Old 04-20-2013, 08:31 PM   #1
_DDMM
Member#: 333653
2007 WRX
Urban Grey Metallic
Default Having trouble with replacing my rotors on a 2007 WRX.
So I was able to replace my brake pads just fine. My problem is taking off the calipers to access taking off my rotors. Am I doing more than I need to? What i'm doing is trying to take off the bolts behind the calipers so I can take them off and access the rotor. The problem with that is the bolts are on suuuper tight, and its not just that. I don't have any room behind the caliper to fit a torque wrench in and take the bolts off. If anyone can provide tips that'd be helpful. All the shops around Vegas are charging $95+ just to install rotors.
_DDMM is offline   Reply With Quote
Old 04-20-2013, 08:55 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Don't know what to say, but get more on those bolts. They can get rough with being exposed and out there and pick up some corrosion.
PB Blaster / Liquid Wrench or whatever your favorite penetrant is, then get a combo wrench on it and whack that with a deadblow hammer if you need to.
Old 04-20-2013, 09:30 PM   #3
alx8283
Member#: 225024
2002 wrx
Double wrench it?
alx8283 is offline   Reply With Quote
Old 04-20-2013, 09:41 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Why would you use a torque wrench to remove a bolt?
And one combination wrench stuck on the other, or hitting the wrench with the hammer, or just going and getting a breaker bar would all probably work.
jamal is online now   Reply With Quote
Old 04-20-2013, 09:49 PM   #5
Amoehlau
Member#: 346085
2006 WRX
This just happened to me not too long ago on my 2006 wrx. According to the dealership this is a common occurrence with the 4pot calipers Only the fronts, the back 2pots do not have the issue. I just used tons of PB and cranked the wheel all the way so I was able to get a small pipe on the end of my wrench. Just a tip, use a 6 point wrench if you can, the bolts are extremely soft for some reason and a 12 point may murder the head. I ended up braking the bolts on the driver's side and had to attempt to pound the caliper away from the mounting bracket which lead to me braking the caliper I reinstalled the bolts with some anti-seize in hopes that this would not happen again and torqued to specs. Good luck with yours! hope it goes much better than it did for me haha.
Amoehlau is offline   Reply With Quote
Old 04-21-2013, 02:55 PM   #6
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
PB blaster, breaker bar and mallet if needed then, use anti seize putting it back together so you don't have an issue taking them off next time
575rider is offline   Reply With Quote
Old 04-23-2013, 10:29 PM   #7
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
I had to turn the wheel and use a pipe on a bresker bar. It may be a silly question but are you turning it the right way
faSTI666 is offline   Reply With Quote
Old 04-23-2013, 11:02 PM   #8
jmp6889928
Member#: 340677
2005 LGT 5EAT
RBP
Use carburetor cleaner instead of the PB blaster. It contains an acid that is there to eat away varnish and crap off of carbs and will penetrate faster. Take a small ball peen hammer after spraying the bolts, and smack them directly on the head of the bolt several times-straight in the direction that they are threaded in. This helps loosen the threads inside of the threaded hole. Then, use a breaker bar, 6 point socket and pull to loosen. If they still don't want to come lose, then try to tighten the bolt a tiny bit. Pull on it to loosen again and keep going-tighten and loosen, until it comes loose. A broken bolt is just as much pain in the ass as it sounds so do whatever you can to NOT break them.
Remember: When working on Subaru, learn two words very well-ANTI SEIZE ! !
Use it on EVERY bolt you ever put back in.
jmp6889928 is offline   Reply With Quote
Old 04-24-2013, 12:26 AM   #9
dictoresno
Member#: 139816
2002 WRX, VF34 swap
he probably recommended this because a torque wrench is as long as a lypical breaker bar. however, i would never use an expensive torque wrench to break free a stuck nut/bolt. i would rather risk a normal breaker bar/pipe combo.
dictoresno is offline   Reply With Quote
Old 04-25-2013, 12:22 AM   #10
thejaredhuang
Member#: 86206
2006 WRX Wagon
Step 1 don't use a torque wrench to loosen things
Step 2 get a proper breaker bar. I got mine off by standing on 18" breaker bar.
Make sure you're turning the right way. For the driver side you should be going towards the ground.
It might help to take the lower bolt off strut, it won't affect your camber when you put it back.
thejaredhuang is offline   Reply With Quote
Old 04-25-2013, 07:32 AM   #11
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
FIRST OF ALL...you do NOT use a torque wrench to take the bolts off...that is your first mistake...
and tells me that ya need somebody to help keep you from doing something else ya shouldnt do
Old 04-25-2013, 08:16 AM   #12
AspenScoob255
Member#: 217405
2006 WRX
Or perhaps he doesn't know the proper names for tools? I have heard people call a breaker bar a torque wrench before
There is also a chance that i have far to much faith in humanity.....
AspenScoob255 is offline   Reply With Quote
Old 04-25-2013, 08:34 AM   #13
gggplaya
Member#: 139444
2008 Impreza
Dark Gray
Nothing wrong with using a torque wrench to remove things per se, but the head of the torque wrench is large and may hit the strut bolts or brake line, as well as you may damage the torque wrench itself.
Go to harbor freight and buy yourself a breaker bar, it has no head and swivels so it can fit into tight places, as well as being able to turn from different angles. SHould be around $10.
Then jack up the car and take off both front wheels. Turn the steering wheel full left when working on the left side and full right when working on the right side, this sometimes helps to give you more room.
I just did the brakes on my brothers EVO X yesterday and his brakes are even bigger than yours. It was a biotch to break the top bolt loose, but when i threw on the breaker bar, it went super easy.
gggplaya is offline   Reply With Quote
