Old 04-06-2010, 07:18 AM   #1
SWP sube
Member#: 236667
2007 SWP
390 whp Limited STi
Default 8cm hotside vs 10cm hotside
i searched.. but came up with nothing..
on an STi is an 8cm hot side good enough?
or would it be better to just get a 10cm hot side??
SWP sube is offline   Reply With Quote
Old 04-06-2010, 07:37 AM   #2
05-rsx
Member#: 101188
MY07 WRX Wagon
Also keen to hear this discussion.
Some company (can't remember which) recently released a TD06-20G-10cm for stock position Subaru application.
FWIW, I think Mitsu Evos run 10cm^2 housings, although they do have short, twinscroll headers, which would aid in reversing any decrease in spool from the bigger housing.
05-rsx is offline   Reply With Quote
Old 04-06-2010, 08:53 AM   #3
WaXed
Member#: 88273
2003 STi 2.0L
good enough for what?
a 350whp daily street driver, yeah...
the bigger the turbine blade then the hosing cm2 goes up....
this refers to the cross sectional area of the turbine entry point right where it meets the turbine housing circumvent
Garrett use the dimensionless A/R number to express the same thing
WaXed is offline   Reply With Quote
Old 04-06-2010, 09:00 AM   #4
WaXed
Member#: 88273
2003 STi 2.0L
also note
with the Mitsubishi 10cm2 twinscroll housing, each turbine volute will be 5cm2...
Old 04-06-2010, 09:06 AM   #5
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Blouch started making a 20g with a 10cm2 housing.
We need more info on what you use the car for...
Old 04-06-2010, 09:23 AM   #6
stidoc
Member#: 147579
Depends on where you want your power band. 8cm = 3-6K rpm and 10cm = 4-7K rpm.
Where do you do most of your driving in this car, street, strip, track, auto-x?
stidoc is offline   Reply With Quote
Old 04-06-2010, 03:08 PM   #7
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Those numbers are pretty meaningless. Even an 8 cm 20G can be a 4-7k turbo.
Byzantium is offline   Reply With Quote
Old 04-06-2010, 03:13 PM   #8
stidoc
Member#: 147579
Given the traditional mods and competent tuning, this is where the dyno plots are shaking out on the 10cm hotsides by Blouch. It's a generalization, sure, but one borne out by the objective evidence to date.
Old 04-06-2010, 03:30 PM   #9
i<3mylegacy
Member#: 215206
bumpppppp
i<3mylegacy is offline   Reply With Quote
Old 04-06-2010, 03:43 PM   #10
arghx7
Member#: 232940
Dyno plots don't show everything. When you run bigger hotsides you will notice it's harder to make part throttle torque and boost. You'll find yourself downshifting a more around town. The engine feels more high strung.
arghx7 is offline   Reply With Quote
Old 04-06-2010, 04:28 PM   #11
stidoc
Member#: 147579
This is what I want to avoid on a street car. I realize others prefer this kind of car.
Old 04-06-2010, 08:38 PM   #12
arghx7
Member#: 232940
it's the classic tradeoff of instant torque which then fizzles versus the top end rush
Old 04-24-2013, 02:26 PM   #13
tja1618
Member#: 181995
2003 WRX
Ok, any new opinions on this? Looking at a new FP GREEN HTA w/ the stock (64mm) compressor cover. I'm figuring with the stock cover, the 10cm2 housing would be of less benefit, and am leaning toward the 8cm2. Then again my motor has Kelford 272 cams so I want to make sure it works well with the turbo.
tja1618 is offline   Reply With Quote
Old 04-24-2013, 04:24 PM   #14
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Bigger hot side I would think if your cammed and don't mind lag. If you daily drive your car am mind downshifting go with a 8cm
Shortpersonbk is offline   Reply With Quote
Old 04-24-2013, 06:18 PM   #15
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
8cm vs 10cm is about preference.
http://forums.nasioc.com/forums/show....php?t=1981344
8cm keeps more at lower RPMs and 10cm moves things to higher RPM.
All about what you want.
It doesn't matter if you're cammed or whatever, this will affect turbo performance similarly no matter what the rest of your setup is like. It will always have a similar trade-off. You'll get one guy saying cams are made for top end and 10cm is best, then another guy will chime in saying you need the 8cm to make up for the low end lost with cams. Whatever, there are valid arguments to go either way... bottom line is you just need to take your pick.
Old 04-24-2013, 10:24 PM   #16
Shortpersonbk
Member#: 319017
15 Prius
Agreed he needs to decide redline power or a little more low end. No one here can decide that for you, unless you have certain power goals in mind.
Old 04-24-2013, 11:03 PM   #17
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
8cm hot side is ideal on a stock 2.5 for every day driving. Off-boost characteristics are insanely good, boost comes on a few hundred RPMs earlier than the 10's, and it still pulls like a big turbo.
Get the 10cm if you're seeing triple digits mph consistently.
scoobasaurusrex is offline   Reply With Quote
Old 04-25-2013, 12:30 AM   #18
Mark2JZ
Member#: 83818
after having a 8cm TD06 20g for over a year, and then more recently a blouch dom3xtr 10cm.....
8cm if you like point-and-shoot, autox friendly powerband, and the 10cm is awesome for roadcourse, trackday work.
just my 0.02
Mark2JZ is offline   Reply With Quote
07 WRX - Blouch DOM 3 8cm housing vs. 10cm housing! Equilibrium Tuning Proven Power Bragging 51 04-23-2013 07:23 PM
Feeler...... Dom 3 10cm hotside Kiwi Fella AKIC Private Classifieds 11 05-25-2010 02:25 AM
fp red 7cm vs 8cm hotside Jonx1218 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-31-2008 09:36 PM
FP Green, 8cm hotside, 3 inch inlet, ewg, $1250 shipped!!! burnin4 Engine/Power/Exhaust 12 01-09-2007 05:39 AM
We Need To Get Some 8cm, 9cm 0r 10cm Rear Housings Made Andreas Miko General Community 0 01-09-2006 07:51 AM
