Old 04-24-2013, 12:47 PM   #1
topherrwrx
Member#: 319759
2012 WRX Hatch
Recently (Saturday), I installed a invidia divorced catless downpipe on my 2012 Wrx 5dr. I also have a tomioka IC to TB hose(prior boost leak). Flashed to cobb stage 2 and test drove. I have driven around 150 mile since the install and I have a whistle sound low in the rpm range. Below 2500rpm or so. Is this a normal sound for. Catless stage 2 set up(no intake) or should I be concerned with leaks? I have made sure all connections are tight. It really is only noticeable when leaving from a stop gently getting up to speed.
topherrwrx is offline   Reply With Quote
Old 04-24-2013, 12:50 PM   #2
topherrwrx
Member#: 319759
2012 WRX Hatch
Oh and it is a little more noticeable on the drivers side. Windows up or down....
Old 04-24-2013, 12:55 PM   #3
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
check all of your connections to the I/C unit. Do a smoke test if you can. Seeing by eye doesn't mean much.
-Mark
APM Tuned is offline   Reply With Quote
Old 04-24-2013, 12:58 PM   #4
DrStinkPinky
Member#: 326086
2012 WRX 4DR Limited
ISM
I'm also experiencing a similar issue after going stage 2 with a catted DP. Same thing I only hear it while gingerly accelerating, and also only hear it under 3k rpms out of boost. I checked all lines and and none appear to be leaking. I'm also able to hit target boost.
Is this possibly just a result of a bit more sound coming through from the less restrictive downpipe?
DrStinkPinky is offline   Reply With Quote
Old 04-24-2013, 01:20 PM   #5
topherrwrx
Member#: 319759
2012 WRX Hatch
Yes I am able to hit target boost. No I do not have a smoke machine. I really hope it is just more noticeable because of the less restrictive downpipe. I'm paranoid.
Old 04-24-2013, 02:30 PM   #6
topherrwrx
Member#: 319759
2012 WRX Hatch
Someone else ever have this issue? Maybe an exhaust leak?
Old 04-24-2013, 02:46 PM   #7
rexspeedworthy
Member#: 26965
2013 XV crosstrek
Mine does it. I hit target boost, so don't worry about it.
TIC installed it, and said my dp was a little tough to seal up. If it gets worse, I'll take it back to them.
rexspeedworthy is offline   Reply With Quote
Old 04-24-2013, 02:50 PM   #8
topherrwrx
Member#: 319759
2012 WRX Hatch
So then I'm gonna guess an exhaust leak. Ill jack the car up today and re torque everything down. Hopefully this will cure the sound. If not ill keep trying..... No issues with your car other then the low rpm whistle?^^
Old 04-24-2013, 09:27 PM   #9
topherrwrx
Member#: 319759
2012 WRX Hatch
All tight. Anyone else have any input...
Old 04-24-2013, 10:05 PM   #10
RoadKillDMD
Member#: 284792
2011 STI
Blurple
What catback are you running?
Old 04-25-2013, 10:29 AM   #11
topherrwrx
Member#: 319759
2012 WRX Hatch
Stock mid pipe and nameless axel back. It wouldn't e the dp area.
Old 04-25-2013, 10:47 AM   #12
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Old 04-25-2013, 11:56 AM   #13
DP2
Member#: 330532
2011 WRX Hatch LTD
DGM - Stage 2
I have this same issue and noticed the whistle (in low rpm range) right after installing a new MadDad hi-flow catted dp, PW TMIC, Tial QR BPV, and AEM CAI. At first I suspected it was the air pump since I had to remove it when replacing plugs, but the whistle continues after the engine had been running at normal operating temps.
Double checked all connections and confirmed no leaks.
My tuner said the whistling most likely is a result of turbo fan (hot side) creating a vortex that can now be heard due to the recent DP upgrade. Over the past week the whisling has subsided and I only notice it on rare occasions.
DP2 is offline   Reply With Quote
Old 05-07-2013, 06:12 PM   #14
topherrwrx
Member#: 319759
2012 WRX Hatch
Road kill, yes I do!
Old 05-07-2013, 06:13 PM   #15
topherrwrx
Member#: 319759
2012 WRX Hatch
Dp2, yes i have driven around 250 miles. Still the same sound. Al checked and all tight. Tuner said its the downpipe.
