Old 04-18-2013, 09:40 PM   #1
AIDRIIAN
Member#: 350104
2007 WRX
Default 07 wrx turbo help?
Hey guys. So i just recently bought an 07 wrx, and it has to go for inspection soon because it came from out of state. I found it that it has a catless invidia dp with some kind of straight pipe exhaust. i need to buy a stock dp and exhaust to pass inspection, obviously. im not sure if the turbo is the stock td04. it looks like it but im not sure and i really dont want to take it out. if i do buy the stock dp, it should just bolt right on and not have problems right? what should i be looking for if it doesnt fit properly?
Thanks for looking.
Adrian
AIDRIIAN is offline   Reply With Quote
Old 04-18-2013, 09:47 PM   #2
Mr.02
Member#: 140697
Your invidia down pipe was designed to fit the stock turbo, therefore if you buy a stock down pipe it will fit the turbo in the car. My guess is the turbo is stock. 100% sure a stock dp with fit with no problem.
Thanks for looking.
Adrian
Mr.02 is offline   Reply With Quote
Old 04-18-2013, 09:54 PM   #3
AIDRIIAN
Member#: 350104
2007 WRX
Okay thats great. Thanks for the reply. Kinda new to Subaru mods if you couldnt tell.
Old 04-18-2013, 10:34 PM   #4
Member#: 301037
2004 Forester XT
Darn inspections! You should be able to find a oem DP pretty cheap. Even if the turbo is not stock most of the popular upgrades as far as turbo goes will mate up with the oem DP.
art@grimmspeed is offline   Reply With Quote
Old 04-19-2013, 12:35 PM   #5
ewrx05
Member#: 71158
2016 WRX Limited
CWP
Thanks for looking.
Adrian
What type of engine management are you running?? Accessport or other?
Are you trying to put the car back to stock permanently?
If not, try to borrow a stock exhaust locally instead of buying.
ewrx05 is offline   Reply With Quote
Old 04-19-2013, 03:14 PM   #6
AIDRIIAN
Member#: 350104
2007 WRX
No I've just got the stock EM. i probably will add an AP later down the road but i just want to get the exhaust back to stock mainly to pass inspection and then ill look into getting a Blitz Nur. That way i can keep the oem dp on but still be a nice loud sound.
Old 04-19-2013, 04:32 PM   #7
UGM_hawkeye
Member#: 238245
WRX 07-Mayhem Tuned
280whp/295wtq - VF34
Just popping in here with a quick 2 cents...
If a downpipe and straightpipe were installed, how safe are you in assuming that the ECU hasn't been tuned?
While it may not be an aggressive tune, having a tuned ECU and going back to stock parts may not be the healthiest thing down the road if your car is expecting a lot more. If I were you, I would get in touch with a local tuner. They should be able to see what kind of tuning was done. I know in the Subaru world, most of the time that you put a downpipe on a tune is required.
UGM_hawkeye is offline   Reply With Quote
Old 04-19-2013, 09:46 PM   #8
AIDRIIAN
Member#: 350104
2007 WRX
[quote=UGM_hawkeye;39631574]Just popping in here with a quick 2 cents...
While it may not be an aggressive tune, having a tuned ECU and going back to stock parts may not be the healthiest thing down the road if your car is expecting a lot more. If I were you, I would get in touch with a local tuner. They should be able to see what kind of tuning was done. I know in the Subaru world, most of the time that you put a downpipe on a tune is required.[/QU
Would i still expect a tune if the only engine mods are a dp and aftermarket exhaust?
And would there be anything noticeable at idle or cruise?
Old 04-22-2013, 12:06 PM   #9
ewrx05
Member#: 71158
2016 WRX Limited
CWP
Yes, an 07 wrx with an aftermarket downpipe needs a tune.
I would make figuring this out a priority. With no tune, your motor is at risk of damage, if it's not damaged already. I think it would be overboosting - not sure if you have a gauge. And you could have issues if you put a stock downpipe on there, but there is in fact a tune. Maybe you can contact the previous owner and find out. Or post in your local forum for some help. Someone with a tactrix cable and a laptop could probably figure this out for you, or go to a tuner.
After you get all that figured out, i think you'll be wanting to put your downpipe back on, with the appropriate tune. Unless you're happy with stock power levels. But the car is much nicer at stage 2, IMO.
Old 04-22-2013, 12:46 PM   #10
ewrx05
Member#: 71158
2016 WRX Limited
CWP
... and you have an aftermarket BOV? and no tune? is that all the mods?
i see you have a bunch of threads going....
