Old 04-20-2013, 07:37 PM   #1
POC
Member#: 344560
2007 Impreza
Default How to change a tire.
I'm not new to cars, and I'm not stupid. I've removed all the lug nuts, but the wheel won't budge. I'm applied some force, but still won't budge.
Is there a secret?
POC is offline   Reply With Quote
Old 04-20-2013, 07:46 PM   #2
Thunderpaw
Member#: 242205
2009 wrx
blue
Is it off the ground?
Jk
Lugs are only thing that holds them on
Thunderpaw is offline   Reply With Quote
Old 04-20-2013, 07:48 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
The wheel is probably slightly rusted onto the hub, which is keeping it from pulling cleanly off. I ran into this once when changing the wheel on a friend's Honda. The easiest solution is probably to lower the car VERY gradually to put some pressure on the tire/wheel and break it loose. Once it's loose, you can jack it back up and pull it off.
Old 04-20-2013, 07:51 PM   #4
POC
Member#: 344560
2007 Impreza
Thanks guys. I thought there might be some kind of "theft" device I wasn't familiar with. When I got the lug wrench out of the little bag, there is a Philips screw driver in there too....my imagination got the best of me.
Old 04-20-2013, 08:01 PM   #5
metoto2sti
Member#: 340990
2012 subaru Sti
Dark Gray Metallic
I love happy ending! !
metoto2sti is offline   Reply With Quote
Old 04-20-2013, 08:08 PM   #6
Amoehlau
Member#: 346085
2006 WRX
Happens all the time, just give the side of the tire a good kick.
Amoehlau is offline   Reply With Quote
Old 04-20-2013, 08:44 PM   #7
POC
Member#: 344560
2007 Impreza
Ok.....I kicked, I laid on the ground and kicked front and back.....I guess it is really stuck. I'll get some WD40 tomorrow....
Old 04-20-2013, 09:04 PM   #8
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
If it's stuck and a good kick won't get it loose, I have a step program:
Step #1. Put the lugnuts on finger tight. Drop the floor jack.
doesn't break free?
Step #2. Get in the car. Put it in reverse. Go about 3 feet and nail the brakes.
doesn't break free?
Step #3. Go forward (faster than last time) and nail the brakes. Hard. No...Harder than that.
Old 04-20-2013, 09:09 PM   #9
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
If it's a front wheel you can also do the lugnuts hand tight, down on the ground and then crank the wheel once or twice.
I have used a 4 pound mini sledge against a piece of wood that was against the wheel on more than one occasion.
Corroded on brake rotors are even worse. I have beaten on those for what seemed like hours.
aerosaaber is offline   Reply With Quote
Old 04-20-2013, 09:36 PM   #10
Twister8008
Member#: 291773
This is exactly correct. I had this occur on my precious cars before.
Twister8008 is offline   Reply With Quote
Old 04-20-2013, 10:04 PM   #11
Amoehlau
Member#: 346085
2006 WRX
I would give the block of wood and a sledge a try. If that doesn't work then any of the suggestions with lowering the car with hand tight lug nuts has to do it I would just be very careful in doing so.
Old 04-20-2013, 10:07 PM   #12
lavid2002
Member#: 226864
I take a step stool and wind up and WACK the tire of the wheel and it pops right off. I have to do this all the time. I love the looks I get when I grab the step stool. People think I am nuts. I go from the inside of the car and smack the corner of the inside sidewall.
It is the perfect length so that I can swing from the bumper. It also has enough momentum to pop the wheels off the hubs.
You do not need WD 40.
Old 04-20-2013, 11:14 PM   #13
blue wrench
Member#: 349542
What has always worked for me with anything is to put a lugnut or two back on just a few threads, laydown underneath the vehicle if you have the clearance (obviously easier with a shop lift than jack/jackstands) and give the wheel a good hard stomp at the inner flange. No need to get big bertha out
blue wrench is offline   Reply With Quote
Old 04-20-2013, 11:47 PM   #14
FrozenIce
Member#: 349378
1993 Impreza WRX Sti
With the vehicle safely raised, take off all the lugs, and put one back on a few turns, I pick an upper stud. Beat the inner rim flange with a deadblow. I do this on a daily basis, usually 1 or 2 swings will do the trick.
To help prevent the corrosion, clean off the hub flange, and the rim seat, and apply a light later of silicone lube, or any grease. It won't need much.
FrozenIce is offline   Reply With Quote
Old 04-21-2013, 07:30 AM   #15
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
A have a 5 lbs rubber mallet that works great in those situation.
Caocao is offline   Reply With Quote
Old 04-21-2013, 10:06 AM   #16
BubbaFNSmith
Member#: 352192
2014 WRX
Kick it.
BubbaFNSmith is offline   Reply With Quote
Old 04-21-2013, 10:28 AM   #17
Turd Nugget
Member#: 346017
2013 STi Wagon
what kind of car is this?? On the last car I owned, I tac welded the wheels on from the backside right before I traded it in.......
Turd Nugget is offline   Reply With Quote
Old 04-21-2013, 10:43 AM   #18
toph
Member#: 78640
14 KTM SuperDuke R
16 Tacoma | 02 STi Wagon
Put one of the top lugs on slightly and then just smack the bottom inside of the tire.
toph is offline   Reply With Quote
Old 04-21-2013, 10:57 AM   #19
danbolsom
Member#: 256898
2011 WRX Limited 6MT
PB blaster works wonders in this situation.... just don't get it on your brake rotor or pads.
also once you get it off, apply some anti seize to the wheel studs and face of the rotor to keep it from happening again.
danbolsom is offline   Reply With Quote
Old 04-21-2013, 11:07 AM   #20
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
just adding to the "kick" camp. I stand with my back to the tire and use the bottom of my foot to kick the tire. But I kick it in a certain way to spin the tire a little. This kind of works it back and forth to get it off.
ADVICE: Once you do get it off, put a little anti-seize on the hub. This should help take care of it in the future.
Bacon117 is offline   Reply With Quote
Old 04-21-2013, 11:58 AM   #21
Driven2Ski
Member#: 254228
Have you tried lifting the wheel, then pulling it off? Sometimes the wheel can get snagged on the threads, especially if there's corrosion.
Also, check to see if your wheel has a concealed anti-theft device.
Driven2Ski is offline   Reply With Quote
Old 04-21-2013, 12:06 PM   #22
cvananden
Member#: 326698
2006 WRX Ltd.
San Remo Red
Go to the gym. Work your legs. When you've done this properly, go kick that bitch off. Open a beer. Celebrate.
cvananden is offline   Reply With Quote
Old 04-21-2013, 03:48 PM   #23
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I put one lug on lose and use a pry bar from the caliper to the rim and pull. Works easy.
Old 04-21-2013, 04:17 PM   #24
Swanelious
Member#: 354133
Silver ... mostly
I use a method quite similar to those already mentioned. Any hammer will work, the heavier and wider the head the better. Keep the vehicle off the ground, start one lug nut on, and smack the bottom of the tire from the back side. This may require laying down on the ground. You get a good swing and you're applying force in the correct direction to get the wheel off.
Hitting or kicking from the front requires more force because the wheel has to pivot before breaking loose from the rotor.
Swanelious is offline   Reply With Quote
Old 04-21-2013, 10:06 PM   #25
some dude
Member#: 100300
06 WRX
Wrecker drivers use a piece if 4x4 wood about 3 feet long. Ram than on the edge of the rim next to the bead of the tire and it usually pops off on the first shot. Tons of wheels freeze on there and some can be a real bear to get off.
