Old 04-19-2013, 03:28 PM   #1
Matbc
Member#: 322121
Default How to install CS side skirt on STI 08 ???
Hi I was wondering how to install chargespeed side skirt on my STI 08 ? Do I have to remove my stock side skirt ?? Thanks for help !
Matbc is offline   Reply With Quote
Old 04-19-2013, 03:49 PM   #2
IMPREZA GUY
Member#: 4119
2011 Mitsu Evo X
Graphite Gray
There was a thread about this with a guy that installed the STi side underspoiler. He removed the sideskirt first.
IMPREZA GUY is offline   Reply With Quote
Old 04-19-2013, 03:55 PM   #3
Matbc
Member#: 322121
I can't find the thread you are talking about...
Old 04-19-2013, 04:30 PM   #4
LiCelsior
Member#: 182551
2004 STi
is it bottom line side skirt? or is it a full replacement? if its the bottom line then it goes on top of the oem side skirts.
LiCelsior is offline   Reply With Quote
Old 04-19-2013, 05:03 PM   #5
Matbc
Member#: 322121
Old 04-19-2013, 05:49 PM   #6
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
Isn't it great that none of the bayson r products come with any type of instructions?
danny_d19 is offline   Reply With Quote
Old 04-19-2013, 07:08 PM   #7
Matbc
Member#: 322121
It comes with any instruction...
Old 04-19-2013, 07:34 PM   #8
emazz104
Member#: 281811
04 WRX
My 04 CS bottom line style side skirts from bestracingmotors (I think that's the name from eBay) did not require the side skirts to be removed. I did install the bottom line skirts onto the side skirts off the car be size I was adding STi skirts at the same time and it looked as if the side skirt clips on the bottom would also go through the bottom like kit. I was wrong. It made it too thick so I actually ended up removing the bottom line kit, clipping my factory side skirts in, the adding the bottom line kit. They were only held on with 9 screws per side that screw into the factory side skirts.
I would assume the GR kits are the same as the GD.
Although it doesn't really matter if they are urethane or fiberglass because unlike a front lip, they should scrape on anything, I found the urethane version easy to install. I'm sure the fiberglass version would have been fine, but urethane made it easier beside they were flexible.
I don't know what's what for the GR, but for my GD baysonR were fiberglass. Just something to keep in mind.
Sorry for the rambling.
tl;dr, the side skirts can stay on the car, at least on the GD.
emazz104 is offline   Reply With Quote
