Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 04-20-2013, 12:48 PM   #1
jsubiesk
Member#: 335038
1995 impreza
Default boosting problems ver 2 ej20g
Just upgraded all the neccessary mods needed and got robs 550 tune. By the way this tune is incredible and there is a noticeable increase in smootheness and it pulls better through every gear. That being said I cannot reach 1.25 kg/cm squared. Which is just under 18psi. The hoses having to with the boost control solenoid dont look to be hooked up properly and on the side of my apexi intake I am unsure which hose is to be connected to the little nipple on the part after the maf. Any help is appreciated and ill put a picture or two up
jsubiesk is offline   Reply With Quote
Old 04-20-2013, 12:50 PM   #2
jsubiesk
Member#: 335038
1995 impreza
I forgot to mention what happens is a heavy sputter at times and a lot of hesitation. feels like a misfire or fuel cut. I just had all the coils out and I have ngk iridium plugs in. The coils all looked to be in good shape.
Old 04-20-2013, 07:17 PM   #3
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
This is more a curiosity thing and not help but, have you done the coil pack upgrade to the 02+ WRX/STi coils?
I used to have a v2 swap with a Rob tune as well and the coil pack upgrade is a MUST for the ej20g platform.
Your current problem may be caused by a different issue but those older coil packs tend to fail when under higher stress which the new 550 tune would do. Even if there are no visible cracks they can still be bad.
As far as the hoses go....if you can post a photo I could reference my old engine bay and try to help you out with proper connections.
hail2theTheif is offline   Reply With Quote
Old 04-21-2013, 04:20 PM   #4
jsubiesk
Member#: 335038
1995 impreza
I just confirmed all my lines are hooked up properly. I am going to do the coil convert just to be safe. I didn't know they could be faulty with no visible signs. thanks for the input
Old 04-21-2013, 04:23 PM   #5
carl1975
Member#: 354134
Default boosting problem please help
Hi i am currently having problems with my boost on my 1995 subaru wrx wagon it gets to where it normally begins to boost then it starts to misfire and sounds like its hitting rev limiter and it looses power,if i continue to try to get boost i also noticed it boils my water up but temp stays as normal, ive checked all the boost pipes and everything seems to be fine,
carl1975 is offline   Reply With Quote
Old 05-02-2013, 10:35 PM   #6
CRX7
Member#: 31639
99 Impreza
Engine cutting under boost at high rpms is the first symptom of bad coils, it gets worse as you let it go with hesitation at all rpms. My coils looked beautiful, but were bad. If you haven't upgraded your coils this is first thing you need to do before you start looking at anything else.
CRX7 is offline   Reply With Quote
