Old 04-07-2013, 09:56 PM   #601
reid-o
Member#: 103631
2004 STI
If you've already purchased it, then nevermind, but I made a heatsink out copper sheet (for roofing) and cut it using tin snips and drilled a hole in the center. It's a lot cheaper but ghetto. I can see from your build you do it right. LOL Let me know if you find out good settings for the launch control.
Old 04-07-2013, 10:08 PM   #602
Layvon
Member#: 195711
STi 04/05/06/07
Well i do some things right, and other things im pissed i did the way i did. This is what thia summer will correct.
In fact Reid - that is the way Bosch recommends to do it on the sensor specifications. As you know copper dissipates heat far better than SS. ... i went out and looked again. Its almost dead nuts perfect at 3 o'clock (parallel to ground) so I'm guessing that is a big factor because if water gets into sensor its not getting out till it's boiled out
As for the settings for launch control, Junior set me up today, if he chimes in ill let him spill the computer settings but i was at 2psi today, but i think i will pull a little more timing and see what that gets me. It kinda pooped out a little on the three launches i did that i think went well.
Im nearly out of tables and i think FFS will fill the final slot. Kelly - does yours have more than 12 table slots? Im guessing Antons is the same
Old 04-24-2013, 12:16 PM   #603
Layvon
Member#: 195711
STi 04/05/06/07
Oops!!! Took apart a buddies motor thus weekend. He said when it died, it died.
one rod had beaten so much stuff that it looked worse than those rods from the west coast Tuning fiasco.
Old 04-26-2013, 08:38 PM   #604
Layvon
Member#: 195711
STi 04/05/06/07
Finally ---
Brian at iWire got me headlight plugs and levelers from an 06 STi harness he had merged. $20 shipped. Doesnt get any better!
Old 04-27-2013, 09:07 AM   #605
Layvon
Member#: 195711
STi 04/05/06/07
If it was easy, everyone would be doing it. Final conundrum of the swap. I think it should still work, just running the 4 position wires from the 04 to the single of the 06. As long as the resistances inside the position switch are the same, should be no problem. If it is, a 06 switch would be an easy swap.
Old 04-27-2013, 11:24 AM   #606
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Track!!
Old 04-27-2013, 10:41 PM   #607
Layvon
Member#: 195711
STi 04/05/06/07
Track indeed. Once we get this launch control situation figured out I'm excited to go back.
Richard showed me the advantages of brake boosting today. Car is fricking loving the warm weather. No boost cut issues and scoots right along
Old 04-28-2013, 09:27 AM   #608
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Keep me in the loop!
I've got to work next Weekend in Cinci but should have some time after that.
Old 04-28-2013, 02:38 PM   #609
Layvon
Member#: 195711
STi 04/05/06/07
You should come to Kaleva sometime .... Hill billies deluxe but there were only 30 cars there yesterday.
Only 40 min for me, prolly hour and fifteen for you.
Old 05-09-2013, 10:56 PM   #610
Layvon
Member#: 195711
STi 04/05/06/07
E85 tune scheduled for the 17th of June.
Gotta do some small things before then.
Oil change
Boost leak test
Check / change plugs
Grab some corn fuel and migrate south to visit the P & L crew and Junior.
Tinker with knock control some more. I still dont like how its working. Working 5 14hr days has taken its toll on my motivation level when i finally get home Friday
Old 05-09-2013, 11:01 PM   #611
manitou
Member#: 193757
2006 XTI Limited
Oil change
Boost leak test
Oh yeah! That should be fun and productive!!
Old 05-09-2013, 11:17 PM   #612
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Oil change
Boost leak test
Haha.. I saw Darius this past Wednesday for some upgrades and more tuning too.. Go to the track with him this weekend!
See ya in June!
Old 05-09-2013, 11:33 PM   #613
manitou
Member#: 193757
2006 XTI Limited
See ya in June!
Hmmm....Saturday?
