Old 04-26-2013, 04:56 PM   #1
projektdotnet
Member#: 315556
2004 WRX Wagon
Default 04 WRX base map Mod list included
Just had an uppipe and turbo swap completed and I need a base map to limp around with until I can get it down to my tuner.
04 USDM WRX Wagon
COBB Short Ram with Air Box
Turbo XS TMIC (not sure of model, was on the car when purchased)
STi Up-pipe
VF39 from STI
COBB 3" TBE (Catted)
Fuel system is stock still, though there are planned future upgrades, this just needs to be a safe limp map to tool around town in.
projektdotnet is offline   Reply With Quote
Old 04-26-2013, 05:22 PM   #2
projektdotnet
Member#: 315556
2004 WRX Wagon
The last map with most recent MAF scaling from before the Uppipe/VF39 install https://docs.google.com/file/d/0Bxd4...it?usp=sharing
Old 04-26-2013, 05:23 PM   #3
dux10
Member#: 235338
2002 Faggin Wagon
srp
Why not have your tuner supply the map?
What boost conrol device?
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 04-26-2013, 05:26 PM   #4
projektdotnet
Member#: 315556
2004 WRX Wagon
He works a day job and I need to be able to drive the car around until he's home.
The boost control is still stock, it's on the list of planned upgrades but that may be a ways away still.
Old 04-26-2013, 05:31 PM   #5
dux10
Member#: 235338
2002 Faggin Wagon
srp
stay out of boost and you'll be fine. Set max WGDC to 0% just to be safe (this means you will boost to wastegate pressure of 7-9psi). Existing tune will suffice if you stay out of the throttle.
Old 04-26-2013, 05:32 PM   #6
projektdotnet
Member#: 315556
2004 WRX Wagon
Thanks, I did notice if I kept out of the throttle I was OK but the second the boost gauge was above dead 0 it started leaning out very quickly so I just shifted and kept off the skinny pedal to limp home until I can tune it.
Old 04-26-2013, 05:34 PM   #7
dux10
Member#: 235338
2002 Faggin Wagon
srp
There's a wideband in the car?
Sounds more like a fuel system shortcoming than a tune related issue if the car was previously tuned for that intake.
Old 04-26-2013, 05:37 PM   #8
projektdotnet
Member#: 315556
2004 WRX Wagon
Yeah a wideband and gauge so I can monitor while driving. Never noticed it leaning out before with the old turbo, that one usually ran in the 11:1 range, it was also tuned for having the catted uppipe so I'm not sure if that's messing with it at all either.
Old 04-26-2013, 05:39 PM   #9
dux10
Member#: 235338
2002 Faggin Wagon
srp
Without a set of datalogs, its hard to tell. Just be easy on it till your tuner can assess the situation and do what they think is best.
Old 04-26-2013, 05:40 PM   #10
projektdotnet
Member#: 315556
2004 WRX Wagon
Will do, going to edit the map to crank back the WGDC at least to help with the lean issue, luckily I noticed it pretty quickly and was able to correct my driving style for the time being.
