Old 04-23-2013, 08:35 PM   #26
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
Originally Posted by Homemade WRX View Post
I'm still wondering about the engine choice. If you are only looking to make 450 whp or so, why did you choose the EZ30? It just seems like a lot of added cost and weight when compared to an EJ. Torque and power will be marginally different, for the same turbo and boost, because of RPM difference...I guess we can assume the EZ to perhaps has less frequent rebuilds because of power density.
Just curious,
Micah
I had just read about Jeff Perrin's EZ30 turbo build and swap into a WRX, and thought that it might be a cool option. It might ultimately be great if the engine were built to make 700 or so hp. It is smooth, sounds great and the low end torque and quick spool should be evident, but what you said is correct. It would have saved a lot of money, a lot of work and be 50 lb lighter with an STI engine. My understanding is that it would not need to come apart to make that power and a stock computer could have been used. I am glad that the details of using an EZ30 6 cyl have been worked out for people that may want that option, but the EJ is the more reasonable choice at this power level. So I guess my ignorance is the main reason -lol! I know more about Subarus now than when I started, but have a lot to learn.
jdogma is offline   Reply With Quote
Old 04-26-2013, 01:13 PM   #27
saffarco
Member#: 281942
Subscribed
saffarco is offline   Reply With Quote
Old 04-26-2013, 06:22 PM   #28
jdogma
Member#: 242350
black
Worked on wheel tubs today. The rear fender design on this car makes them very easy compared to most, but they are still tedious the first time. Bent a piece of 3003 aluminum to make a mold, then layed up 4 layers of carbon. Each side took 1 yard of carbon cloth ~ $30/yd. The bottom half is attached to the centerbody. The top half will be attached to the tail, but it is not bonded in yet. With these in the tires can't pick up rocks and throw them into the radiator and intercooler and the sidepods won't fill up with road crap.
Guess the inner fenders should be centrally lined with thin rubber sheet or something to protect the carbon...
Old 05-02-2013, 05:32 PM   #29
jdogma
Member#: 242350
black
Wheel tubs almost done. Took 2 lineal yards to be clear - roll is 50 inches wide, so 36 x 50 = 1 lineal yard. Used the extra bit for a top brace of the bottom tub part.
The bottom brace is a piece of carbon tube that somebody gave me. Made small triangular sections out of lightweight plywood to join the flat parts at right angles to flat parts with epoxy. Will add carbon layups later when I have the body off - takes 2 people and I'm alone today...
Note the conventional coilover unit. Just temporary...
Old 05-02-2013, 10:31 PM   #30
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
What size radiator did you use? I am still trying to figure that one out for my build.
RSti_Spyder is offline   Reply With Quote
Old 05-03-2013, 09:44 AM   #31
panel
Member#: 352704
1965 Vw panel van
EJ20 Turbo Swap/convo
Are you using stainless for your cooling lines?
panel is offline   Reply With Quote
Old 05-03-2013, 05:23 PM   #32
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
There are some simple calcs (rule of thumb kind of work) and then some complex calcs (values you probably won't have) to sizing a radiator.
If you look on FSAE.com, you can find some pointers.
I'm quite anxiously waiting to see this car's finished design. I feel like I'm only seeing sectio.s of an entire picture LOL
-Micah
Old 05-03-2013, 09:25 PM   #33
jdogma
Member#: 242350
black
Griffin 27.5 x 16 - core is 22.5 x16, 2 rows 1-1/4 in tubes Double pass. It also has an integrated oil-water intercooler.
Old 05-03-2013, 09:31 PM   #34
jdogma
Member#: 242350
black
No. They are all aluminum. Lighter, easier to bend and bead, match the material in the radiator and engine.
Old 05-03-2013, 09:44 PM   #35
jdogma
Member#: 242350
black
-Micah
Griffin Radiator has been very helpful over the years. Tell them hp and use and they suggest a solution. Ambient temps, airflow in and out, water flow path and volume - so many variables... I try to overdo it rather than optimize it F1 style. Never had any real problems - hope this isn't a first time -lol.
Thanks for the FSAE.com link. Some good brains there. One guy wrote a program for radiator sizing that you can use. Even if it is not perfect, I'm still impressed...
Old 05-04-2013, 02:43 PM   #36
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Thanks Jdogma. I love Griffin. They even helped us figure out the best size for this...