Old 05-10-2013, 06:33 AM   #614
Layvon
Member#: 195711
STi 04/05/06/07
Yes and yes! Its supposed to rain tomorrow but hopefully it holds off
Old 05-10-2013, 08:40 AM   #615
manitou
Member#: 193757
2006 XTI Limited
Yeah, weather looks sketchy! Keep me posted if you're going. If my girlfriend is working tomorrow I may come and join you, weather dependent of course.
I'm in Carleton, MI right now and not quite 3 hours away from MMMP, so I don't want to make the drive if it's going to get rained out. I was kind of hoping to have my DSS stuff installed before track time!
Old 05-10-2013, 08:41 AM   #616
4Warned
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
RAIN
FYI Layvon, but your E85 from Meijer on 17 mile in Cedar Springs its like 94% ethanol
4Warned is offline   Reply With Quote
Old 05-10-2013, 09:31 AM   #617
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by 4Warned View Post
RAIN
True story! The Meijer's E85 I've tested was 82% at it's lowest with the winter blend. I just try to buy their E85 if I can.
Keep me posted on tomorrow guys! If you go, what time are you planning to get there?
Old 05-10-2013, 03:42 PM   #618
4Warned
Member#: 66092
2011 STi sedan
two thirty
Old 05-10-2013, 05:05 PM   #619
Layvon
Member#: 195711
STi 04/05/06/07
Ditto. Ill buy some from there on the way down!
Old 05-11-2013, 01:48 PM   #620
Layvon
Member#: 195711
STi 04/05/06/07
Track day weight, plus me @ 225 fully dressed.
Full tank of fuel
Full interior
No spare tire
Jack going in dumpster at the track
Battery full size but rear mounted
Aluminum DS
Stock wheels with 245/40 DWS (should grip well in this effing rain :rollseyes: )
Ironically enough the 04 STi from the factory has a 1893 and 1380 split.
3260+225 = 3485
Old 05-12-2013, 02:45 PM   #621
Layvon
Member#: 195711
STi 04/05/06/07
The cost of doing things right is astounding. Just to get Teflon fuel lines in the trunk to the exterior of the car was almost $400. That was with summit brand because i couldn't justify 600+ for Earl's. oh well.
I think I'm going to fabricate up a fuel cooler that mounts in hood scoop location because i Have the extra fittings and hose.
Old 05-12-2013, 03:24 PM   #622
manitou
Member#: 193757
2006 XTI Limited
Anything with teflon is pricey! Are you doing this because your current lines are not E85 compatible?
Old 05-12-2013, 03:35 PM   #623
Layvon
Member#: 195711
STi 04/05/06/07
They are E85 compatible however they are also permeable, and I'm tired of smelling gas in the cabin.
It's also going to allow me to change the way everything is ran; right now it is spread out way too far. The reason I did not change it before is because I was just trying to get it done in the way I had it worked. Now that I can afford ( both time and money) to get nitpicky I am. I want to get my fuel trace sitting up near the seats and parallel to the back rest, and get my y block after the pumps back up into the cabin.
I have already found one thing that I wish I would have purchased different though. No matter how many times I build it sitting there looking at it I always seem to be one or two fittings off. In this particular case I think a 45 would have worked better than a 90. Having said that at $20 a piece I cant afford to just swap them out.
Old 05-12-2013, 03:40 PM   #624
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Dann! Is that for premade lines or the line + fittings you assemble yourself?
P.S. I got the job
Old 05-12-2013, 03:53 PM   #625
manitou
Member#: 193757
2006 XTI Limited
P.S. I got the job
Congrats! Moving now?
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps wrx. NWIC Private Classifieds 0 11-13-2011 06:49 PM
FS : NJ: 2004 STI Race Build dsds711 Private Vehicle 'For Sale' Classifieds 22 03-19-2011 11:39 AM
2004 sti build questions GA_STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-09-2009 03:31 PM
2004 STI Parts from Racecar Build TxSpeed1 Complete Car Part-Out 36 03-21-2009 03:00 PM
