Old 04-25-2013, 07:43 PM   #1
Shadow4
Member#: 351319
2002 Impreza WRX HB
Default Difference in EJ257s?
Is there a difference between the EJ257 from an STI and the EJ257 out of a WRX? Because I was ordering a head bolt for mine the other day and there was a difference of a few hundred dollars for the one they had listed for a WRX EJ257 and an STI EJ257, so I was wondering what the difference is.
Shadow4 is offline   Reply With Quote
Old 04-25-2013, 07:48 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
WRX has a ej255. Your WRX (unless you have a swap) has a ej205... What exactly are you asking?
Old 04-25-2013, 07:53 PM   #3
Shadow4
Member#: 351319
2002 Impreza WRX HB
Well I bought my 02 WRX from a mechanic down in South Carolina and he said the engine was swapped out of a newer WRX, I looked at the engine serial and it's an EJ257. The part store had one listed for that engine code for a WRX and an STI. Are you saying they never put the EJ257 in WRX's?
Old 04-25-2013, 09:40 PM   #4
ost911
Member#: 245634
2003 Impreza wrx wag
Wrbp
i do believe you've got yourself a sti short block!!!
ost911 is offline   Reply With Quote
Old 04-25-2013, 11:35 PM   #5
Shadow4
Member#: 351319
2002 Impreza WRX HB
So I have a complete STI engine? Or are you saying just the bottom end is from an STI?
Old 04-26-2013, 11:50 AM   #6
Shayhan27
Member#: 205906
05 WRX
Ej257 is the code from the STI. The thing you need to ask is if the mechanic you got your car from did a full swap or if he did a hybrid ej257 block with ej205 heads.
This is critical information as the part you are looking for is for the head, and I do not know if it will be a universal part.
Call the guy you got the car from and find out exactly what you have.
Shayhan27 is offline   Reply With Quote
Old 04-28-2013, 09:00 AM   #7
Shadow4
Member#: 351319
2002 Impreza WRX HB
I talked to him the other day. It's a full EJ257. It's quite possible that the guy I talked to on the phone at the parts store had no earthly clue what he was talking about and just knew how to type info into the computer.
Old 04-28-2013, 08:08 PM   #8
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
You have an EJ257 and didn't even know that when you bought it?
tmburke is offline   Reply With Quote
Old 04-28-2013, 11:57 PM   #9
Shadow4
Member#: 351319
2002 Impreza WRX HB
No, I knew that it had an EJ257, but I found out a bit later the hybrid swap, so I called him to make sure that it was a full swap and not a hybrid swap.
