Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 03-29-2013, 12:28 AM   #26
Myth21
Member#: 246851
2007 UGM
2012 LR
Originally Posted by Jdub.csu View Post
Boost leak. Do you have a boost gauge
I have an AP, I took all my mods off and it's currently running COBB stg1+SF, I just logged it and apparently it barely hit 7psi @5000rpm
I'm gonna take it off tomorrow morning and get some T-bolts while I'm at it. I am very positive that I secure all the hoses down properly with the provided clamps.
Myth21 is offline   Reply With Quote
Old 03-29-2013, 09:29 AM   #27
Jdub.csu
Member#: 283784
2013 EVO X GSR
The provided clamps suck. No shops around here will tune if you don't have tbolts on boost tubes
Jdub.csu is offline   Reply With Quote
Old 04-04-2013, 01:24 AM   #28
Myth21
Member#: 246851
2007 UGM
2012 LR
My 2" doesn't even fit around the tube, luckily I ordered the whole set w extras. I noticed there are different sizes within the diameter too. That would explain y others are having problems fitting it
Old 04-08-2013, 03:04 PM   #29
inertius
Member#: 260989
2010 WRX 5dr
Thank you for this guide! I'm definitely saving this in case I decide to go beyond the Cobb stage 2 tune.
inertius is offline   Reply With Quote
Old 04-09-2013, 10:37 PM   #30
Myth21
Member#: 246851
2007 UGM
2012 LR
I used the stock clamp on the throttle flange because the flange itself have very little clearance and it has indentation for the width of the clamp. The rest I went with Tbolt. I'm a little worried about the throttle body because it was hard to get the tbolt to sit and face the opening. We'll c after my tune tomorrow.
Edit: wasn't happy with the throttle body tbolt because as it tightens it kinda turns and it got hard to tighten. Since that's the most problematic area I decided to take it all apart and did it with the provided clamp.
I was able to get it a lot more tighter wasn't banging on the metal fuel lines and possibly damaging it.
I also got lazy and didn't want to remove the supporting bracket so I just removed the bottom.bolt under the IC. It was PAIN IN THR ARSE to get it on. I got it in 1/4 of the way then realized it wasn't right. End up taking the bracket out to do it right, I almost stripped it but I was able to push it thru the top thread and screw it back in..
I hope my experience can help others because Ive taken it on and off about 4 times now, and it still gives me trouble lol :/
Old 04-12-2013, 02:26 AM   #31
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
does anyone know of a store or site where they sell the splitter seperately. i am hesitant to call RSD and ask if they would sell me one seperately cause they do for the other years but not the 08+ and not sure if there is anyone else that sells it and forsure not in the for sale section but i'm hoping someone can help me with this. :/
JAMM0N is offline   Reply With Quote
Old 04-12-2013, 02:05 PM   #32
Wrexflex
Member#: 326301
2012 WRX LR - Sold
2015 Forester Premium CBS
PW doesn't sell it sep., nor does anyone else for the 08+, I just tried. I have a PW core, and had to buy the rest of the kit from FMS. I ended up not even using the FMS splitter because when the hood shut it was putting a good deal of pressure on the IC. Luckily if you take the splitter out, the scoop's dimensions are basically that of the PW. I'm sure the PW splitter is more ideal, but it's still doing the job and is cold to the touch w/out one.
Wrexflex is offline   Reply With Quote
Old 04-13-2013, 11:15 PM   #33
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
which is total BS cause RSD has the older models in stock and i dont get why PW just sells the HS seperately if they are going to sell the new gens with it.
the thing about not having the splitter is that it doesn't get air directly onto the TMIC but throughout the car. i wish i could see if a shop or some vendor is willing to make one but who knows.
STI PW TMIC are always floating around but most STI's that i know of go FMIC but not many WRX PW float around, and a lot of those STI PW TMIC that float around usually dont have a hood splitter and its tough to find one.
Old 04-14-2013, 11:45 AM   #34
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
this is exactly why I passed on the few used PW intercoolers I found for 08+wrx and bought new. They'd be missing one key part and I had heard you can't buy them alone!
Rubbish.
SenorDucK is offline   Reply With Quote
Old 04-14-2013, 11:19 PM   #35
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
RSD sells the couplers and the gasket last time i checked. They just dont sell the splitter.
