Welcome to the North American Subaru Impreza Owners Club Saturday August 2, 2014
Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 04-13-2013, 12:30 PM   #701
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
Got my car tuned from Travis Barnes. He made some very nice changes over cobb ots map. Now thinking I'm going to go stage 3 sometime. My understanding is I need a bigger intercooler, higher flowing injectors, the turbo of course. Fuel pump is done... what the fuel rail?
T_woot is offline   Reply With Quote
Old 04-13-2013, 03:20 PM   #702
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Fuel rails are a great upgrade! Our stock fuel setup makes it to were not all cylinders get an equal amount of fuel in higher rpm. A fuel rail kit will prevent this.
I chose boomba fuel rail kit. Boombaracing.com
cosseywrx is offline   Reply With Quote
Old 04-13-2013, 03:35 PM   #703
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
they make it so cylinder 3 gets fuel last, so if your pump runs out of flow that cylinder leans out first. unless your running a huge turbo and even if you are there are pumps that can flow high enough.
Alaskan EJ20 is offline   Reply With Quote
Old 04-13-2013, 04:10 PM   #704
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
I would not worry about a fuel rail at this point. Injector upgrades with a fuel pump upgrade and the intercooler will be fine. If your planning to go to the point of needing bigger fuel rails then your at the point of popping a stock internalized motor anyway. There are ways to calculate the amount of fuel you actually need. In your case 750cc-850cc injectors would be more than enough on pump gas.
The guys that are beginning to see fuel flow issues are running E85 which requires 30% more flow over regular gas, have built motors, big turbo setups, and injectors that are 1300cc and up.
Seth
P3 Import Autowerks 907-355-6655
P3Auto is offline   Reply With Quote
Old 04-13-2013, 04:51 PM   #705
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
Good to know. I think injectors will be next until I find a sweet deal on an sti tmic and turbo.
Old 04-13-2013, 04:52 PM   #706
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
Appreciate the knowledge.
Old 04-13-2013, 07:45 PM   #707
cosseywrx
Member#: 276443
Im aware of that.
Old 04-14-2013, 11:26 AM   #708
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
I started a thread in transmission/drivetrain and haven't got much help so ill leave this here as a question for a tuner.
I was wanting some input on Clutch kit you guys think I should go with. I'm currently running an ACT HD-SS and its starting to slip after a lot of spirited driving over the past 2 years. Here is my set-up
02 WRX
Built/Stroked ej205
08 LGT gearswap
Runs on E85 with slightly higher comp. Pistons
Turbo is Blouche 18gxt 7cm (quick spool)
SAE CORRECTED DYNO #s
369awhp
360awtq
Uncorrected I believe its
430awhp
421awtq
I also don't have the greatest history with the 02/03 WRX 5speed as alot of people don't, so I need something with a low Shockload to the internals that will still take a little abuse if I slip the clutch.
If you read all of that, I appreciate it and anticipate suggestions.
Thanks.
boostmasterflex is offline   Reply With Quote
Old 04-14-2013, 05:40 PM   #709
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
woukd the blast plate setup with ppg's be acceptable and affordable for your setup?
mikeydrives1 is offline   Reply With Quote
Old 04-16-2013, 06:45 PM   #710
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Put the ACT HD-SS back in it or if you want to go a little stronger go with the ACT XD-SS. You not going to find a smoother clutch for those power levels. You did good if you got 2 years of driving driving hard.
There are other options but the ACT just always seems to be the one I like and the customers like them for drive ability and quality.
Seth
P3 Import Autowerks 907.355.6655
02 WRX
Built/Stroked ej205
08 LGT gearswap
369awhp
360awtq
430awhp
421awtq
Thanks.
Old 04-27-2013, 09:14 AM   #711
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Seth
Spoke to soon. Lost 3rd gear on a slipping clutch going into gear at around 40mph... time for a 6speed. Tired of this.
Old 04-27-2013, 04:41 PM   #712
snowdrift86
Member#: 273920
05 Legacy GT
Regal Blue Pearl
^i can fix that
snowdrift86 is offline   Reply With Quote
Old 04-27-2013, 06:20 PM   #713
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Hes in Texas, you know that tiny state in the south...lol
Old 04-28-2013, 09:12 AM   #714
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Originally Posted by snowdrift86 View Post
^i can fix that
No....this is my 3rd rebuild with LGT gears. No more "Fixing". The first two builds didn't even last 1000miles due to incorrect lashing and poor craftsmanship in the "builds" I then switched shops and got 13000k out of this one. Instead of doing the same thing again, I'm just going to spend the money and do the swap myself. Hell, I could of already bought the swap + extra with what ive spent on rebuilds. Nightmare.
Old 04-28-2013, 09:13 AM   #715
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Very very tiny State. I promise we are not all RedNecks.... I do love my guns though. Ar15 in the car and I carry a micro 1911. Both legal. Notice with our gun laws you see a lot less mass violence... Arm Law abiding citizens no one messes with anyone...Take guns away then non law abiding citizens are the only ones armed...they didn't get the memo.
Old 04-28-2013, 04:33 PM   #716
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
yep, check out our gun laws
Old 05-20-2013, 07:32 PM   #717
exogen
Member#: 355393
03 wrx 4eat
psm
Random question I cant seem to find the awnser to.
Will a 4eat auto tranny from an 06 impreza work in with a 4eat auto tranny i n an 03 WRX?
TIA!
exogen is offline   Reply With Quote
Old 05-20-2013, 07:35 PM   #718
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
i would saw yes but someone else might know for sure.
Old 05-20-2013, 08:04 PM   #719
exogen
Member#: 355393
03 wrx 4eat
psm
Yeh I'm just scared to buy it, throw a TC an valve body done then find out it wont bolt up lol.
Old 05-21-2013, 12:53 AM   #720
yambeezy23
Member#: 347347
2013 Wrx Hatchback
Hey guys! Just got a tune from element and had them install my stage 2 set up.
I have a 2013 base model hatch and now with the invidia n1 single exit, invidia catless downpipe, and cobb short ram intake.
I was hoping to just barely hit the 300 hp mark but i fell a little short.
im running 288 hp at the wheels now and I can feel the difference =)
What direction should I go now??
yambeezy23 is offline   Reply With Quote
Old 05-21-2013, 01:18 AM   #721
cosseywrx
Member#: 276443
Pray the stock motor doesnt go boom.
Old 05-21-2013, 01:50 AM   #722
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Question
Oh yeah, which local dyno did you use? Where are your printed dyno sheets. Please post them.
Nomadgene is offline   Reply With Quote
Old 05-21-2013, 02:19 AM   #723
cosseywrx
Member#: 276443
Romraider or the Ap i assume. I dont mind the romraider software. I beleive it gets pretty close to the right numbers
Old 05-21-2013, 02:38 AM   #724
exogen
Member#: 355393
03 wrx 4eat
psm
Enjoy it, when you get bored you'll need turbo/fueling setup to gain more I think, maybe someone can correct me.
Old 05-21-2013, 02:41 AM   #725
Nomadgene
Member#: 22923
Close counts….in horseshoes and handgrenades. Not much else.
Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune Unabomber Engine Management & Tuning 12 05-05-2014 05:18 PM
Bend, Oregon Tuners Carartist North West Impreza Club Forum -- NWIC 52 10-05-2010 10:07 PM
Tuner is asking me what compression I am using. Ryan314 Built Motor Discussion 7 04-24-2010 05:44 PM
('93-'01) sorry to ask if asked, how do u search ? christurismohk Impreza Forum 1 06-07-2001 10:11 PM
