Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 05-18-2010, 05:46 PM   #51
Member#: 96204
2013 STI GR
Originally Posted by Equilibrium Tuning View Post
Even if the wastegate spring is 15psi, a boost controller will get you to that 15psi significantly faster than just the wastegate on its own. Wastegates open progressively, so as you hit 5psi, it opens a bit, 10psi, it opens more, 15psi, it opens more and stabilizes boost. With a good boost controller, the wastegate doesn't see any boost until it gets very close to its target. This allows the wastegate to stay closed much longer and greatly improves spoolup.
-- Ed
I will give you the progressive part, but the 6 Waste gates that I have played with were not quite as progressive as you say.
My 15 psi IWG would start to open at about 13 psi (depending on pre-load).
My 1.0 bar (q14.7 psi) Tial EWG starts to open pretty close to 12 or 13 as well.
This is verified by a hand-held boost pump, and logging.
If there was 0 pre-load on the spring, then yes I agree, but that is not the case.
LittleBlueGT is offline   Reply With Quote
Old 04-23-2013, 07:23 PM   #52
Member#: 218648
2009 WRX
Spark Silver
Old school thread redux- great for putting a visual on the gains for the 10cm housing... looks like it would be very happy with an 8000rpm redline.
Vanderkitten is offline   Reply With Quote
FS/FT: feeler Blouch Dom 3 Turbo 8cm - BRAND NEW $1300 shipped Sato_unit Engine/Power/Exhaust 5 03-11-2010 03:38 PM
f/s:va: Blouch DOM 3 2.4inlet 8cm zero miles** sold sold** moorebl MAIC Private Classifieds 2 01-11-2010 09:00 PM
f/s:va: Blouch DOM 3 2.4inlet 8cm zero miles** SOLD SOLD SOLD** moorebl Engine/Power/Exhaust 2 01-11-2010 05:35 PM
FS (DFW): Blouch Dom 3 Essentially New (3inch/8cm/EWG) 75 DOLLAR FINDERS FEE TOO! fatcircles TXIC Private Classifieds 53 12-12-2009 02:17 AM
FS: Like New Blouch Dom 3 Turbo (3inch inlet/8cm exhaust/EWG Only) fatcircles Engine/Power/Exhaust 39 12-12-2009 02:16 AM