PW TMIC always float around but they never come with everything always something missing and the splitter is an important piece i dont get while seller's dont include it. it'd be pointless to sell it then and your left with a paperweight. i bought it without a splitter cause seller didn't have it but i'm not trying to go 350+ just 300+ so i should be fine for where i'm at and just my stock hood scoop
Old 04-18-2013, 07:01 PM   #36
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
does anyone know if i need the gasket for my BOV?
Old 04-18-2013, 08:03 PM   #37
SenorDucK
Member#: 327511
13' WRX 6 Speed
yes, process west doesn't supply one.
Old 04-18-2013, 08:23 PM   #38
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
that is ridonkolous what about the L bracket?
Old 04-18-2013, 08:54 PM   #39
SenorDucK
Member#: 327511
13' WRX 6 Speed
what about it? the driver's side bracket is extended with hardware provided by process west. basically flat bracket and a few bolts. is that what you mean?
Old 04-18-2013, 09:49 PM   #40
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
yeah thats what i'm talking about its probably just to get the TMIC to sit right. i hope i dont run into any problems. i got it today and the tmic is huge and heavy. couplers are here and the hood splitter is coming in
Old 04-24-2013, 01:02 PM   #41
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
got the hood splitter looks like it fits.
does anyone know if the intercooler bracket is needed? i know i need the gasket so i'm ordering that.
Old 04-24-2013, 02:56 PM   #42
Wrexflex
Member#: 326301
2012 WRX LR - Sold
I would say the support that the bracket provides on the passenger side is necessary. Otherwise the only thing holding it up is the hoses
Old 04-24-2013, 03:28 PM   #43
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
ok so i'm looking at my friends picture.
the gasket on the right side looks like it can hold it up but the other side is jsut the hose holding it up i'll see if i can find something that will hold it up or together whichever works.
i honestly think its just aesthetics.
Old 04-24-2013, 03:56 PM   #44
BroBroBroBroBro
Member#: 338211
2011 wrx
12.9 @ 107
im about to get this thing...ima let the shop do it forget this crap...
BroBroBroBroBro is offline   Reply With Quote
Old 04-24-2013, 04:38 PM   #45
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
if you bought it retail you wouldn't have to worry about these things.
if you cant even install it yourself, you've got a problem. save money on labor and DIY
Old 04-25-2013, 09:55 AM   #46
Wrexflex
Member#: 326301
2012 WRX LR - Sold
It's super easy to install if you have any mechanical background whatsoever and if u have taken off/put on the stock IC before, I think this is easier personally. I'll tyr to post some pics later tonight of mine, and yes I used the gasket for the BPV, the stock gasket, if not you will have a boost leak and be gettin all kinds of misfires.
Old 04-25-2013, 10:59 AM   #47
S206DGM
Member#: 339537
okay, I installed the Process West TMIC yesterday. The install went pretty smooth with only a couple hiccups.
The kit comes with new hoses and worm clamps.
Well today, I drove the car to the office. Everything seemed fine, I was driving easy (shifting at 3k rpm). Once I was on route 28 and was in 5th gear, I decided to test the car out. I put the fun pedal on the floor to see how the car was handling. Once I hit about 3500 rpm - 4000 rpm, the car sounded like it was having fuel cut out issues and the car would stop continuing to accelerate.
I believe I have a boost leak issue. I think it is caused by the hose running from the intercooler output to the throttle body. I havent had a chance to look at the worm clamp to see if it slipped off.
I am looking at ordering some t-clamps to replace all 4 clamps on the intercooler piping.
Anyone else have this issue?
S206DGM is offline   Reply With Quote
Old 04-25-2013, 11:15 AM   #48
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
what the stock gasket? it shouldn't be able to use it cause there isn't any. where does your throttle body hose go into?
someone take a pic and share it?
Old 04-25-2013, 11:17 AM   #49
DP2
Member#: 330532
2011 WRX Hatch LTD
DGM - Stage 2
The day following my PW install, the TB hose clamp slipped and was no longer holding the hose on. It was a bit scary when it happened.
So I pulled the IC and all hoses/clamps off. Starting with the IC to TB hose, I made sure there was a clear area at the TB connection point (moved some of lines out of the way just above the TB connection). I applied some hair spray to the hose, and worked until I was confident that the TB clamp was 100% secure.
Once that was done, I reinstalled the PW finishing with hose & clamps at the turbo inlet side. No issues since.
DP2 is offline   Reply With Quote
Old 04-25-2013, 12:35 PM   #50
S206DGM
Member#: 339537
Did you use the hair spray on the inside of the tubing?
