Old 02-16-2013, 10:20 AM   #1
Nick_P_
Member#: 343384
2003 Impreza wrx
Default Ej205 build just started
So I'm gonna build a ej205. I'm pretty new to the forum but have been trolling the built motor section reading all the stickies and 2l builds I can.
To start off I bought on an eBay auction a set of eagle rods and arias pistons new in box for $375 shipped which is a crazy good deal. My buddy gave me a short block that spun the number 3 rod bearing. Here lies my first question should I replace my crank or have it turned down and go with a larger bearing. The cost of a new oem crank is $350. The cost of turning it down is $100. Has anyone gone this route?
I'm aiming to make around 350 hp. And I know everyone is gonna say just buy the jdm v7 swap because it can make that power but that's not the route I wanna go.
Parts I have so far
Eagle rods
Arias pistons 92.5mm 8.7:1
Bloush 20g
King main bearings
Killer b oil pickup
Parts I'm planning on
Bc 272 cams
Bc valve springs
New stock size valves
New gasket kit
My car already has
Agency power exhaust
Tsudo Catless downpipe
Perrin up pipe
Spt cold air
Cobb access port
Deatschwerks 650cc injectors
Deatschwerks 255 fuel pump
Vf39 turbo
Suggestions would be great and let's keep the v7 swap out of this please
Nick_P_ is offline   Reply With Quote
Old 02-16-2013, 12:53 PM   #2
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
get a new crank dont mess with turning one.
Couple things I didnt see on your list:
Rod bearings
Oil pump
Oil cooler
Timing kit w/ pulley
Maybe shimless buckets for the heads if you plan on reving it out much past 7k. Shim over bucket came in 02 and most 03 WRXs
Old 02-16-2013, 01:07 PM   #3
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Personally, I don't have a problem with a ground crank and but you may be better off with one of the newer crossdrilled cranks at the power levels you're looking for.
theotherguy is offline   Reply With Quote
Old 02-16-2013, 01:35 PM   #4
Nick_P_
Member#: 343384
2003 Impreza wrx
What's the cost of a cross drilled crank I don't think I wanna spend a $1000 on a crank to be honest. My 2003 wrx doesn't have an oil cooler. I know this because when I did my timing belt and water pump the new gates kit water pump had the bung for it and I had to cap it off. Also at full operating temp an oil cooler is pretty ineffective. As for rod bearings kinda gotta wait on those until my crank issue is settled. What's the best oil pump to go with dollar for dollar?
Old 02-16-2013, 04:07 PM   #5
theotherguy
Member#: 191514
'05 FXT 6spd, 98
The cross drilled cranks are oem ej205 04+. $350 or so.
Old 02-16-2013, 05:35 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
The oil cooler is what the oil filter screws into. The only reason I said to replace that is cause of the bearings that went thru the motor. You can try and clean it out but people have def lost motors going that route and its not something Id risk.
Best oil pump for you will be the 10mm subaru pump most likely
People have turned cranks and used oversized bearings but when its all said and done you save maybe $200 and w/ a 20g IDK if I'd risk it.
Old 02-16-2013, 09:54 PM   #7
Nick_P_
Member#: 343384
2003 Impreza wrx
Okay so I'll buy a new 04 crank then and the 10mm pump. I've built some Chevy v8s and a lot of Honda motors but I'm gonna leave the assembly of this motor to my local subaru speed shop
Old 02-16-2013, 10:03 PM   #8
Paul
Member#: 56203
00 RSTI Coupe
if you have a dial bore gauge and some Mics I'd assemble it yourself.
If you do have a shop do the assembly, a vendor off of here will be your best bet!
Old 02-16-2013, 11:30 PM   #9
Nick_P_
Member#: 343384
2003 Impreza wrx
Here In Tacoma Washington we have a mainly subaru shop called pacific import auto they do big builds and every thing subaru down to dyno tuning. I have all the stuff but I'm a bit scared of assembling it without someone who's done it before.
