Old 04-22-2013, 07:36 PM   #1
shano
Member#: 223839
2004 WRX
Java black
Default 2004 WRX, PE1818 w/open source tune
This is my 2004 USDM WRX imported to Canada. 2.0l stock block w/117k miles.
Engine:
Pe1818 turbo (basically a VF34 with a ball bearing CHRA from an 18g(?))
550cc injectors
walbro 255
GMS inlet
samco intercooler hoses
cobb post maf
one step colder plugs
HKS downpipe
Grimmspeed uppipe
Borla Hush
K&N PANEL filter lol
stock BCS
stock intercooler
Tranny:
Kartboy short shifter
exedy stage 1 clutch
subaru oem oil
Suspension:
STi springs
17x7 5Zigen heidfelds on falken 452s
ebay slotted brakes
Everything else: Alpine touchscreen w/ type-s speakers, reflect-a-gold on the intercooler, some weight removal ~50pds or so...
3rd gear run on airboy spreadsheet with a the correct "parameters"
RESULTS:
P.S anyone know why the boost goes flat then peaks
shano is offline   Reply With Quote
Old 04-22-2013, 08:02 PM   #2
BroBroBroBroBro
Member#: 338211
2011 wrx
never seen the boost go like that how the heck does it hold out?
BroBroBroBroBro is offline   Reply With Quote
Old 04-22-2013, 08:34 PM   #3
TXSoobieNoobie
Member#: 345103
2004 WRX Limited
Black/Black
Good info. I was just looking at this turbo. I think an EBCS would help you as would a STI intercooler. Both are upgrades I got cheap, though Im just running an STI uppipe and stock inlet.
TXSoobieNoobie is offline   Reply With Quote
Old 04-22-2013, 09:07 PM   #4
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
your after maf hose is about to fall off!!!!!!!!!!!!!!!!!
BONFIRE074 is offline   Reply With Quote
Old 04-22-2013, 09:37 PM   #5
shano
Member#: 223839
2004 WRX
Java black
Yeah I was able to get it on slightly more but the inlet and aftamaf didnt want to meet up correctly.
I think if I would get a big topmount/ebcs/sf intake it would improve spool bigtime.
Old 04-22-2013, 09:47 PM   #6
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Beautiful curves.
Old 04-23-2013, 02:33 PM   #7
drwrx
Member#: 50891
Originally Posted by shano View Post
Pe1818 turbo (basically a VF22 with a ball bearing CHRA)
Actually the PE 1818 uses the p18 housing in vf30 / vf34 / vf39, etc.
The PE1820 uses the vf22's larger p20 housing.
While difficult to verify, I suspect the internals are a MHI 18G.
drwrx is offline   Reply With Quote
Old 04-24-2013, 04:37 PM   #8
shano
Member#: 223839
2004 WRX
Java black
That makes sence! I've been trying to dig info on this turbo for awhile and I knew people kept referring to VF34/VF22... now I know why. I'm almost starting to think that its a 1820 because of the late spool lol.
