Old 03-20-2013, 10:28 AM   #1
boxer07wrx
Member#: 293439
2007 WRX
Default Removing air pump for meth tank
Does anyone know if a strut mounted sti washer tank will fit in my 07 wrx, air pump removed obviously. I was hoping to use it for a meth tank.
boxer07wrx is offline   Reply With Quote
Old 03-20-2013, 11:13 AM   #2
boxer07wrx
Member#: 293439
2007 WRX
Come on guys someone's done it.
Old 03-26-2013, 04:28 PM   #3
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
I was considering this very same thing after I removed my air pump and wanted to make an intercooler sprayer and was considering the washer tank in that spot. The fuse boxes on the 06/07 models are slightly wider. There isn't enough room.
findurpath is offline   Reply With Quote
Old 04-18-2013, 08:14 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
either the regular 04-05 sti trunk tank or spec c tank in the trunk.
Old 04-22-2013, 07:54 AM   #5
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I did this for a while but the trunk tank is really much better. The under-hood temps really heat up your meth mixture making it not as effective and causing it to evaporate over time.
Zackbo is offline   Reply With Quote
