Old 12-26-2008, 03:25 PM   #1
lightgod86
Member#: 197343
2009 WRX Premium
WR Blue
Default '08-'09 WRX Auto Dimming mirror /w compass install
I know this is a super easy mod, but I figured since I was gonna do it, I might as wall write up a quick walk though as if the subaru directions were not easy enough!
Step 1: Buy the Mirror! This is a HAVE TO on all modern cars! Every vehicle should have one as the provide much better night visibility out of the rear.
Here is the box with the part #. I chose to go without the home-link as i would not use it:
Ok so here is your current situation with the old mirror:
EW GROSS!
To remove the old mirror all you have to do is grab the base of the mount and twist to the left. It spins 90 degrees and then you slide down to remove.
Ok so here is the mount on the window and the new spring clip they give you (identical to the old one).
BEFORE YOU REMOVE ANY PANELS IN YOUR CAR, OR UNPLUG/PLUGIN ANY CABLES PLEASE REMOVE THE NEGATIVE TERMINAL FROM YOUR BATTERY JUST TO BE SAFE! Thanks =)
Now to get to the cable, just stick a flat blade screw driver into the slots below, and give them a little pry till you hear a pop and the lens cover lifts.
Behind that there is 2 screws (phillips) that need to be removed, at which point the whole unit can come be gently pulled down:
Just plug in the provided cable into the white connector (shown below) till you hear a click then route the cable though the small area in the headline in the center-top of the windshield.
Once thats done all you need to do is attach the new mirror to the mount the same way you took the old one off (in reverse), snap the cable into the back and then use the handy dandy extendable mirror cable cover to hide the cable and voilą!
Read your manual for calibration instructions of the compass, doesnt take more than a few minutes.
Over all, I rate this install as easy-beginner and for those of you who who have the old school mirror i suggest you upgrade NOW!
Feel free to PM me or leave a comment if you need any help.
lightgod86 is offline   Reply With Quote
Old 01-06-2012, 12:14 PM   #2
96max2fast
Member#: 252910
Do these same steps apply for an 07 sti??? I am really afraid of breaking the mirror that I am removing... I want to get an autodim compass one... No homelink.
96max2fast is offline   Reply With Quote
Old 11-12-2012, 07:03 PM   #3
s1eepR
Member#: 335330
2008 Impreza 5DR
Revival to say THANKS!
s1eepR is offline   Reply With Quote
Old 03-18-2013, 01:45 PM   #4
Marbucks
Member#: 348659
2011 STI
Just used your tutorial to install the auto dim on my 11STI. Great write up. Thanks
Marbucks is offline   Reply With Quote
Old 04-23-2013, 12:53 PM   #5
Freeriderchad108
Member#: 334394
Default Homelink
Will this guide work on a homelink mirror as well? I just picked up a 2013 WRX and wanted to install one.
Freeriderchad108 is offline   Reply With Quote
Old 04-23-2013, 01:42 PM   #6
themaus
Member#: 321211
Yes it will
themaus is offline   Reply With Quote
Old 08-22-2013, 11:02 PM   #7
Cheveyboy
Member#: 34773
2013 WRX STi
Nevermind.
Cheveyboy is offline   Reply With Quote
Old 08-23-2013, 10:16 AM   #8
96max2fast
Member#: 252910
Default Regular Mirror
Originally Posted by Cheveyboy View Post
Nevermind.
I have an 07 STi and can sell you the mirror for 25 bucks. let me know.
Auto Dimming Mirror w/ compass install? yo14jman Newbies & FAQs 0 10-17-2009 10:55 AM
installation auto dimming mirror and compass subaru222 Interior & Exterior Modification 8 12-14-2008 07:52 PM
WTT: My Auto dim mirror with compass plus cash for your Homelink Auto Dim mirror. ScoobyNubieToo! Private 'Wanted' Classifieds 3 06-29-2008 10:39 PM
Mirror or Auto Dimming Mirror w/compass tunedmotors Private 'Wanted' Classifieds 1 07-24-2007 09:54 PM
WTB: 02 WRX Clock and Auto-dimming mirror w/ compass chuckywang Private 'Wanted' Classifieds 3 11-28-2006 04:44 AM
