Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 04-13-2003, 11:36 PM   #1
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
Default Wiring USDM EJ20 into MY98
Ok, I've been reading countless threads about WRX swaps for 3.5 hours now. The biggest problem from my understanding is the wiring part. My question is there an easier way around this, I'm a little confused because I keep reading about JDM swaps, and the RHD -> LHD conversion causing problems. How hard is it to swap a USDM motor in and what all would I need. Anything that makes this process easier (I read something about using a Link ECU that was made for the WRX swap but didn't find much details about this???)
Kyle
Andursun0013 is offline   Reply With Quote
Old 04-18-2003, 06:37 PM   #2
SUBY2.5
Member#: 31985
06 Outback Wagon
Go to lachutesubaru.com they'll help you out.
SUBY2.5 is offline   Reply With Quote
Old 04-18-2003, 11:59 PM   #3
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Arrow
The problems you run into with RHD vs. LHD is that the harnesses are laid out backwards. There's no problem in swapping a motor from a RHD car to a LHD car except the wiring.
Swapping a USDM motor into a GC/GM body is simple except again for the wiring. You'll need to get the harnesses (engine & firewall aka dash) and splice them together.
Do a search in this forum for yamarocket630's swap. Very good information.
Some stuff you'll need for the swap are:
Complete motor/ecu
Wiring harnesses (engine & firewall)
WRX or Legacy turbo crossmember
WRX fuel pump
Man...my mind is fried right now. I can't think of what else you'd need. I've got a list that's on my kitchen table that's 250 miles away right now.
-mykr.
mykrrrr is offline   Reply With Quote
Old 04-23-2003, 11:21 AM   #4
EJ25
Member#: 10768
beer.... you forgot the beer....
EJ25 is offline   Reply With Quote
Old 04-23-2003, 11:46 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
check out i-speed usa....chris has been a big help to me in understanding what I need to do.
http://www.i-speedusa.com/home/
They have a lot of good info on what you need and a break down of the time required to do the wiring.
Good luck, Micah
I'm paying to have my wiring done!!
Old 05-13-2003, 07:34 PM   #6
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
I did exactly what you want to do. One thing that definatly made things easier was to get a vishnu TEC II kit. The TEC II makes the wiring bit about 1000x easier.
Frank
luvmyrs is offline   Reply With Quote
Old 05-13-2003, 07:47 PM   #7
HubbieScooby
Member#: 7088
Super Slow
Frank
kool really?? i was thinking about getting the autronic engine management...but i know that the TEC 2 needs to be totally wired up compared to the Link's plug and play ability....was this with a JDM motor or a USDM WRX motor....i was thinking about getting a JDM and going with an aftermarket ECU....hopefully this can make the wiring part a little less painful....thanx
hugh
HubbieScooby is offline   Reply With Quote
Old 05-13-2003, 08:35 PM   #8
luvmyrs
Member#: 1048
to POS thieves.
it was a USDM motor. Good luck on your project man. it'll all be worth it the first time you get into your car
Old 05-19-2003, 04:07 PM   #9
serious
Member#: 22879
I'll be having the joy of doing this in the somewhat near future with my legacy. (knocking on wood anyway) I've read you can take the entire wrx harness and put it into your rs. Or you could cut and spice. There is always the option of going with a stand alone but that's really spendy and something i won't be doing. I think the last but maybe the best option for some would be cutting the old rs harness at the ecu and wiring in the wrx computer and adding a few wires. You don't have to take out the dash to do this, but then there are a bunch of wires under the dash you don't need and could take out.
You might be able to send you harness to somebody and have them prep it for you. I think if you're able to take out the dash then you might as well do it yourself and save a bundle.
Brent
serious is offline   Reply With Quote
Old 05-19-2003, 07:18 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Problem with aftermarket engine management is emissions. Some places may just test your OBD-II system for the emissions and if you have a single CEL then you will fail. There is only one engine management system that I know of that allows the OBD-II system aside from a remapping of the stock ECU and its not anything for Subarus.
-Jon
stimpy is offline   Reply With Quote
Old 05-19-2003, 11:04 PM   #11
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
i think it's i-speed that said they can prep your harness for install, 750 i think it cost. Good luck.
Soon2Bgreat is offline   Reply With Quote
Old 05-28-2003, 12:55 PM   #12
bluimpreza00
Member#: 19094
2004 Forester XT
Red
I have been doing some research about swaping a USDM EJ20 into my RS. If I can ever save up enough money Im getting a Subaru mechanic to do mine. He knows about the WRX and the RS, he said he would do it on the side. I really have no worries. I also heard from www.teaguesauto.com. Dale Teague told me that somebody was coming out with a plug and play for the RS-WRX swap. I dont know how expensive it will be.
Matthew
Good luck
bluimpreza00 is offline   Reply With Quote
Wire Guru's: Jdm Ej20 Into 93 Impreza 4wd (No E-Techs Please) ScoobySnacksURhonda Subaru Conversions 4 09-25-2007 05:36 PM
FAQ: RHD GC8 JDM sti conversion. turn your USDM L into EJ20 RHD Sti JDM supermoose Subaru Conversions 43 03-15-2006 04:22 PM
EJ20 into RS - Main relay wire questions... WRX 555 STi Subaru Conversions 2 08-10-2004 02:20 AM
usdm ej20 into pre 02's Wishing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-07-2004 03:14 AM
USDM ej20 into a 00+ Legacy GT? Layman Normally Aspirated with bolt-on Forced Induction Powertrain 4 01-14-2003 05:09 PM