Old 02-17-2013, 12:37 AM   #10
wrx1392
Member#: 342331
2003 wrx
blue
get the 2005 WRX cross drilled crank pm me i got one for $310 ish .also the oil pan is a B to clean out all the metal from spun bearing .but yeah new oil cooler ,oil pump. with a used block you might want to try some cosworth +.001 main bearings or you might not get the bearing clearance right .you'll need mics too to measure this stuff.dont ask me how i know this i learned the hard way ..oh and use an oem gasket set USE oem o-rings in the block halfs ...also dont ask me about that either good luck with the build ....these motors are a different animal so if this is your first motor build get some help and find a machine shop that knows how to work on Subies. and hang on to your wallet $4,000 goes fast.and that was me doing all the labor
also id use the 16gxt for a faster spool .dont think you need cams to get to 350 hp at the crank. 8.7 CR is a tad high also so a 16 gxt should get it done. i think Maxwell power is up in your neck of the woods he has a program where you help build the motor under his watchful eyes....i think he does that shoot him a pm .he know his stuff.
wrx1392 is offline   Reply With Quote
Old 02-17-2013, 04:55 AM   #11
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Dont really need cams. Im making 300whp on a 2.1l stroker on 16psi 18g turbo. Winter tune
cosseywrx is offline   Reply With Quote
Old 02-17-2013, 11:03 AM   #12
theotherguy
Member#: 191514
'05 FXT 6spd, 98
You can't go wrong with PIA or Maxwell, except I don't think Maxwell will let you use your used parts. Its top of the line new or nothing, you get what you pay for in quality.
If PIA is going to assemble I'd drop it all off and let them do the machine work, etc. They might like it done by their own machine shop to their specs.
Keep the oil cooler delete, no point in getting another one.
Only thing I'd be concerned with is your 650cc injectors. On our built ej205 with a gt3071r at 26 psi, we were hitting 76% injector duty cycle on modded light blues, 820cc.
We also had stock cams, fell off on the top end a little but not enough to care.
Good luck with the build
Old 02-17-2013, 02:57 PM   #13
Nick_P_
Member#: 343384
2003 Impreza wrx
The only used parts I have are the block and crank everything else is new in box
Old 02-17-2013, 07:23 PM   #14
cosseywrx
Member#: 276443
New crank man. No point in using a used one
Old 04-10-2013, 12:09 PM   #15
Nick_P_
Member#: 343384
2003 Impreza wrx
Just a little update. My block is currently in the shop getting all the machine work done. I should have it back in a few weeks. Then ill start the assembly process!
Old 04-10-2013, 02:02 PM   #16
mash740
Member#: 310419
2002 wrx
I don't see the reason to buy a new crank, I myself got my crank grinded and balanced. I wouldn't waste your money.
mash740 is offline   Reply With Quote
Old 04-20-2013, 12:48 PM   #17
Nick_P_
Member#: 343384
2003 Impreza wrx
I bought a amr cxr750 turbo I got a awesome deal on it. But I'm a little concerned that its way to big for a 2.0. Anyone ever ran this turbo on a 2.0?
Old 04-21-2013, 12:48 AM   #18
kilgore
Member#: 267768
Sonic Yellow
80lbs a minute, that's a big snail. The 35r flows 65lbs and those are rather large on a 2.0.
kilgore is online now   Reply With Quote
Old 07-08-2013, 03:36 PM   #19
Nick_P_
Member#: 343384
2003 Impreza wrx
Started assembly today on the short block. Measured everything out with bore gauge and calipers. Standard size bearings are what I came up with. Also decided to platicgage the bearings also and came out in spec! Dropped my heads off to be machined this morning also shoul have those back next week sometime.
Old 09-04-2013, 12:56 PM   #20
Nick_P_
Member#: 343384
2003 Impreza wrx
Heads are all finished and my crower cams are installed also. Anyone have any cam lifter buckets laying around? I need these sizes 494, 456, 498, 478, 474, 483x3, 458x3, 490x2, 486x3
Old 09-04-2013, 12:58 PM   #21
Nick_P_
Member#: 343384
2003 Impreza wrx
I also sold the amr and picked up a more manageable fp18g and a grimmspeed up pipe with a tial 44mm ewg
