Old 04-25-2013, 07:01 PM   #1
Zumiez87
Member#: 206481
2013 WRX STI
Default 13 sti- need to prime everytime before start up.
I was wondering if anyone else has to prime the engine before turning the key or i get a lon g crank. can u guys just hop in and turn the key and no long crank? Or is that everyone?
Zumiez87 is offline   Reply With Quote
Old 04-25-2013, 08:34 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
what are you talking about? this isnt a model-t you own.
424wrx is online now   Reply With Quote
Old 04-25-2013, 08:38 PM   #3
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
lol..wut
Old 04-25-2013, 09:03 PM   #4
Dmochowski
Member#: 306478
2016 Focus RS
stock
you have a carb'd version?
Dmochowski is offline   Reply With Quote
Old 04-25-2013, 09:38 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
If you are having issues starting with your BRAND NEW CAR, take it to the dealer to utilize your WARRANTY. Just about any FI (Fuel Injection) vehicle you can hop in and start right up without "priming."
Old 04-25-2013, 10:00 PM   #6
DannyLerch
Member#: 353235
^^this^^
DannyLerch is offline   Reply With Quote
Old 04-25-2013, 10:36 PM   #7
JazzyJake
Member#: 153476
2005 VF39 6spd FXT
I have a tendency to turn the key to accessory, leave it for a sec, and keep turning. That's primarily because my 86 Celica prefers starting if you let the fuel pump cycle for a second or two, and it's a force of habit.
JazzyJake is offline   Reply With Quote
Old 04-25-2013, 10:44 PM   #8
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
I've done this on every car I've owned. I turn it to accessory (buckle up) and when the needles on the gauges stop moving I start mine.
Chicago AJ is offline   Reply With Quote
Old 04-26-2013, 12:29 AM   #9
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
You were wise to post about your long crank in the newbie section.
DO NOT do so in OT!
Gallo2011 is offline   Reply With Quote
Old 04-26-2013, 07:06 AM   #10
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
This. Just habit for me. And honestly, better for the car.
DO NOT do so in OT!
Heh, penis.
Old 04-26-2013, 09:16 AM   #11
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It sounds like you're losing fuel pressure as the car sits. You should not have to prime it before starting. I agree that you should take it to the dealer. It could be a leak at the fuel pump (in the plastic housing) or any other place along the fuel system.
Old 04-26-2013, 09:38 AM   #12
Corranhorn009
Member#: 353331
2016 STi Limited
I guess this could be somewhat related. How long, after you have started the car, do sit and idle before you drive? I usually wait at least 30 seconds if the temperature is above 60 degrees, and increase the time as the temperature get lower. Below freezing, at least 90 seconds.
With a new car like this and it running full synthetic I don't know if we even need to do this anymore but I still do.
Corranhorn009 is offline   Reply With Quote
Old 04-26-2013, 10:11 AM   #13
unamused LGT
Member#: 250813
08 unamused LGT
Camarillo - ish
Wait.....with drive by wire, does pumping the gas even do anything when the car isn't running? At most, it's moving the butterfly in the throttle body and annoying the ECU.
LGT
unamused LGT is offline   Reply With Quote
Old 04-26-2013, 11:14 AM   #14
mejifair
Member#: 11356
2012 WRX STi Hatch
I too turn the key to accessory while buckling my seat belt and then I start the car. Not sure what pump runs (I assume the fuel pump) But I certainly hear some liquid getting sucked into some place somewhere in the car!
mejifair is offline   Reply With Quote
Old 04-26-2013, 11:32 AM   #15
sultan81
Member#: 309943
2012 STi
you should let the gauges cycle before cranking the car, this gives the fuel pump time to prime the line.
sultan81 is offline   Reply With Quote
Old 04-26-2013, 11:46 AM   #16
prescottn6ft7
Member#: 268918
2007 WRX STi
Obsidian Black Pearl
Am I the only one reading this thinking it's ridiculous? Maybe on a race car running duel walboros 1400cc injectors with a custom fuel rail running on E90... elictricity travels a lot faster than you can turn a key, I promise. Unless your car has been sitting for months on end without being started or you have a fuel line/pump issue this sounds extremely unnecessary and you're enjoying the Defi sweep too much. Just my opinion, but would love to see scientific evidence that contradicts it.
prescottn6ft7 is offline   Reply With Quote
Old 04-26-2013, 01:31 PM   #17
WRX boarder
Member#: 328399
2012 WRX Limited
I believe what you're hearing is the secondary air pump, not the fuel pump.
WRX boarder is offline   Reply With Quote
Old 04-26-2013, 05:03 PM   #18
tec_41
Member#: 346278
04 WRX
Why....do you care? It's just a routine.
tec_41 is offline   Reply With Quote
Old 04-27-2013, 12:59 AM   #19
greenplates
Member#: 239162
I allow fuel pump to prime before starting
greenplates is offline   Reply With Quote
Old 04-27-2013, 12:59 AM   #20
greenplates
Member#: 239162
It feels magical
Old 04-27-2013, 02:10 AM   #21
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Originally Posted by greenplates View Post
It feels magical
I wish the fuel primer sounded like a jet engine primer firing up... That would get me every time.
blehhh is offline   Reply With Quote
Old 04-27-2013, 04:11 PM   #22
Zumiez87
Member#: 206481
2013 WRX STI
I was asking out of concern. I just wanted to know if anyone else has this issue. Im bringing it to the dealership on monday. I only have 1800 miles
Old 04-27-2013, 10:09 PM   #23
Freeagnt54
Member#: 339011
13 WRX Hatch
I usually let the gauges do the full sweep before starting, I'm not sure why, it just feels natural I suppose.
Freeagnt54 is offline   Reply With Quote
Old 04-27-2013, 10:55 PM   #24
wrxman02
Member#: 24162
2014 Legacy 2.5i
2012 Impreza 2.0i
I turn key, let gauges sweep. then start engine. no issues. ever.
wrxman02 is offline   Reply With Quote
Old 04-28-2013, 04:10 AM   #25
Zumiez87
Member#: 206481
2013 WRX STI
Yeah when i wait for the "opening ceremony" i hhave no issues its on the rare occasion that i dont that i have the issue.
