Old 04-19-2013, 04:37 PM   #1
09wrbrex
Member#: 350382
2009 WRX
Default Anybody upgrade sound system without sub?
I really need to upgrade the stock sound system in my 2009 wrx as many of you know it's not very good. I have an mrp500 amp and a ten inch kicker l3 from my previous car but I wanted to get some input from anyone who has upgraded their speakers and maybe threw in a small amp for the speakers. How is it? Is it worth the money/sound quality? I definitely want to get more bass and frequency but I wanted to try avoiding installing the sub because it takes up trunk space and would be annoying anytime I needed to get to the spare tire/jack. Any input would be great thanks!
09wrbrex is offline   Reply With Quote
Old 04-19-2013, 09:08 PM   #2
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
price comes down to brand, quality not so much. If you're dead set against a sub then the best bass you can get from a door speaker would be 6x9's with a dedicated amp for the two of them, however those won't fit in your rear doors and custom work will be required. So it comes down to what you want out of your speakers, if you want booming bass, use your sub and deal with it....if you don't care so much then just get a set of speakers that fit, amp them and tune it to your liking and be set that way. You will not find a speaker that's less than 7in diameter that'll be a replacement for a dedicated subwoofer system.
brew02wrx is offline   Reply With Quote
Old 04-19-2013, 09:26 PM   #3
jimbosv650
Member#: 261307
04 wrx wagon
You'll get a better variety of answers by posting in the correct sub forum. http://forums.nasioc.com/forums/forumdisplay.php?f=25
edit: just noticed that you did
jimbosv650 is offline   Reply With Quote
Old 04-19-2013, 10:58 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
My old bugeye had a nakamichi cd45z, some jl 5.25 separates, and 5.25 coaxials in the rear deck lid. No amp or sub.
I loved how clean that setup was. Both in looks and sound. It did need a sub though, and an amp could have helped too, but it was a simple budget upgrade.
mitch808 is offline   Reply With Quote
Old 04-20-2013, 09:47 AM   #5
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
I changed the original HU for a fancier one, (non nav), and saw an improvement. I also replaced the stock speakers with the Upgraded ones Subaru sells. Mainly because I wanted PNP. They sound light years better than the stockers. I have the small Alpine 4 ch amp that I intend to install at some point but I haven't gotten round to that as of yet. I am pretty happy with the improvement in sound. I believe the HU goes up to 40 on the volume, and I can run it at 36 an have decent sound. Adding 40 watts RMS per channel should put things where I'll be happy with it, and consider it done.
As you probably know, getting those pesky loudness and EQ settings turned off make things better. The other things I have done have also netted improvements. I also know you could probably get better speakers for less and the spacers needed from P Henry. That alone would likely yield a big improvement.
John
Old 04-20-2013, 09:51 AM   #6
gettle70
Member#: 312825
2011 Impreza 2.5i
blue
you could try to modify the rear doors to mount some 8in for them and amp them you can get some decent bass out of a quality 8in .
gettle70 is offline   Reply With Quote
Old 04-20-2013, 10:21 AM   #7
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
I changed my head unit to get bluetooth and HD Radio. At the same time I had the
front speaker changed. I'm happy with the results.
Go to radio installers and listen to their equipment.
CRAZYHAWK is offline   Reply With Quote
Old 04-20-2013, 12:37 PM   #8
moby4dick
Member#: 51901
'04 WRX
http://www.fastwrx.com/auinsubo.html
They say it allows access to the spare tire. If you already had a sub, then you'll never be happy without it. Low frequencies require power and air movement; no 6 x 9 door speaker is going to do that.
moby4dick is offline   Reply With Quote
Old 04-20-2013, 05:58 PM   #9
luan87us
Member#: 335013
2013 Premium WRX 5dr
Although I agree that probably one of the best option to install a sub into the WRX/STi I think It's rather overpriced (just my opinion).
@OP: Door speakers definitely WON'T ever give you the same result as a dedicated sub-woofer would. A lot of members here have been putting underseat sub into their cars and seems to be happy with it so may be that'll be something you can look into.
