Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 04-24-2013, 07:28 PM   #2776
04wrx008
Member#: 261447
2004 Impreza WRX
I personally like the current layout, it's different, and because of that "in my opinion" cool.
breaking from the norm is how new and "cool" things are created. keep it up!
04wrx008 is offline   Reply With Quote
Old 04-24-2013, 07:31 PM   #2777
rsutton1223
Member#: 280744
2009 CTSV 6MT 750whp
Black Raven
Custom upholstered Sparco Milanos by JPM Coachworks
rsutton1223 is offline   Reply With Quote
Old 04-24-2013, 07:42 PM   #2778
grinch77
Member#: 198758
2004 STi
^^^^ nice bet that wasn't cheap.
grinch77 is offline   Reply With Quote
Old 04-24-2013, 09:04 PM   #2779
Bradrcr
Member#: 276382
2005 SaaBeeru
Wow, I am usually facepalming at the Alcantra set ups I see on here, that looks great.
Bradrcr is offline   Reply With Quote
Old 04-24-2013, 09:07 PM   #2780
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
I agree that looks really really good
I just cant get on board with the alcantara thing, I dont think I would like a fuzzy interior
KeithS05RS2.5 is offline   Reply With Quote
Old 04-24-2013, 09:21 PM   #2781
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
I had already modified the fender badge to light up using red LEDs, I took it a step further and wired them up as turn signals as well. The lights turn on with the headlights and blink in sync with the rest of the turn signals. I also put a pair of 9" LED strips in the fender vents, not sure how I feel about those just yet. The strips only flash with the turn signal, they do not stay lit at any time.
Sorry for the poor quality, but you get the idea.
atf78 is offline   Reply With Quote
Old 04-24-2013, 09:33 PM   #2782
DearDiaryJackpot
Member#: 343041
2013 wrx limited
metallic silver
Video Link: http://www.youtube.com/watch?v=pHv553zHDwI
Really love it. I might do this. But if I could, i would take it further. White wrx with headlights and red when turn signal.
DearDiaryJackpot is online now   Reply With Quote
Old 04-24-2013, 10:42 PM   #2783
ixwrxxi
Member#: 334215
2015 Forester
Awesome work by JPM Coachworks
ixwrxxi is offline   Reply With Quote
Old 04-24-2013, 10:49 PM   #2784
BoDacious
Member#: 190110
Originally Posted by ixwrxxi View Post
Provide more info! I love the look.
BoDacious is offline   Reply With Quote
Old 04-25-2013, 08:59 AM   #2785
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
Originally Posted by Se7enrex View Post
Agreed, and understood, however I have been "into cars" for a lot longer than what you are interpreting from my statement, let me clarify. I think it is just the in-between stage that is a tough look. It is like when you grow some hair and are two weeks out from the next haircut. That one picture I guess just seemed to accent everything at once. But spend $5 and paint the FMIC and piping, that is not too big of a jump. My car is FAR from a show car and I like the little rough around the edges, and I LOVE cars that are super beat and the owner embraces the "rat rod" style. But it is that in-between that can look tired.
I digress, no hate though
The fmic has been painted several times not by me and all the piping need to be stripped and prepped. Not a 5 minute job otherwise it will flake off and look like it does now lol...but yeah
King of Poop is offline   Reply With Quote
Old 04-25-2013, 02:04 PM   #2786
Se7enrex
Member#: 124283
2000 RS/STI/WRX
Haha...word...I dig
Se7enrex is online now   Reply With Quote
Old 04-26-2013, 11:37 AM   #2787
djosbun
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
2011 WRX with Custom LED Sidemarker wired as running light and turn signal - YouTube
Did you have to add a resistor to the single side LED blinker, and/or the LED strip?
djosbun is offline   Reply With Quote
Old 04-26-2013, 02:39 PM   #2788
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
I didn't add any resistors. I used 3 of these SMD LEDs behind the side badge and they come prewired with a resistor inline. The strips didn't require anything either.
Old 04-27-2013, 01:06 AM   #2789
Justin V
Member#: 98747
07 WRX
I had my motor out last week and did a few custom things to it.
20G went on as well as a 3" hard inlet so I had to work with the fuel lines, I just got rid of the metal lines under the manifold and ran rubber hoses. I pretty much just followed APS's instructions. I had the harness out too so I did the following,
Engine wiring harness, got rid of the uneeded plugs, air pump delete on my 07, 2x TGV plugs per side, and the air check valve that runs from the pcv to the turbo inlet. Also wrapped the gray part in black now.
I tried to do a wire tuck but Geez there is no room under there.
This is what came out.
Also deleted the oil heat exchanger to fit my EL headers on my 07 wrx.