Old 04-22-2013, 01:11 PM   #11
UGM_hawkeye
Member#: 238245
WRX 07-Mayhem Tuned
Like ewrx05 is saying, it's best to find out what exactly is going on with the car. In the meantime, drive it softly.
Get a phone number or two of some local (reputable) tuners. Tell them you just picked up this car and you want to get a quick look at what's going on. If they help you now, they're securing business in the future if you have future plans and mods. I can't imagine this would even be that expensive anyway.
Once they can see what's been changed, ask what you should do for the cars benefit if you're serious about changing parts around right now. They should be able to answer any question you have, even passing smog, etc.
Old 04-22-2013, 06:41 PM   #12
AIDRIIAN
Member#: 350104
2007 WRX
Everything that has been said makes a ton of sense. but the problem is, the car is not registered because it was bought from out of state and in order for it to get registered it needs to pass smog...which i obviously cant do with no cats or muffler. And there is a boost gauge, but its not hooked up. I have started the car, listened to it run and it runs very smooth except for some black smoke from the BOV. Would it be okay if put the stock exhaust on for a day or two, then put my aftermarket parts on and go to a tuner?
Old 04-24-2013, 11:57 AM   #13
ewrx05
Member#: 71158
2016 WRX Limited
CWP
have you posted to your local forum to see if someone with a tactrix cable can help you out? If you don't have a check engine light, you could have a tune. I think a downpipe would throw a CEL eventually unless another mod was done.
If you're out of optoins, put the stock parts back on, including a stock BOV if you can get one, and get through inspection, then get it checked out. I would try and stay out of boost on your dirve.
Old 04-24-2013, 12:05 PM   #14
xanthus29
Member#: 118313
2007 WRX Wagon
I inadvertently ran a DP without EM (thought it was the proper tune) for a couple weeks on my 07 WRX and now I need a new short block. As others have stated, figuring out your EM should be your immediate priority. Mine didn't throw a CEL, just ran terrible.
xanthus29 is offline   Reply With Quote
Old 04-24-2013, 02:57 PM   #15
AIDRIIAN
Member#: 350104
2007 WRX
ok ive looked into Tactrix and im going to get the Openport 2.0. so if i can find a stock 2007 wrx base map which i have, unchanged, would reflashing the stock map allow me to put the stock parts back on?
Old 04-25-2013, 09:04 AM   #16
MakeItRoar
Member#: 284844
2006 WRX Limited
Obsidian Black Pearl
.....did this not jump out at anyone else?
MakeItRoar is offline   Reply With Quote
Old 04-25-2013, 12:26 PM   #17
ewrx05
Member#: 71158
2016 WRX Limited
CWP
Yes, flash the stock 07 wrx map and install all of the stock parts, including a stock BOV, at the same time. Are you able to verify that you have a stock boost control solenoid, and not a manual controller or GM solenoid or other? I'd try and confirm that as well.
Old 04-25-2013, 05:01 PM   #18
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Once you get all the stock parts back on and pass inspection, your very next stop should be to get a compression and leak down test. I'll be very surprised to see that your motor is healthy, at this point . But I'm hoping for the best.
Good luck!
Also, ewrx05, I coppied your Vehicle description because the layout is much cleaner than mine was.
sc00ter is offline   Reply With Quote
Old 04-25-2013, 06:26 PM   #19
ewrx05
Member#: 71158
2016 WRX Limited
CWP
how are you liking the vf-48? my only regret is not doing it 100k miles ago!
car is night and day better and i've only tuned it up to 16 psi tapering to 14.5.
still have headroom but the trans is always in the back of my mind.
good luck aidriian, keep us posted.
Old 04-25-2013, 07:00 PM   #20
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Absolutely loving it. Tuned for 17psi tapering to about 15.5. My tuner also made me a higher performance map at 19psi tapering to 17.5psi but I don't use it often at all since he said it wasn't safe for daily driving.
I've been on this setup for almost exactly a year now and have had no issues (knock on wood). The power difference from stage 2 on the TD04 is just not even comparable. I'd do the upgrade again in a heart beat.
With the hot weather right around the corner I just installed the Perrin DP blanket, PTP turbo blanket and installed the SPT heat shield to help combat the heat soak a bit. I've already noticed a decrease in spool time with the blankets installed, which I love.
I thought about getting an e85 tune this summer, but like you, I'm pretty scared of blowing the transmission (even though I never launch it). I think I'll leave it as is since I'm extremely happy with it anyway.
Sorry for the thread jack OP.
Old 04-25-2013, 10:12 PM   #21
coalslaw
Member#: 324808
2006 IWL Stg2
i AM VERY SORRY TO HEAR THIS...MARK THIS MAN'S WORDS...MARK THEM WELL.
coalslaw is offline   Reply With Quote
