Old 04-21-2013, 01:49 PM   #1
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Default quick brembo question on wrx
I plan on swapping 04 STI brembos on my 04 WRX (JUST the fronts).
I've done it before, but I was wondering, do I actually need Stainless steel lines or have to use the STI brake lines? OR will the WRX ones work?
I know ill need
2 calipers
2 5x100 sti rotors
4 sti mounting bolts
sorry, i tried to search, and i didnt see anywhere that said i NEEDED to use braided lines. IF i can use the WRX brake lines, id much rather do that.
Jubert39 is offline   Reply With Quote
Old 04-21-2013, 01:54 PM   #2
sc00by4life
Member#: 97135
I know ill need
2 calipers
2 5x100 sti rotors
They are all the same.
But why woul you upgrade the front only? Too cheap? That severely ****s your bias.
Old 04-21-2013, 02:12 PM   #3
prescottn6ft7
Member#: 268918
2002 WRX Wagon
^agreed, at least get the 06-07 2pots in the rear.
prescottn6ft7 is offline   Reply With Quote
Old 04-21-2013, 03:54 PM   #4
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
You will want to at least upgrade to an sti master cylinder. Otherwise you will likely not be happy with the braking. it makes some difference but not add much as ansti bb. An sti bb will give you much firmer brake feel.
faSTI666 is offline   Reply With Quote
Old 04-21-2013, 05:37 PM   #5
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
is this true? cus i heard it really doesnt make a difference. REad it somewhere here.
http://forums.nasioc.com/forums/show....php?t=1800734
I did have an 02 RS that swapped brembo brakes on and it was fine (but i also did SS lines).
so just get a break booster (sti) and keep the WRX brake lines?
Old 04-22-2013, 03:03 AM   #6
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
The sti mc is a little larger. Its not necessaty but preferred.
Old 04-22-2013, 05:18 PM   #7
sc00by4life
Member#: 97135
Yeah, brake bias doesn't mean anything.
Anyone saying that shouldn't be giving out advice.
Old 04-22-2013, 07:02 PM   #8
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Thank you!
Old 04-22-2013, 08:08 PM   #9
SW21MR2
Member#: 60135
2005 Kona Stink-E
Just do the rears too if you can afford it. It looks better. hahaha
SW21MR2 is offline   Reply With Quote
Old 04-22-2013, 08:16 PM   #10
Novtec1
Member#: 13641
13 Shelby GT500
03 SY WRX (DAILY)
been running my 03 wrx with front brembos for like 4 years with no STI mc... not ONE issue!!!! just put in some really good fluid and lines...
Novtec1 is offline   Reply With Quote
Old 04-22-2013, 09:04 PM   #11
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
so if i went with just the calipers and rotors, and stock lines everything, it cant be any WORSE than the stock setup, correct?
Old 04-22-2013, 09:31 PM   #12
sc00by4life
Member#: 97135
yes....you'll be pretty front biased, causing the front to dive more than it should during braking, more initial understeer when braking into corners, etc.
if you can't do the rears, at LEAST do the h6 rear upgrade.
Old 04-22-2013, 09:59 PM   #13
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
So no disrespect, but unless im not understanding, even stoptech (reputable) says that it isnt necessary to do the rears UNLESS i have thermal concerns (i assume he means track use).
When u see big break kits, u usually see them fro the fronts, not for both.
Old 04-23-2013, 12:37 AM   #14
sc00by4life
Member#: 97135
"No disrespect" but different kits have different requirements. Saying one manufacturer states xx doesn't mean anything against a different manufacturer. Not to mention stoptech makes a variety of kits, including "small" kits that retain close to stock rotor dimensions.
Brake bias is a very real thing. If you don't understand how bias effects your car, why are you even considering purchasing anything?
Not to mention the only reason you'd even NEED to upgrade the wrx brakes is if you are having "thermal concerns". You won't see much of a difference in stopping distances, even less so in a street driven car.
You apparently have a lot to learn about braking systems.
Incorrect.
Old 04-23-2013, 01:11 AM   #15
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
why do you want brembos in the first place??
brew02wrx is offline   Reply With Quote
Old 04-23-2013, 01:20 AM   #16
paulpat
Member#: 237145
02 WRX
12 FXT
Brembos with the h6 are ok and good. Slightly more front bias than stock but just front brembos makes it really front bias. You will notice the front dive more and this overloads the front tires and then kicks in the ABS because either the front or back .... I forgot. The point is from the factory you are already really front bias. You might feel the front dive and think "oh they are working better " but really ur front is just giving you an illusion.
I suggest getting the h6.
paulpat is offline   Reply With Quote
Old 04-23-2013, 07:08 PM   #17
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Getting h6 will really make the difference? Isnt braking based on tire grip? And the rears ony do like 15% of the braking.