Pulled the nipple from the waterpump and tapped it for a 1/4 npt plug, I guess next go round I'll just order a 08 wrx pump.
Also order the OEM plug for Legacies and what not without the heat exchanger and removed the nipple by the oil filter.
NEXT UP: temp switch on the I/C to controller the sprayer.
Justin V is offline   Reply With Quote
Old 04-27-2013, 01:29 AM   #2790
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Isnt that a downgrade to remove the oil cooler?
BeBop86 is online now   Reply With Quote
Old 04-27-2013, 06:59 AM   #2791
Erik
Member#: 168774
Nothing crazy, got the idea from someone else in this thread to use the led third brake light off the wrx wing in the rear window, but I wanted to try it at the top instead. Took maybe 5-10 minutes to do, didn't need to extend any wires and they're all hidden behind the headliner and c-pillar trim.
Erik is offline   Reply With Quote
Old 04-27-2013, 11:03 AM   #2792
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
The OEM cooler really does nothing besides lower the oil filter toward ground whacking level. It more keeps oil and water temps consistent between each other then actually cool the oil. Hence the reason why JDM/Sepc-C and RA-R Subys are not running them. If Subaru was truly worried about high oil temps they would be running a line directly through the radiator like an auto trans fluid line or an out front actual oil cooler ....an option on the JDM STi's
I seriously doubt the new Subaru motor design ( the BRZ's turbo motor I think its call a FA20? as to the EJ20) will have one either. Perhaps they will actually go to a real cooler setup for that??
dangerousatom is offline   Reply With Quote
Old 04-27-2013, 11:06 AM   #2793
Ed05WRX
Member#: 319401
05 WRX
WR BLue
Cool mite try that.
Ed05WRX is offline   Reply With Quote
Old 04-27-2013, 01:08 PM   #2794
mrchyes
Member#: 294069
98 Forester
Green
how did you delete the oil cooler? plug the lines going to it? and how does the oil filter mount then?
mrchyes is offline   Reply With Quote
Old 04-27-2013, 02:06 PM   #2795
Justin V
Member#: 98747
07 WRX
I specifically called it a heat exchanger because it is not an oil cooler
I deleted mine its posted above
1. buy a block plug from subaru (or leave in place if connecting a hose between the waterpump)
2. buy a double ended nipple from subaru
3. buy a 08 wrx water pump, tap and plug water pump, cap it off, or run hose from waterpump to nipple by oil filter (in lieu of removing the nipple)
Take off heat exchanger, take of mounting plate, leaving bare block with threaded hole where oil filter would go. Screw in the double sided nipple, then screw on an oil filter.
I did this to run EL headers on my 07 wrx (necessary), and only deleted because I realized it really doesn't do anything to help or hurt the car.
Old 04-27-2013, 03:51 PM   #2796
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
The spec-c and ra both come WITH the external oil cooler though...
Old 04-27-2013, 05:27 PM   #2797
mrchyes
Member#: 294069
98 Forester
Green
3. tap and plug water pump, cap it off, or run hose from waterpump to nipple by oil filter (in lieu of removing the nipple)
awesome, might have to do this on my ej205 build
Old 04-27-2013, 05:35 PM   #2798
WRXGOBerserk
Member#: 328413
2004 Impreza WRX
If all goes well I'll be installing a rear view camera in my trunk key lock early next week. I'll post up some pictures once I get started.
WRXGOBerserk is offline   Reply With Quote
Old 04-27-2013, 07:15 PM   #2799
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Some refer to them as an oil heater. To be fair I wouldn't go out of my way to remove one from a street car. I added a stock one to my 09 WRX, probably the only person to do so. I had an oil temp gauge. The oil lags the coolant about 5-10 min on warmup without, but barely at all with the "cooler". On the hot side the oil only ran a little cooler maybe 5 deg or so with, on hot days a little more. If you dump the stock cooler, make sure you are good and warm or have an oil temp gauge so you don't stomp on it with cold oil. Though Subaru dumped it for US WRX, all ROW WRX and the STI have the cooler/heater.
Any serious cooling needs like an external cooler, the temp varation between oil and coolant is not enough to transfer a ton of heat out of the oil, and you are putting all that load into the cooling system anyways.
Power6 is offline   Reply With Quote
Old 04-29-2013, 09:10 AM   #2800
max_v_2012wrxice
Member#: 324494
2012 WRX limited
ISM
Originally Posted by Bizborky View Post
Wrapped some of my interior
I really dig this. Very clean, I have been looking around and trying to find something clean and worth the money and time to do to the interior pieces.
Does this suede or alcantara last? It looks really nice but I am wondering if it will fade?
max_v_2012wrxice is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 01:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 10:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 02:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 04:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 08:46 PM