Old 04-21-2013, 03:21 PM   #10
sgp250r
Member#: 256882
2005 WRX Sedan
CGM
If a person spends the extra time and money and really seals up the front doors (outter & inner skins) with a sound dampening product a good quality 6 inch separate can really produce some good midbass...granted that's no sub of course.
You can pick up Audio Integrations enclosures directly from them as well for a bit cheaper - http://www.audiointegrations.net/08subaru.html
sgp250r is offline   Reply With Quote
Old 04-22-2013, 01:27 AM   #11
1oldman
Member#: 325505
2015 WRX
Crystal Black Silica
Seal up your rear doors really well and get a couple of JL Audio 6W3v3-4: 6.5-inch (165 mm) Subwoofer Driver, 4 Ω subs with a amp. That will be about the best you can do without a dedicated sub. These are true 6" subs that can run off of a small 50-75 WRMS amp. You don't need rear fill speakers since they really don't do much filling anyway. I went with two six inch CDT M6 subs in my XRX's rear doors and they provided adaquit bass response if not very spectacular. They are about half the price of the JLs.
1oldman is offline   Reply With Quote
Old 04-23-2013, 04:43 PM   #12
09wrbrex
Member#: 350382
2009 WRX
Thanks for all the ideas guys! I think I might just go with some door speakers and a head unit and maybe a small amp for them considering I just put my new exhaust on and that brought out many new interior rattles so I can't imagine how bad it would be with a sub without getting the whole car dynomatted or something
Old 04-23-2013, 05:17 PM   #13
Beau M
Member#: 345079
13 Wrx sedan
There are a few companies that make 6.5" subs. Kicker, JL, Dynaudio, Tang-Band. I've always wanted to play with a pair in the rear doors.
Beau M is offline   Reply With Quote
Old 04-23-2013, 05:34 PM   #14
09wrbrex
Member#: 350382
2009 WRX
Video Link: http://www.youtube.com/watch?v=JuJmZbVncoU
Yea I'll definitely look into those, but I would imagine they would be too deep to fit in the doors
Old 04-24-2013, 07:22 AM   #15
Xterrapin
Member#: 352282
How about an underseat sub ? I have a Rockford Fosgate sub under the front seat of my Xterra, and it does a pretty good job.
Xterrapin is offline   Reply With Quote
Old 04-24-2013, 08:34 AM   #16
1oldman
Member#: 325505
2015 WRX
Smile
I fit the CDT M6 Sub/Mids in the rear doors without and adapters. You will need to deaden the doors unless you like rattles.
Old 04-24-2013, 09:06 AM   #17
sultan81
Member#: 309943
2012 STi
get a set of decent components for the front stage and put two 6" subs in the rear doors.
sultan81 is offline   Reply With Quote
Old 04-24-2013, 10:26 AM   #18
chappys4life
Member#: 349639
2 6" subs in the rear would be awesome but would they fit?
chappys4life is offline   Reply With Quote
Old 04-24-2013, 11:31 AM   #19
sultan81
Member#: 309943
2012 STi
they sell adapters to make the 6" fit, you would have to measure depth, some people have went with shallow mount 6's.
Old 04-24-2013, 09:46 PM   #20
09wrbrex
Member#: 350382
2009 WRX
Where did you buy them from? I've looked online and can't seem to find them anywhere besides amazon and eBay and I'm a little skeptical about ordering electronics from eBay lol and how do you like them? Seems like they'd be good for what I'm looking for
Old 04-25-2013, 07:57 AM   #21
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Install a traditional system..
Buy a small 8-10" sub and TRUCK style sub box.. should be small enough to fit behind the driver seat (see Parts Express for inexpensive boxes and subs)
Put sub on a longish piece of wire and have a bananna terminal on the wire and cup on the box..
If you need the back seat.. put the sub in the trunk. .. if you need it all... put the sub in the garage...
You get all the bennies
Old 04-25-2013, 08:06 AM   #22
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You could also consider "bass shakers" for subless bass...
Old 04-25-2013, 09:50 AM   #23
sultan81
Member#: 309943
2012 STi
woofersetc.com isnt bad. hifisoundconnection.com . Knukoncepz.com for wiring.
