Old 04-25-2013, 10:13 PM   #1
lillayzie2000
Member#: 255051
2004 WRX
Default Rattling sound/hard vibration when going into first gear
When going into first gear, there seems to be a bit of vibration and a slight rattle. It's hard to explain but i'm going to try and get a video of it in the am. 04 WRx, and this happened on my 5spd and now on my six speed. i'm thinking it could be something with the master cylinder or something. just wanted to see if anyone else has ever had this issue.
lillayzie2000 is offline   Reply With Quote
Old 04-26-2013, 02:32 AM   #2
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Bad throw out bearing maybe? Flywheel needs resirfaced ?
white guys wrx is offline   Reply With Quote
Old 04-26-2013, 11:42 AM   #3
lillayzie2000
Member#: 255051
2004 WRX
Maybe it's flywheel resirfacing. throw out bearing was replaced.
Old 04-26-2013, 08:06 PM   #4
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
can you record what its doing by chance? ... you could have a bad bearing in your crank also....... check your oil for metal shavings :s
Old 04-27-2013, 01:10 AM   #5
wrx1392
Member#: 342331
2003 wrx
blue
stock clutch or a stage 2 or 3?
wrx1392 is offline   Reply With Quote
Old 04-27-2013, 12:17 PM   #6
lillayzie2000
Member#: 255051
2004 WRX
Stage 3 clutch.
Old 04-27-2013, 12:18 PM   #7
lillayzie2000
Member#: 255051
2004 WRX
Hopefully not, Built motor i has.
Old 04-27-2013, 03:20 PM   #8
drewmob
Member#: 214192
Usually flywheel.
drewmob is offline   Reply With Quote
Old 04-28-2013, 05:14 PM   #9
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Stage 3 clutch.
I ran a drag setup for 2 years... six puck dual spring clutch with a fidanzia flywheel...that bitch will rattle, shake, jump and do all sorts of tricks... the oem clutch is rated for like 400hp ... I would swap over to it lol. You also may have some chunks taken out of your flywheel with that aftermarket clutch if you are running the stock one
Old 05-06-2013, 04:42 PM   #10
lillayzie2000
Member#: 255051
2004 WRX
Here is a little of what i'm talking about. I tried to get the best sound clip that I could:
In this video it happens at 4sec and at 8.5-9sec and at the end, sounds like a rattle:
Old 05-26-2013, 09:55 AM   #11
lillayzie2000
Member#: 255051
2004 WRX
Found the source. It was actually the dog bone mount. It wasn't tight.
