Old 04-21-2013, 04:49 PM   #1
panel
Member#: 352704
1965 Vw panel van
EJ20 Turbo Swap/convo
Default urabuS.....it's in the works!
Hi guys,
First of all I'd like to blame RonW for all of this
Anyway,
This is my first Subaru project. I have never had one and I saw how well Ron's went and asked him enough questions ..........and vwalla! Here I am.
Motor is from a 2000 Forester EJ20T.
The adapter plate/flywheel is from Hecker Machine in Oregon and the stub pipes are from Outfront.
Here's the mill that's going into my 1965 VW panel Van:
The plan is to run a rad similar to this set-up.
panel is offline   Reply With Quote
Old 04-21-2013, 04:52 PM   #2
panel
Member#: 352704
1965 Vw panel van
Here's the flywheel and adapter from Hecker:
And stubby pipes:
Here's a tried tested and proven rad setup:
Old 04-21-2013, 04:54 PM   #3
panel
Member#: 352704
1965 Vw panel van
And the latest ...........a bellmouth that my Dad did:
I will have lots a questions along the way
Old 04-21-2013, 10:37 PM   #4
RonW
Member#: 103663
1968 Porsche 912
STi v8 Spec-C conversion
subscribed!
RonW is offline   Reply With Quote
Old 04-22-2013, 12:08 AM   #5
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
A wasserboxer in a splitty?
Oh man, the guys on thesamba will have your head for this atrocity!
Can't wait to see it! Post some pics of the bus!
Old 04-22-2013, 03:17 AM   #6
MoRex
Member#: 231966
2003 WRX
Pure Silver Metallic
hey Panel, i'm assuming you've seen the ads on usedvictoria offering vw subaru conversions. That's not you i take it... i'm sure those guys'd be willing to offer some advice in person for someone doing this on their own
MoRex is offline   Reply With Quote
Old 04-22-2013, 12:23 PM   #7
Hondaslayer
Member#: 4562
1995 Legacy LSi
Just noticed, you plan on running the stock trans on it? Yikes. Might want to look into a Subarugears reverse R&P setup.
Old 04-23-2013, 12:25 PM   #8
wtyree
Member#: 29879
2002 WRX Wagon
Subscribed.
wtyree is offline   Reply With Quote
Old 04-23-2013, 04:31 PM   #9
amiexploited
Member#: 251061
2002 wrx*just sold
& 2015 WRX
Subscribed as well. Can't wait to see the bus!
amiexploited is offline   Reply With Quote
Old 04-23-2013, 09:49 PM   #10
Type2
Member#: 200436
2004 Forester XT
Subscribed. I own a 78 Westy I've seriously considered doing this on.
Type2 is offline   Reply With Quote
Old 04-23-2013, 11:50 PM   #11
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
Cool! This should make the bus way faster, way more reliable, less noisy, have better heat and it might make it less prone to rollover due to a bit more weight down low. I was a rear passenger and got ejected through the sunroof of one of these in a rollover...
jdogma is offline   Reply With Quote
Old 04-24-2013, 09:41 AM   #12
panel
Member#: 352704
1965 Vw panel van
Hi guys, thanks for following along.
Trans is a Rancho Pro Street with a welded third and for + beef a diff.
There is one guy here in Victoria that is going to help on the wiring part and has been a source of what to keep and not to keep on the motor.
That's exactly what I'm looking for in this conversion.
The old motor was a 2275CC turbo intercooled crank fired Megasquirt powerhouse.
Old 04-24-2013, 12:31 PM   #13
Hondaslayer
Member#: 4562
1995 Legacy LSi
Nice panel!
Question, are your windshields missing?
Old 04-25-2013, 07:51 PM   #14
panel
Member#: 352704
1965 Vw panel van
Originally Posted by Hondaslayer View Post
Nice panel!
Yup they were out getting painted.
Old 04-26-2013, 10:45 AM   #15
Type2
Member#: 200436
2004 Forester XT
Is that 2275cc aircooled with a turbo? What EM?
Old 04-26-2013, 10:52 AM   #16
RonW
Member#: 103663
1968 Porsche 912
I believe he was running megasquirt 2 ms-extra. Panel, is the motor out and sold already or are you waiting til you have everthing squared away then pull it?
Old 04-26-2013, 10:55 AM   #17
Badler
Member#: 133597
Sweet van!
Badler is offline   Reply With Quote
Old 04-26-2013, 03:21 PM   #18
Hondaslayer
Member#: 4562
1995 Legacy LSi
Originally Posted by Badler View Post
Sweet van!
You watch your whore mouth! That's a bus, son!
Old 04-26-2013, 05:49 PM   #19
Type2
Member#: 200436
2004 Forester XT
Ok, so megasquirt is a type of engine management. I didn't know that. I'm assuming this is aircooled then as well.
Old 04-26-2013, 05:50 PM   #20
Type2
Member#: 200436
2004 Forester XT
Sweet van!
The word VAN makes my skin crawl! It's a BUS!
Old 04-26-2013, 08:15 PM   #21
Hondaslayer
Member#: 4562
1995 Legacy LSi
Drove my Westy to work today. I figure it's a beautiful day so I don't mind walking home........
Old 04-26-2013, 10:18 PM   #22
Type2
Member#: 200436
2004 Forester XT
I've had my 78 Westy since 2000. Only broke down once. It was on the way to a wedding, so it broke down in style
Old 04-27-2013, 11:31 AM   #23
Hondaslayer
Member#: 4562
1995 Legacy LSi
I bought into a basket case. It has been a "good" learning experience, but this is the last time I do anything with the word Bosch attached to it
Old 05-05-2013, 02:29 AM   #24
panel
Member#: 352704
1965 Vw panel van
It's not the biggest update like you pro's but....
Got a couple more bits back from my miracle worker
Oil feed from block to turbo:
Coolant on block cut down and re-positioned for heater core delete(for now)
And another coolant mod on the back of the block (cut/shortened re-positioned etc)
And oil drain from the turbo:
Old 05-13-2013, 03:00 PM   #25
Type2
Member#: 200436
2004 Forester XT
Not sure if you already mentioned this, but are you having a custom gas tank built or will the 2.0l engine fit ok in there? Any other cutting required to get it to fit? Are you going to go with air to water intercooler? Are you having the oil pan trimmed?
