Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 04-09-2013, 10:26 AM   #226
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Originally Posted by manitou View Post
That sound like a great idea, a 3" down pipe and EWG exhaust, merging into a collector/ expansion chamber and into a full 3.5" exhaust that you supply (or not?). The 3.5" has an area of 30.23 sq in. and a 3" exhaust with a 1.75" gate exhaust/ 44mm gate (use the bigger for calculations) would have an area of 29.77 sq in. so you have the flow covered without loosing the gains of the external gate. Another up side is you control the whole exhaust tract and the performance of that if you supply that!
The downside of the merged turbo and gate exhaust is the added expense to the buyer who may have a nice 3" exhaust but now has to buy your kit with a new exhaust. As well you will have multiple platforms to design the exhaust system for.
Figuring that you dump the gate close to the turbo with a muffler then you could assume the following. The up side of the separate EWG exhaust would be easier to fabricate for you and less costly to the customer. It will flow exactly what it needs without the complication of the merging exhausts.
Down side is the loss of complete control of the exhaust tract using the customer supplied exhaust beyond the down pipe which you would supply.
JMHO
I thought I would point out that one option on the recirc EWG exhaust is an adapter flange. If the KillerB 3 1/2" downpipe ended short of a standard catback, it wouldn't matter because it doesn't have to match other 3 1/2" exhausts. That means that the KillerB 3 1/2" catback could bolt to it (not fitting other downpipes) and there would be room for an adapter to let it bolt to a normal 3" catback if someone wants to keep their existing exhaust.
There would be a power drop for customers with big turbos and they would probably opt for the full exhaust, but some GT(X) 28-30 users might not care as the restriction wouldn't affect them as much and they would probably have lower budgets anyways. Plus, that would let them save up and add the 3 1/2" later.
I recommend starting with a 3 1/2" exhaust for the GR sedan so I can buy it and adapt it to my Bellmouth downpipe by cutting it at the 3 1/2" diameter portion and adding some pipe and a flange...
Speaking of, any progress/pics on the 2012 project car?
bluescoobywagon is offline   Reply With Quote
Old 04-09-2013, 02:36 PM   #227
scoobyrolle
Member#: 315411
Have you had this on the road in the rain at all and Any idea of when/if this will be available to the public ?
scoobyrolle is offline   Reply With Quote
Old 04-09-2013, 06:20 PM   #228
azn2nr
Member#: 35276
Originally Posted by KillerBMotorsport View Post
... but physically the turbocharger just won't fit between engine and front cross member.
is that turbo wider than it is tall/deep?
maybe its just the efr's that are like that but i always thought turbos were more compact transverse.
either way its a great looking kit. im tepmted to buy one of your unfinished/straight out manifolds to try something custom. great work on the turbine reducer too btw.
azn2nr is offline   Reply With Quote
Old 04-09-2013, 08:21 PM   #229
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good observation.
The 12 is going to have injectors put in soon and we should be getting some dyno testing on the cat-back we've been road testing. Then the GR downpipe will be done after we finish the GD version and after that the TS Low Mount... but that's probably fall.
Yes. Rain and torrential downpours. I even drive it through the automated car wash. No date set yet.
I don't have dimension in front of me at the moment, but it is fairly square IIRC. Thanks for the kind words!
Old 04-09-2013, 10:50 PM   #230
scoobyrolle
Member#: 315411
That's good to hear living in new orleans, hopefully a date pops up soon
Old 04-10-2013, 01:27 AM   #231
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
great job on this kit! it's really looking promising!
question: how does this change underhood temps? specifically, if it's under the right front, doesn't that heat up the air that a cold air intake might pull in? or, running the exhaust that close to the RF axle, would it burn up the axle boot prematurely?
lil'redwagon is offline   Reply With Quote
Old 04-10-2013, 01:51 AM   #232
azn2nr
Member#: 35276
the exhaust is always close to that axle and the intake is in front of all exhaust components right near the very front of the car. no hot air over there.
Old 04-10-2013, 10:14 AM   #233
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
looks like you can cut out another foot or more of charge pipe if you ran a reversed intake manifold and throttle body setup. yay for more spool!
gsrcrxsi is offline   Reply With Quote
Old 04-11-2013, 02:45 PM   #234
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Well, looks like I'm waiting until fall for your TS GR kit
I'm also interested in the radiator adapter, more info?
Tyrial is offline   Reply With Quote
Old 04-11-2013, 04:36 PM   #235
V3rtigo
Member#: 262020
2013 STi-Limited
PBP
Subbed. I'll be in the market for this kit late 2014 for the gr/gv
V3rtigo is offline   Reply With Quote
Old 04-12-2013, 08:19 AM   #236
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It is definitely a setup that can be driven in all conditions and has exceptional drivability. My wife (not a car person at all) occasionally drives it and when I ask my usual "how'd the car drive?" gives an uneventful "it was fine" response... although sometimes with a bit of a smirk
Here you can see the turbo pulls air right from the front. It's significantly colder than the OEM or rotated setup. With the hood scoop being deleted and relatively open areas adjacent to the radiator sides there's a lot of airflow through the engine bay (especially with the freaky hood vent/heat extractor I've got on the car).
^ Very true.
I seriously considered this. My thought was, most want A/C and rotating the manifold makes it that much less of a bolt-on kit. There's also the piping that would right RIGHT behind the 175+ degree radiator to get to the TB and according to the bend/length rough calculation it was worth an additional 2% on a good day.
I'm excited to get into this as well! A lot of sketches and some design work has been done, but the big hold-up is we've got the GR slated for a bunch of other product testing before getting into the Low Mount Kit.
That's two for the radiator adapter. If we get to (5) I'll price out manufacturing a small batch.
Great to know!
Old 04-12-2013, 01:43 PM   #237
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Like what? Always interested in GR products from you~
Old 04-12-2013, 03:24 PM   #238
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
nice!! i didn't realize the turbo was mounted as far inboard, toward the center of the car. i was under the impression that it utilized the space between the front right fog light and the wheel well.
as for the axle boot question - do you have any shots from under the car to show how the exhaust is routed around the RF axle?
Old 04-12-2013, 03:43 PM   #239
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
VV this VV
Just so you guys don't think I'm doing nothing over here. This is something I've always wanted to do. Based on some reading I've done this is a weakness in the cooling system. I don't intend to do any testing on my own to verify, but there is significantly more flow capacity and significantly less turbulence in this piece vs OEM casting.
Old 04-18-2013, 09:36 AM   #240
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
im interested in the lower coolant passage adapter too. provided the price point is right.
would it need a custom lower hose? or should it work with stock hoses/rad fine?
Old 04-18-2013, 01:00 PM   #241
veightkiller
Member#: 78967
2011 335i
looks like limited space for a bigger turbo but this setup looks awesome!
veightkiller is offline   Reply With Quote
Old 04-18-2013, 01:40 PM   #242
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I should only require a stock hose to be trimmed.
Correct on the GDs it's very limited. Nothing larger than a GTX35
Old 04-20-2013, 12:08 AM   #243
whitiey922
Member#: 321398
I need to hear what this sounds like!
whitiey922 is offline   Reply With Quote
Old 04-20-2013, 06:33 PM   #245
idratherbesurfing
Member#: 282972
2006 Sti
cgm
wow this is insane. depending on final price i might do this over the borg warner setup i wanted. Guess i should start saving haha
idratherbesurfing is offline   Reply With Quote
Old 04-21-2013, 12:26 AM   #246
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Are you considering doing this for a GR as well....I have a 2011 STI build currently going on and would love this setup....My only issue is I have a big turbo.....Please PM me if you are interested in making one for me....
jdpsearcher is offline   Reply With Quote
Old 04-21-2013, 01:47 PM   #247
arf80
Member#: 125580
2011 WRX 5dr
I'd be interested to see how fast this could spool a 20G for an autocross car.
arf80 is offline   Reply With Quote
Old 04-22-2013, 11:00 AM   #248
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes. Likely to go TS on the GR first, but I'm on the fence on that. Define big?
Well here's a quick comparison (same year with kinda sorta other similar mods). If the pulls were started at the same RPM the onset of power would likely look closer. On the street is spools very rapidly and feels/reacts similar to a VF but just pulls a lot more and there's no power taper.
Old 05-06-2013, 01:31 AM   #249
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Updates?
Old 05-06-2013, 06:42 AM   #250
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Started her up last week and prepping her for an engine transplant. Nothing exciting to report just yet.
