Old 04-24-2013, 05:06 PM   #1
crschneiderwrx
Member#: 324337
2008 sti
satin pearl white
Default 2011 wrx boost issues
Current tune: ap stage 2+ sf oct91
I started losing power throughout the week. I plugged up my ap and read boost off of it. Target boost:17.5 logging boost:14.4 I thought maybe my plastic ic had a crack, replaced with a fms tmic... Still same readings, then replaced the plastic bpv with a forgemotorsport bpv... Still same boost... I use to boost to my target but idk where I could be leaking?
crschneiderwrx is offline   Reply With Quote
Old 04-24-2013, 07:06 PM   #2
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Now that you've replaced the TMIC you should probably get a tune.
In the meantime, did you try unplugging the battery to reset the ECU?
sc00ter is offline   Reply With Quote
Old 04-24-2013, 07:24 PM   #3
subyhatch05
Member#: 296700
i would have checked all the lines and parts for leaks before going and buying expensive new parts out on a limb
subyhatch05 is offline   Reply With Quote
Old 04-24-2013, 08:18 PM   #4
crschneiderwrx
Member#: 324337
2008 sti
satin pearl white
well i was wanting to replace these parts anyways since ive been stage 2 for a year. The leak just happened a week before the purchase and wanted to clarify that the leak didn't come from the plastic parts
Old 04-24-2013, 08:20 PM   #5
crschneiderwrx
Member#: 324337
2008 sti
satin pearl white
I flash my tune back on, I didn't think i had to reconnect my battery every time i reflash my ecu with the current tune, or even just reflashing with same tune. Im saving for a protune next, I just want to figure out why my boost levels are not up to par before I do so.
Old 04-24-2013, 10:00 PM   #6
jpatt006
Member#: 289470
2010 Forester XT
A tune would be beneficial but isnt required for a TMIC
Take a look at your TB to IC hose if you havent already. Check if any vacuum lines are disconnected.
jpatt006 is offline   Reply With Quote
Old 04-24-2013, 11:31 PM   #7
crschneiderwrx
Member#: 324337
2008 sti
satin pearl white
Tb to ic is tight, turbo to ic is checked, bpv gasket is fine, new forged bpv and ic.. Vaccum Line from bpv to Mani ? I believe? Is connected. I don't know of any other vacuum lines to look for
Old 04-25-2013, 08:31 AM   #8
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Do you hear any noises when going WOT, such as a squeal or flutter? I find it weird that your car was hitting target boost for that long then one day dropped.
Old 04-25-2013, 12:04 PM   #9
crschneiderwrx
Member#: 324337
2008 sti
satin pearl white
No added noise, I'm just lost and confused.... I figure if I posted up here maybe there's a random vacuum hose I don't know about?
Old 04-25-2013, 02:19 PM   #10
nky2012wrxjason
Member#: 338816
Where are you from here in Cincy tempature change really affects my boost winter ill hit 20 21 psi summer like 18 19
nky2012wrxjason is offline   Reply With Quote
Old 04-25-2013, 03:03 PM   #11
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Build and use one of these: http://forums.nasioc.com/forums/show....php?t=2205161
