Old 04-22-2013, 05:56 PM   #1
Bluesnowgt
Member#: 349005
Default 03 wagon clutch reccomendation
I have an 03 wagon with a 2.5 hybrid. I'm making 300whp and 325wtq. I HATE the spec clutch the last owner put in. I'm trying to find a clutch that will hold the tq and I could also street use. It's my daily. One of my buddies said not to get a clutch with Kevlar due to glossing over. Any recommendations on brand and stage? Thanks in advance.
Bluesnowgt is offline   Reply With Quote
Old 04-22-2013, 06:21 PM   #2
hoffmanEstates
Member#: 122043
04 wagonier
psm
Stock, oem
hoffmanEstates is offline   Reply With Quote
Old 04-23-2013, 07:51 AM   #3
Bluesnowgt
Member#: 349005
What is the advantage of going to a stock one that isn't designed to hold the torque?
Old 04-23-2013, 08:08 AM   #4
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
I have an act street/strip is an organic clutch and probably a stage 2. Have 354 ft/lbs - 280hp in my 03 bugeye, and a 6spd so Sti flywheel and clutch (a little bit bigger than oem wrx). happy with it.
Old 04-23-2013, 10:43 AM   #5
Bluesnowgt
Member#: 349005
Will the STI clutch bolt up and fit just fine with 03 trans?
Old 04-23-2013, 09:45 PM   #6
mhoerath
Member#: 131379
justablue hatch
wrx and Sti flywheels are different.
Your clutch size should match the flywheel.
wrx clutches are less expensive.
I had a wrx clutch and flywheel in my 6 spd, used because I had a new clutch to use when the 6 spd was installed. After that clutch went bought an Sti clutch and swapped in my Sti flywheel.
Can a Sti flywheel and clutch be used in a wrx 5 spd? answered here:
http://forums.nasioc.com/forums/show....php?t=1507759
Old 04-23-2013, 10:03 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
A sprung organic disc is easier to drive than the other materials.
Higher than stock rated there are several options, but people have had good luck with the Exedy, ACT street disc and any of the Southbend "Daily" clutches.
You can see the FAQ for a list of torque ratings for the various clutches. Unsure if Unabomber has the Southbend clutches on there, Southbend has ratings on their site.
I have a Southbend Stage 3 daily and engagement was initially jarring, but once broken in the pedal is a little stiffer than stock, but otherwise engagement is smooth. The ACT is similar. I haven't driven an uprated Exedy organic, but I'd expect the same. The cerametallic and kevlar clutches have a harsher engagement that make them better for some motorsport usage, but more difficult to daily drive. For what you've explained, you want a sprung organic clutch, which is probably what your transmission wants you to have too =)... since it transmits a bit less shock by giving some slip on engagement.
