Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 04-19-2013, 05:44 PM   #1
Armyofcase
Member#: 281396
2009 WRX Sedan
Default 08+ Subaru WRX Clutch Issues
Hello Ladies and Gentlemen. I'm the proud owner of a 2009 WRX Sedan and unfortunately, I've come to experience the issues of a faulty firewall (or more importantly the faulty welds) and the cracking associated with the Clutch and Brake master cylinders.
After doing some research, I've found that there have been so many complaints to SOA and to that, so many of the claims have been denied. With that being said, I have asked a class action lawyer to look into this and it seems we have a very good chance that we may have a case.
I would like to see how many people on NASIOC have experienced this issue, whether it was fixed by the dealership, fixed by yourself, or it is currently not fixed. Also, I need to know if anyone has had any further issues or possibly an accident resulting from this. I know that in our Knoxville, TN community I personally know of five other WRX's that have all experienced the same weld breaks and issues.
Greg Coleman Law has asked that we gather any and all information to see if there is something that can be done on our behalf. By no means am I looking to seek monetary gain but I am only seeking for SOA to own up to the issue and fix it through a mass recall.
Please let me know if you have had or currently have an issue with this immediately as we begin to try to build a case. Thank you in advance for your help and hopefully, we can get this fixed for everyone that has experienced it.
We especially need to know if anyone in New Jersey, New York or California has had these issues. Thank you again for your help!!!
Armyofcase is offline   Reply With Quote
Old 04-20-2013, 10:30 AM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
I just had the throwout bearing replaced on my '12 WRX at 17K miles. Clutch pedal still clicks and sqeaks, need to stick my head under there, but at least the bearing noise is gone, and so is much of the binding up. This was a problem on my '11 WRX racecar as well, looks like a QC issue with SOA as common as it is. Spot-weld and be done with it.
JamesWilson2 is offline   Reply With Quote
Old 04-20-2013, 11:10 AM   #3
garudatwo
Member#: 322385
Throwout bearing replacement at 4k in NY.
garudatwo is offline   Reply With Quote
Old 04-20-2013, 11:19 AM   #4
liner
Member#: 303231
2008 WRX
Dark Metallic Grey
bought my 08 wrx hatch with 23k cert preowned.
tob replacled at 25k
tob replaced, pressure plate replaced and everything greased @ 30k
clutch still squeeks(tob) occasionally, brake moves about an inch to the left when clutch is depressed from about 35k to current 56k.
Dealer said theres no issue.
Also took it to the family mechanic, who doesnt work on subarus, but he said it just has a VERY stiff clutch, like a sports car. My clutch also vibrates once in a while.
I was told not to worry about it. If anythign goes wrong, the dealers getting a new one ripped, as I have been very persistent if this was an issue.
But well see. No other complaints about the car though
EDIT: Im on an oem clutch. As far as I know they did work on the entire clutch assembly and replaced the clutch \ at 22k before I bought it.
liner is offline   Reply With Quote
Old 04-20-2013, 02:17 PM   #5
Hwaang
Member#: 169271
2008 wrx
white
clutch squeak/creak came at 25k, dealership replaced clutch pedal assembly.
now at 80k and the clutch squeak/creak is back with a vengeance and dealership won't address issue.
Hwaang is offline   Reply With Quote
Old 04-20-2013, 02:23 PM   #6
Crobb707
Member#: 324229
2008 Wrx
Dark grey
Your welds are shot... The OEM clutch is not stiff at all. My welds broke clutch became squeaky and stiff. Long ordeal but finally paid for clutch in order for dealership to reweld firewall. Squeak and stiffness went away instantly
Crobb707 is offline   Reply With Quote
Old 04-20-2013, 02:39 PM   #7
Zulu-
Member#: 232213
Exactly! My dealer refuses to acknowledge this, blames the stiffness and creaking on a "worn clutch." It's been worn out for 40K miles I guess.
