Old 07-14-2009, 03:15 AM   #1
AraSh
Member#: 211134
2007 Impreza STi
Default How come I Can't see feedback knock correction or fine learning knock correction?
Hi. I just got my tactrix cable 2.0 and installed RomRaider, ECUFlash, and the latest definitions. I have a 2007 wrx tr. My problem is that I can't see the following definitions:
1. feedback knock correction
2. fine learning knock correction
I don't even see those parameters defined in the latest definition i downloaded!
and also right when I connect to my ECU, this option:
-Knock Correction Advance
dissapears!
What do you think is the problem?
Anyway, I'm really trying to look to see if my car is knocking. Do I need to do something else other than looking to log the mentioned parameters?
Thanks a lot
AraSh is offline   Reply With Quote
Old 07-14-2009, 03:53 AM   #2
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
They are vehicle specific parameters and ONLY available/visible in the logger once your laptop is connected to your car via the openport2 cable and the car's ignition is on.
Saying that, I'm not sure they are available on newer models, in which case you would log "knock sum" instead.
dissapears!
The parameters listed in the logger when not connected to your car are generic parameters, and as such some may not actually be availble for your model.
I'm have not logged a CAN model before so I'm afraid I can not say if the parameter shoul'd actually be available or not. You're better speaking with the guys over on the RomRaider forums.
Thanks a lot
As above, log knock sum. Log load, rpm and knock sum, ignition total timing and WB02 (if you have it). Every time knock sum increases, your ECU has determined that knock has occurred. You can then hen check AFR and/or timing at the load and rpm points where knock sum increased and make changes as required.
Leslie.
wrxsti.l is offline   Reply With Quote
Old 07-14-2009, 09:59 AM   #3
Tea cups
Member#: 103136
feedback knock correction and fine learning knock correction are available on all Subarus supported in RR, even those that support knock sum.
Subaru removed knock correction advance in about 07 and later models and added "learned ignition timing". However, I added knock correction advance as an extended parameter for those 07 and later models, so you'll still be able to log it.
As leslie stated, you have to be connected to the ECU in order to view extended parameters as they are ECU specific. If you don't see them after connecting then:
1. You are not actually connected - view the message on the status bar at the bottom of RomRaider and post that up.
2. Your ECU is not supported. You'll need to pull the ROM with Ecuflash and a tactrix cable and submit them.
3. Your using old definitions.
Old 07-15-2009, 08:31 PM   #4
JoeyOKC
Member#: 209486
i actually had this happen to me the other night, but it was random out of the blue. i had to reboot my computer and everything was back to normal. i get quite a few glitches with rom raider and have to restart it and unplug the cable fairly frequently. oh well.
JoeyOKC is offline   Reply With Quote
Old 03-23-2012, 03:07 AM   #5
kaj
Member#: 290109
2005 WRX
i used to be REALLY good at this stuff a few years ago, but have since been out of the game. is there ANY WAY someone can walk me through making sure my definitions are updated. i know there is a folder somewhere where i (IIRC) cut/paste the definition to add "feedback knock correction".
i've tried looking for it once connected to the car. no dice. strange i just updated to the Beta 0.5.4 Beta RC1.
kaj is offline   Reply With Quote
Old 03-23-2012, 08:28 AM   #6
quazimoto
Member#: 70395
Why don't you just update the definitions anyways? If you don't know if they are in date then chances are they are not. Really good at what stuff? Just go to the Program folder in Windows.
Old 03-23-2012, 06:42 PM   #7
kaj
Member#: 290109
2005 WRX
"used to be really good" at updating definitions. i used EvoScan and EcuFlash for a couple years and got used to updating definitions and updating files.. but that was quite a while ago. i'm a bit rusty and don't remember exactly how to do it.
with EvoScan i'd find the coding for the parameters i wanted to log and cut/paste them into the definition files for my car.
i haven't figured out now to update RomRaider yet. i did download the latest beta version of RomRaider, today. so i'm gonna run out and see if "feedback knock correction" appears when connected to the car.
Old 03-23-2012, 07:40 PM   #8
quazimoto
Member#: 70395
The Subaru definitions are complete. You simply remove and replace. All the info is right on Romraider's site. I have never had to do anything with the coding unless I was adding in launch control or adding in something to the editor.
http://www.romraider.com/Documentati...aiderFAQ#toc17
Old 03-23-2012, 09:53 PM   #9
kaj
Member#: 290109
2005 WRX
see? told ya i'm out of practice. LOL. and the fact that RR works different makes it a bit more difficult. cool, man. thanks!
when i open RR it does tell me "car definition file not found. go online to download latest definition file". when i click "yes", it takes me to a page where i previously downloaded and updated the files. that's what had me thinking i did something wrong. i've gotten this prompt since first installing RR. it's never affected the operation of my logging, from what i can tell. it just tells me i may not be able to use the "dyno feature". no biggie.
i went to the link you provided, then found this:
In an effort to support more and new ECU's, a thread has been started in the experimental definitions forum which expands on this official Logger definition. If you have an ECU that is not supported in the official release, then maybe search the experimental forum to see if it has been added.
