Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 04-08-2013, 12:53 PM   #1
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Default idle issues. built 2.1stroker
Ok so sometimes ONLY at idle i have the following problems.
1. One time only this happened. The car was a warm start and idle had dropped low to 500 then as it raised the boost gauge raised up to 1psi ish and then the car rev'd to 3k and then settled back down to normal idle of 1k rpms. All in all lasted maybe 5seconds max
2. The cars idle ONLY at idle will sometimes jump a few 100rpms and hang there a bit and then drop back down. Usually once the car is fully warmed up it will do this. This is not constant but does happen daily.
Iacv has been removed and cleaned with new oring installed.
MAF has been removed and cleaned.
Front O2 sensor has been replaced and Afs all read normal.
An ecu reset has been done at every part cleaning or replacement.
For those that do not know i have a built 2.1 stroker. Stock heads.
Any info would be appreciated.
As a side note of minor concern is it normal to see full boost at part throttle and the check eng will blink but not save the data for me to read it? Would this be a issue with the tune?
Thanks!
cosseywrx is offline   Reply With Quote
Old 04-10-2013, 08:56 PM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Did you check the tune. It changes idle and timing plus af target based on coolant temp... Just a thought.
Bamofo is offline   Reply With Quote
Old 04-15-2013, 08:44 PM   #3
cosseywrx
Member#: 276443
Im aware of this. It was retuned when it was built. Just ruling aout all mechanical or electronic issues first.
Old 04-15-2013, 09:23 PM   #4
majik1
Member#: 255841
2005 WTX STi
white
Have you checked for any vacuum leaks??
majik1 is offline   Reply With Quote
Old 04-15-2013, 09:35 PM   #5
cosseywrx
Member#: 276443
Yes. Even sprayed the motor with carb cleaner while it was running. No change in idle was noticed/heard/seen.
Old 04-15-2013, 09:36 PM   #6
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
Intake manifold to tgv, tgv to head or maybe fuel injector o-rings?
bigolrig is offline   Reply With Quote
Old 04-15-2013, 09:55 PM   #7
cosseywrx
Member#: 276443
Injector o rings are new. Like i said. I sprayed everything.
Old 04-15-2013, 09:57 PM   #8
cosseywrx
Member#: 276443
This all started i started to clean the maf. Replaced front o2 and cleaned the iacv. All are installed correctly and sealed perfectly.
Im not downing any ideas. I want all thoughts before looking at retune.
Old 04-16-2013, 12:09 AM   #9
majik1
Member#: 255841
2005 WTX STi
white
I know this sounds exactly like mine dude with the wandering idle and the bogging to low idle, that is why I say to find a buddy with a smoke tester and put it on the im where the fuel rail vent is...
Old 04-16-2013, 09:59 PM   #10
cosseywrx
Member#: 276443
Smoke test was good. No leaks found. Smoke test more than 1 spot to make sure.
Old 04-18-2013, 01:33 AM   #11
cosseywrx
Member#: 276443
My main problem persist.
Its running lean at idle adding 18-25% extra fuel.
I unplugged the o2 and it does the exact opposite. Runs rich and -18-25% fuel.
Any body know whats going on? Most likely the tune is the problem?
Old 04-18-2013, 06:56 AM   #12
Bamofo
Member#: 159743
07 STI Limited
Sounds like the tune. Do you hav access to the rom? I can take a quick look
Old 04-18-2013, 08:50 AM   #13
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Injectors? Rhinking one may be stuck/sticking intermittently.
aboothman is offline   Reply With Quote
Old 04-18-2013, 11:17 AM   #14
cosseywrx
Member#: 276443
I really dont think injectors because the issue got worse when i replaves the o2 sensor (front).
Old 04-18-2013, 03:22 PM   #15
Xcrave
Member#: 351592
1999 RSTI Ver. 6
I think it's the tune. I'm running in my EJ207 an EJ257 crank and it did that for awhile cause it wasn't tuned imo
Xcrave is offline   Reply With Quote
Old 04-18-2013, 03:29 PM   #16
Power-Division
NASIOC Manufacturer
Member#: 337895
how does it run off idle? drives fine, boosts fine, hauls ass?
Power-Division is offline   Reply With Quote
Old 04-18-2013, 09:10 PM   #17
cosseywrx
Member#: 276443
Yes yes and hell yeh!
Old 04-18-2013, 09:10 PM   #18
cosseywrx
Member#: 276443
I will link my build thread within the hour.
http://forums.nasioc.com/forums/show....php?t=2312759
my build
Old 04-19-2013, 07:09 PM   #19
cosseywrx
Member#: 276443
looks as-if the MAf just need some scaling. i really appreciate the help from Bamofo!
Old 04-19-2013, 11:31 PM   #20
cosseywrx
Member#: 276443
i learned to scale the Maf myself and got it between AF learned -0.78 and +0.78.
thanks for all the help and suggestions