They said they would weld the firewall "for free" and install a new clutch assembly, not because something was wrong but because I was complaining. But, only if I paid the $1K+ for PP, flywheel, clutch etc.
Their tech also told me there were no cracks in the firewall even though I've confirmed it myself. When I get a moment in the garage, I plan to remove the cowl again and take photographs and go on to complain vehemently to SOA. See where that gets me.
Been dealing with this for a long time now, really sucks since past 3-6 months my clutch slips under more than a few pounds of boost in all gears. Don't want to throw in my aftermarket equipment yet and jeopardize this situation.
Zulu- is offline   Reply With Quote
Old 04-20-2013, 02:48 PM   #8
Kinjirra
Member#: 258345
2009 Xterra
Had the same issue with my 08+ to the point where it was like doing leg lifts to push the clutch in.
Had it checked right before warranty expired at 60k and was told it just needed to be greased and I had an aftermarket clutch installed that explained the stiffness(tech have xray eyes apperently as they never dropped my trans). Traded it in for a 13, clutch is like butter compared to that.
Kinjirra is offline   Reply With Quote
Old 04-21-2013, 05:22 AM   #9
Crobb707
Member#: 324229
2008 Wrx
Dark grey
I dealt with this for 6 months or so first rolled in stage 2 with suspension goodies they said I must have aftermarket clutch based on how stiff my clutch was. I called SOA and told them no way.
Basically long story short had to get a clutch job with dealership (1800) new flywheel too and they verified I had OEM clutch and couldn't have caused my welds to go bad. If I had aftermarket clutch I would have had to pay for welds out of pocket.
The dealerships and Subaru tried to make it difficult as possible but didn't help I was rolling stage 2 with bigger tmic and headers by the end. The fact is these welds are a manufactures defect and shouldn't even need a warranty. I would fight strong and get ready to maybe pay for new clutch
Old 04-21-2013, 12:40 PM   #10
liner
Member#: 303231
2008 WRX
Dark Metallic Grey
What seems to be the protocol for getting SOA or a dealer(bought at subaru of nashua) for getting this taken care of. Im in the proccess of gathering reference numbers and info for the dealer.
Any advice?
The car is stage 1 TP tune with Cobb SF intake. Never had issues with this dealer regarding these mods fwiw
Old 04-22-2013, 12:58 PM   #11
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
tmburke is offline   Reply With Quote
Old 04-22-2013, 01:51 PM   #12
NoGraffix
Member#: 276209
I am Rub
Function>Form
I've had the issue since about 20k miles. Started off as a creaking noise that has recently turned into a clicking noise. If I pop the hood and have someone press the clutch in I can see where the firewall flexes. I've never tried to address this at the dealer since I do have an aftermarket clutch and flywheel.
My plan is to drill through the firewall and pedal assembly and simply bolt the assembly to the firewall in a few places. This seems like it will be easier then welding it and hopefully will not require me to remove the entire dash.
NoGraffix is offline   Reply With Quote
Old 04-22-2013, 03:16 PM   #13
colby1321
Member#: 267408
08 WRX Sedan
VF 52'd Satin White Pearl
Ive had this issue with my 08 and they said they would not fix it and I need to get the welds fixed myself. It still is not fixed and the pedal assembly is held in place by a zip tie so it cannot flex off to the side anymore, stopped the sound for now. Keep me posted on how this mass recall goes. They should own up to their problem and fix it, not me. I bought mine from Atlantic Subaru in Bourne, MA
colby1321 is offline   Reply With Quote
Old 04-22-2013, 06:01 PM   #14
Armyofcase
Member#: 281396
2009 WRX Sedan
Please call Greg Coleman at 1-800-Hurt-Now and tell them that you heard about the suit. I spoke with the legal team today and the ball is rolling!
Old 04-22-2013, 06:38 PM   #15
Armyofcase
Member#: 281396
2009 WRX Sedan
Can I have the guys at Greg Coleman get in touch with you? PM me your number if you don't mind. We need someone in California that has had this issue and sounds like you're the man! Thanks!