Experimental Logger Definition Updates
This logger definition is required for use with RomRaider version 0.5.4b RC1 and higher.
which led me here:
http://www.romraider.com/forum/viewt...hp?f=34&t=6681
i think i'm getting closer. thanks for pointing me in the right direction!
Old 03-27-2013, 11:36 PM   #10
Type2
Member#: 200436
2004 Forester XT
Let me know if you can figure this out. I have a 2004 FXT and I need to log feedback knock correction and fine learning knock correction but it's not available. It's updated. I've reinstalled a couple times. I can log pretty much everything else no problems. Wideband, etc...
Mikey is tuning me right now and I'm going to have to log via my Cobb AP (I can log FLKC & FBKC on the Cobb) which is ok, but I can't log my wideband O2 with the Cobb AP so I'll have to shoot a video of my Uego gauge/display which doesn't seem as accurate.
I did read Leslie's quote from 2009 "Log load, rpm and knock sum, ignition total timing and WB02 (if you have it). Every time knock sum increases, your ECU has determined that knock has occurred. You can then hen check AFR and/or timing at the load and rpm points where knock sum increased and make changes as required."
Will that yield the same practical results as logging FLKC & FBKC?
Type2 is offline   Reply With Quote
Old 04-15-2013, 11:06 AM   #11
Type2
Member#: 200436
2004 Forester XT
I have still never figured this out. I can log it just fine in Access Tuner Race so it's not my ECU.
Old 04-15-2013, 11:56 AM   #12
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
There is an issue with the definitions that are loaded up for the car.
endrswrd is offline   Reply With Quote
Old 04-28-2013, 10:04 PM   #13
Type2
Member#: 200436
2004 Forester XT
Not looking for hand holding here, but this is what I am using right now:
RomRaider 0.5.6 Release Candidate 6
logger_v154.zip
ROMRAIDER STANDARD units ECU definitions 0.8.3.1b 10-07-09.zip
I have re-downloaded them and re-installed. Still can't see FBKC, FLKC, etc.
Should I put it on a completely new laptop?
Old 05-13-2013, 12:06 AM   #14
Type2
Member#: 200436
2004 Forester XT
Installed on a different laptop. All the options are there and selected. As soon as it connects with ecu, IAM, flkc and fbkc disappear. This is very frustrating. The options are there right before my eyes, then disappear.
Old 06-17-2013, 06:03 PM   #15
Type2
Member#: 200436
2004 Forester XT
Old 06-17-2013, 06:24 PM   #16
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
What happens if you create a profile with those parameters selected first then try to load it with the car running? E.G. click on file "save profile" then exit romraider. Next with car running open romraider , select file "load profile"?
Worth a try.
Old 06-17-2013, 06:27 PM   #17
Type2
Member#: 200436
2004 Forester XT
They don't even show up. Tried it. I did the video this way so people could see that I actually had it selected and it was appearing on my screen as an option.
Old 06-17-2013, 06:43 PM   #18
nmlittlebigman
Member#: 321409
2003 Big Effing Van
OK I saw that. Have you created and saved any logging profiles without trying to log first?
Old 06-17-2013, 07:17 PM   #19
Type2
Member#: 200436
2004 Forester XT
Yes I did. Actually the one you just saw was me right after a fresh install of RomRaider will all the latest packs. I had never hooked it up to the car. I selected all the parameters I wanted on the left - there are about 3x as many parameters available than what I can use.
I saved the profile, then afterwards I started the camera rolling and connected to the ecu (as you can see in the video).
Old 06-17-2013, 07:25 PM   #20
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Have you connected with ECUFLASH and tried to read a copy of your rom?
Old 06-17-2013, 08:08 PM   #21
Type2
Member#: 200436
2004 Forester XT
It's a speed density Cobb ROM, so I don't think it will read it. But no, I haven't checked.
Old 06-17-2013, 08:11 PM   #22
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Probably not. I bet it's locked.
Old 07-09-2013, 03:32 PM   #23
Type2
Member#: 200436
2004 Forester XT
Problem completely solved. It had nothing to do with me at all. Cobb customer service was able to help me out. If anyone has this issue in the future and also have a Cobb AP installed, email Cobb customer support and they will tell you how to fix it. A guy in the RomRaider forum told me to contact Cobb and said it was something that he's seen a lot of.
Old 01-08-2014, 08:04 PM   #24
enduroxt
Member#: 310796
05 obxt
^ How about if you get the same issue but don't use an AP? I have this exact same problem with my OBXT 05. My tune is opensource.
enduroxt is offline   Reply With Quote
How come we can't drift like the EVO's? dubba you are ex Off-Topic 40 07-31-2004 06:25 PM
How come i can't post attachments? gtr Off-Topic 53 01-15-2003 04:59 PM
How come I can't post pictures Sub25RSDTown Newbies & FAQs 3 01-04-2003 09:10 PM
('93-'01) How come I can't update my pix?? Bahumut Impreza Forum 2 09-07-2001 04:05 PM
how come i can't update my mods? suby ej25 Newbies & FAQs 3 06-26-2001 06:53 PM