These are all aluminum coolant lines powdercoated wrinkle red.
Old 05-04-2013, 03:40 PM   #37
Homemade WRX
Member#: 33782
96 bastard child
No worries. A bunch of us FSAE alums are out floating about. I just don't have the time to go through all the details.
Old 05-09-2013, 05:47 PM   #38
jdogma
Member#: 242350
black
I give up. What is that?!! Mine ventilation?
Old 05-09-2013, 06:12 PM   #39
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
I'm guessing its a swamp buggy thing ( i forgot what they are actually called )
This build is sick. I wish I had the time and skills to form carbon fiber like that.
Krang is online now   Reply With Quote
Old 05-09-2013, 06:14 PM   #40
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
"air boat"
Old 05-10-2013, 03:36 PM   #41
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Motion picture wind machine, truck mounted. Although at gas stations when asked I sometimes tell them the wheels fold up once you drive into the water.
Airboat making wind, also Griffin radiator.
Old 05-10-2013, 03:41 PM   #42
Psychoreo
Member#: 79643
2015 WRX STI
I was close
Old 05-16-2013, 12:59 PM   #43
jdogma
Member#: 242350
black
Put tail lights on the car. Brake lights now only. Will add resistor to use them as running lamps and flasher to use them as turn signals too. Wire is inside the edge of the endplate and comes out under the tail. Also added a side Gurney to the endplate, which should help the diffuser that isn't there yet...
Old 05-18-2013, 03:46 AM   #44
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Very nice once again!
Old 05-23-2013, 01:40 PM   #45
jdogma
Member#: 242350
black
Thought it might be interesting since there are no photos with other cars for reference, to give dimensions relative to some other cars.
Carma Wolf WB 102.5 in, L 172.0 in, W 79, Ht 43.0 in, Wt ~1800 (hoping for this, but has not been weighed)
'13 Subaru WRX WB 103.3 in, L 180.3 in, W 70.7, Ht 58.1 in, Wt ~3240, 3384 (STI)
'02 Subaru WRX WB 99.4 in, L 173.4 in, W 68, Ht 57 in, WT ~ 3100
'13 Porsche 911 Turbo WB 96.5 in, L 177.4 in, W 74, Ht 51.2 in, Wt 3509 (AWD)
Corvette C6 WB 105.7 in, L 174.6 in W 72.6, 75.9 for Z06, in Ht 49.1 in, Wt ~3150
Porsche and Vette width are without mirrors.
Old 05-28-2013, 08:45 PM   #46
jdogma
Member#: 242350
black
Default Niprotek
Updated Niprotek suspension units:
-ride height is set via pressurization (could be a pump controlled in cockpit)
-spring rate is adjusted via large hex nut
for ref: with ride height close to design, pressure in rear is ~260 psi, pressure in front is ~ 180 psi.
for damping there are 3 speed adjustments for rebound and 2 for compression
Build is easier now, there are fewer parts, and they are even lighter. Very easy to set up, adjust and comprehend!
Old 05-31-2013, 05:59 PM   #47
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Nice, any more full shots?
Old 06-05-2013, 12:44 PM   #48
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Just came across this, very cool!
John, would you be willing to PM me your email address or number? I have a few questions I think you are uniquely qualified to answer.
Looking forward to see more updates!
Ben
PHATsuby is offline   Reply With Quote
Old 06-05-2013, 05:13 PM   #49
D3F0
Member#: 265799
1988 Subaru RX TURBO
This is some good work good luck with everything!
D3F0 is offline   Reply With Quote
Old 06-07-2013, 08:53 PM   #50
jdogma
Member#: 242350
black
Thanks for the encouragement from everybody!
Just wanted to post that I recently emailed Bremar in Australia asking if they made a 6 speed mid engined conversion, and they said " just wanted to let you know that since your email last month, I’ve had two more enquiries about a conversion kit for the STi 6 speed, so I’m going to have another look into what’s involved in developing the 6 speed parts. It’s not a definite goer yet, but I’m going to try and get hold of a box and figure out what needs doing. I’ll need to do the sums, but it’s likely that we’ll need a minimum order before we can put the parts into production, so if you know of others who would be seriously interested in this kit, get them to drop me a line and I can start building a waiting list."
Their email is [email protected]