Old 04-22-2013, 06:50 PM   #16
Armyofcase
Member#: 281396
2009 WRX Sedan
Hey guys! We're moving forward with the Class Action. if you have a minute to voice your opinion and help move this thing towards a massive recall, please call 1-800-Hurt-Now. Thank you in advance and i'm excited to try to get this all sorted out and fixed!
Old 04-22-2013, 07:43 PM   #17
dave07
Member#: 291349
2013 Mustang GT
It absolutely boggles my mind that Subaru can produce a car with a faulty clutch design. How long have they been designing manuals?
dave07 is offline   Reply With Quote
Old 04-22-2013, 08:35 PM   #18
Kinjirra
Member#: 258345
2009 Xterra
Originally Posted by Armyofcase View Post
Please call Greg Coleman at 1-866-Hurt-Now and tell them that you heard about the suit. I spoke with the legal team today and the ball is rolling!
Just a heads up, I know for a fact many dealerships and I wouldnt be surprised that SOA as well monitors this site on a regular basis. I wouldnt put anything related to said case on the forums besides general contact info for the lawyers.
That being said put the info up at 3gwrx.com and any of the other subaru sites. I know lots and lots of people have had issues with this problem.
Old 04-23-2013, 09:55 AM   #19
Armyofcase
Member#: 281396
2009 WRX Sedan
I agree completely! Please let me know everyone that has had this claim!
Old 04-23-2013, 09:57 AM   #20
stanrc
Member#: 266177
2006 MX-5
RED
My clutch just started squeaking last week at 36k miles. I havne't had time to check if the firewall is flexing or not but the sound definately doesn't seem to be coming from under the dash.
stanrc is offline   Reply With Quote
Old 04-24-2013, 11:22 AM   #21
Armyofcase
Member#: 281396
2009 WRX Sedan
It may sound like it's not coming from under the dash but definitely check it out. Also, have someone press the clutch in and watch the master cylinder inside the engine bay to see if it's moving...
Old 04-24-2013, 12:25 PM   #22
stanrc
Member#: 266177
2006 MX-5
RED
Yeah, I had someone do that but of course thats when it decided not to make noise. I put some wd40 on some of the linkage in the pedal just in case.
Old 04-24-2013, 02:25 PM   #23
davidboies
Member#: 304390
I have a 2009 wrx sedan with 113,000 miles on it. It's had a squeaky clutch for as long as I can remember. I didn't think anything about it until I started having trouble putting the car in reverse and 1st, and the brake pedal would move over with the clutch when I presse in the clutch. Took it to the dealer and they adjusted the clutch. It helped for a little while, but then it went right back to what it was doing before. Took it to subaru and they said its a cracked firewall and they wont/cant fix it. Same thing with the dealer i got it from. They all say they need to send it to a dfferent shop. Car wont start since the clutch wont go all the way in, so its sitting in the driveway. I bought a warranty thats supposed to cover all "non-wear" items , but it doesn't look like theyre going to cover this. Im iust going to fix it myself I guess. Ive contacted SOA about this. Ive loved this car until this happened, now im not so sure how much I trust subaru.
davidboies is offline   Reply With Quote
Old 04-24-2013, 10:38 PM   #24
Armyofcase
Member#: 281396
2009 WRX Sedan
Would you mind giving Dawn a call at Greg Coleman's office? Dawn is his legal assistant and is taking all the calls concerning this. His phone number is 865-247-0080. This is definitely why I'm doing this...
Where are you located at? Guys/Gals....if anyone else is having this very same issue...factory clutch or aftermarket clutch...fixed previously or not...please call Greg Coleman Law today. It will only take 10 minutes or less...I Promise it will help everyone out in the long run! Thanks!
Old 04-24-2013, 11:32 PM   #25
Subiezilla
Member#: 280543
So putting some lube on the linkage fixed the issue for you?
Subiezilla is offline   Reply With Quote