Im not being cheap, just curious. If its really a difference maker, ill just get the brembo rears and the adapter kit
Old 04-23-2013, 08:18 PM   #18
Grimoire
Member#: 181331
2012 STI
More like 25% to 35%, depending on the car.
The *limit* of braking depends on the tire grip, but how you reach that limit matters. If your front brakes are grabbing too much relative to the back, they will reach that limit much sooner than the back tires. Your rear tires will not be an effective part of your braking system.
A good article on the importance of good brake bias (or the problems with a bad bias): http://stoptech.com/technical-suppor...alance-matters
Grimoire is offline   Reply With Quote
Old 04-23-2013, 11:26 PM   #19
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Incorrect.
its for looks, looks only. i dont care about performance. if itll hurt the car i wont do it, if it will at least be no worse than stock, then ill put it on, cus it looks so much cooler.
i dont track the car, i just show it off while going to the grocery store.
Old 04-23-2013, 11:46 PM   #20
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
PPG's,Polka pickled,ewg
At least the man is honest! If looks is all you expect from this upgrade then go for it! You will not hurt anything and if your not tracking the car you will not notice the change in bias unless you make it a point to regularly threshold brake on the streets to the point of making the nose dive and abs engage! If you are driving like that on the street, you're doing it wrong! Wrx brake lines should work and ss lines are not necessary at this point, though I would suggest for piece of mind!
02-05 wrx use the same 1 1/16" master cylinder as the Sti! That Said, if you have an 02-05 wrx you will gain nothing from swapping to an STI master cylinder!
The sti brake booster however, is where you gain the last little bit of that " firmer" pedal from the full swap!
06-07 Wrx they reverted back to a 1" master cylinder with the 4/2pots..why Fhi did this, I do not know! This would be beneficial to swap to a 1 1/16" mc for these model years! (this is what I did ;swapped to the STI mc and bb)
From personal experience the front brembos paired with rear 2 pots is no better..I ran this set up on the track and the nose dive was horrible..literally lifting the back wheels under hard braking. Way too much front bite! I am certain that brembos should be done as a full swap if your car does see track! for the street though..don't even sweat it! Best of luck!
blazzin06wrxdude is offline   Reply With Quote
Old 04-23-2013, 11:57 PM   #21
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
The stock sti rears are 2 pots and it was no better? So does the stock sti already have this issue then?
Btw thanks for the reply, Explained everything, i appreciate it.
I just feel like sometimes ppl here are way to technical like they are track experts. I was just wondering if itll hurt the car that much on a DD. Im generalizing, but i bet the majority here do a lot of thinks more for bling than for performance. Dont tell me u put an sti wing for more downforce on your DD. dont tell me u got a big break kit for ur DD, or even stretched tires and ur bbk. I just want a clean look and i got brembos at an incredible price which is why i made this thread.
Old 04-24-2013, 12:00 AM   #22
ronnyyun
Member#: 354403
ronnyyun is offline   Reply With Quote
Old 04-24-2013, 12:04 AM   #23
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
No problem man! Enjoy your car and do what makes you happy! Just to re emphasis though..if this is just for a car primarily driven on the street you will notice no negative impact from the swap and drivability for 99.9% of all your normal day to day driving duties will remain the same! The only downside is more expensive pads and rotors! I should have been more clear! At the time I was running the 2 pot rears that came on my 06 Wrx! After experiencing a shift in brake bias for the worse, after doing just front brembos on an 06 wrx, I decided to go ahead and upgrade the rears to the brembo 2 pots ( more brake torque and larger diameter rotor) with a conversion rotor from Dba that allowed me to maintain the wrx parking brake. Since I have an 06 Wrx and now brembos fr and rear I also opted to do the STI mc and brake booster! My car see's some pretty hard weekends at the track! This is totally not needed in your application though! Get those brembo's on and enjoy! Remember..bleeders up!
Old 04-24-2013, 02:52 AM   #24
sc00by4life
Member#: 97135
it is definitely noticeable on the street under any sort of moderate to hard braking occurrence. And that isn't as unlikely or uncommon as you think.
the difference between the 06-07 2 pot rears and the 02-05 sliding calipers is significant....which is most likely clouding your advice.
I love it when these guys come in and state things like this are only factors under "threshold braking" and what not. That is absolutely untrue.
if you're doing it for looks, who cares what I say. do it. if you don't pay attention to how your car behaves in the first place, you most likely wont notice any difference.
Old 04-24-2013, 12:57 PM   #25
Grimoire
Member#: 181331
2012 STI
In that case, these might be more what you are looking for:
