Old 04-22-2013, 08:48 AM   #1
CBC_North
Member#: 338523
Default Brakes grinding after parked
Have had this problem for the last few weeks. When I am leaving my parking garage, the first few times I apply my brakes I hear a grinding sound. It is only the first 4 or 5 times and then I do not hear it again until I have parked my car for a while. I have actually gotten into a habit now of just touching the brakes a few times when I first start out to get rid of the sound. It doesn't seem to affect the braking in any way and there's no difference in the pedal feel. It also happens regardless if the car is moving straight or turning and only when I am actually applying the brakes.
I had originally assumed it was rust clearing off the surface of the rotors after being parked. But now that I have my summers on I can see the surface of the rotor and noticed the car makes the noise even when the rotors have no rust. Just wondering what this could be?
Also, it's a 2009 wrx with everything braking related being stock.
CBC_North is offline   Reply With Quote
Old 04-22-2013, 12:15 PM   #2
emusoda
Member#: 211869
2006 STI
Check your pads. A metal on metal grinding noise from the brakes usually means you need to replace them
emusoda is offline   Reply With Quote
Old 04-22-2013, 01:41 PM   #3
CBC_North
Member#: 338523
If this was the case wouldn't the sound stick around constantly and not go away after pumping the brakes a few times?
Old 04-22-2013, 01:58 PM   #4
GT11
Member#: 128002
0000 four door sedan
Poop color
It's because there is a very light layer of rust on your rotors when you park it for a while and the pads are scrubbing the rust away during the first few brake applications. It's completely normal.
GT11 is offline   Reply With Quote
Old 04-22-2013, 10:27 PM   #5
its byron
Member#: 345847
2004 WRX STI
WRB- 20PSI on 93oct
I have this same issue, and my buddies were telling me my rotors were shot and my pads were gone, but ive had the car for just over a month and the dealership said my pads were fine. seeing as my friends arent mechanics i thought the same thing GT11 just said.
its byron is offline   Reply With Quote
Old 04-22-2013, 10:35 PM   #6
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Yeah, I get the same thing except I don't really have a grinding sound but more of a rubbing/whirring sound. It also gives my pads a few brief seconds of really high bite before the rust is rubbed off. (hehe rubbed off)
chazly413 is offline   Reply With Quote
Old 04-23-2013, 12:30 AM   #7
Ikkitousen
Member#: 354304
Ya I believe it is normal...happens after a car wash every time.
Ikkitousen is offline   Reply With Quote
Old 04-24-2013, 05:57 PM   #8
bootystank
Member#: 354475
2011 WRX Hatch
Satin white pearl
My Hawk HPS pads grind pretty bad after my car has been parked all night but it goes away after a few feet of pumping the breaks. There also fairly noisey in general.
bootystank is offline   Reply With Quote
