Old 02-13-2013, 05:44 PM   #1
comp1
Member#: 97527
Default 2003 legacy maf
Were on earth do i find my maf sensory on a 2003 subaru legacy and what does it look like
comp1 is offline   Reply With Quote
Old 02-13-2013, 08:26 PM   #2
GrundleJuice
Member#: 165749
In the intake tube before the TB. It will have a plug/wire harness attached to it. It's in a plastic, round housing.
GrundleJuice is online now   Reply With Quote
Old 02-13-2013, 08:53 PM   #3
Elbert Bass
Member#: 283429
2003 Legacy does not use MAF, it has a pressure sensor (MAP). That is located in the top of the throttle body with a 3 wire flat plug.
Old 02-13-2013, 09:35 PM   #4
GrundleJuice
Member#: 165749
On my part
Old 02-13-2013, 11:15 PM   #5
Elbert Bass
Member#: 283429
Originally Posted by RaceFaceXC View Post
On my part
I say we blame Subaru, they were the ones that kept changing it ;-)
Old 02-18-2013, 12:51 PM   #6
comp1
Member#: 97527
Does this sensor normally go out or get dirty causing a no start. the car will start after shooting either into the tb then die after 10 seconds
Old 02-19-2013, 12:04 PM   #7
Elbert Bass
Member#: 283429
MAP does not usually affect starting as there is not enough pressure differential during cranking for it to read. Since it won't fire off without ether and immediately dies I would see if you are getting fuel or have a massive vacuum leak. Do you have any DTC (codes)?
Old 02-20-2013, 11:11 PM   #8
Smitithus
Member#: 346895
I agree with Elbert. It's running for 10 seconds off of the starting fluid you're using, soon as its gone, it has no fuel and dies. Sounds like you're not getting fuel. or your injectors are not firing. MAP is Manifold Absolute Pressure. It detects changes in the air pressure and adjusts air/fuel accordingly. Not as good as a MAF IMO but if I remember right, it should run even without being plugged in. codes?
Smitithus is offline   Reply With Quote
Old 02-23-2013, 01:22 AM   #9
comp1
Member#: 97527
I tried plugging a code reader up i got from the local parts store but no codes at all came up. checked the fuel pump and it is pumping gas. any more suggestion. i thought also it maybe the o2 sensor that has gone out could that be a possibility. didnt check the injector
dont know what else to try
Old 04-29-2013, 02:08 PM   #10
comp1
Member#: 97527
Default car dies after a few seconds apon shooting either in throttle body.
checked fuel pumps gas when turning ignition key is there something that can go out on the car between the fuel filter and the fuel injectors i dont see any thing except a vaccum valve please help guys been dealing with for a long time . when i blow on the line between the filter and ejectors there is no air going through
