Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 04-05-2013, 08:48 AM   #76
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it's useless anyway!
ride5000 is online now   Reply With Quote
Old 04-29-2013, 06:41 PM   #77
jm02466
Member#: 282876
2005 LGT Limited
04 WRX Wagon
Just want to throw in my $.02.
I installed my oil pressure gauge today using this DIY relocation kit. Worked beautifully.
The only hose they had at Home Depot was 18" long. Looks identical to the OP's pic though so i'm not sure if he was mistaken in his post on the length.
I say this because 18" is perfect, I wouldn't want it any shorter.
Just FYI if anyone runs into the same thing, don't fret, 18" works fine.
I Teflon taped everything and no leaks. I used the front galley plug under the alternator.
jm02466 is offline   Reply With Quote
Old 08-17-2013, 09:56 PM   #78
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Bump it up rather than start new, I've got everything but the PSNUT oil galley plug from prosport.
http://prosportgauges.com/subaru-oil-galley-plug.aspx
Since I got the female to female brass fitting from the same aisle, now I'm thinking, why hasn't anyone used a 1/8 male to female instead of the oil galley plug?
If you guys are trusting the female to female, can't I trust a male to female to bolt to the block?
This is the only variation I'm seeing, I'm tired of fighting with this sandwich adapter (unrelated 2.5L life), and would like to utilize the free time I've got rather than wait for a prosport galley plug.
colin1234567 is offline   Reply With Quote
Old 09-09-2013, 10:30 PM   #79
kabz
Member#: 351744
2013 WRX
Because the hole in the block is bigger. It's not 1/8th NPT like the adapter.
kabz is offline   Reply With Quote
Old 09-10-2013, 12:39 AM   #80
SeanThomas
Member#: 367931
Default Newbie help
Hey I can't post a new thread but this seems in topic. My 06 2.5i is leaking oil as a sieve.. It's coming from a sensor on the top left hand side of the motor.. I've seen that oil pressure sending unit is under the alt?? Is this also an oil pressure sending unit?? Or is it another name etc?? Any help greatly appreciated..
SeanThomas is offline   Reply With Quote
Old 10-14-2013, 05:12 PM   #81
MNRZR
Member#: 342857
2005 Legacy GT
For those that have used this method, how are the hoses holding up after a while? My main concern is that the hose is designed to hold the pressure, but can it stand the heat, vibration, etc.?
Thanks to the OP for sharing this great idea!
MNRZR is offline   Reply With Quote
Old 10-14-2013, 10:52 PM   #82
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Mine's holding up great. No problem.
Old 10-14-2013, 11:10 PM   #83
rocketperson7
Member#: 283968
MBP
same here, works flawlessly, never leaks
Old 10-15-2013, 11:11 AM   #84
gijosiahh
Member#: 351807
2005 WRX WAGON
does anybody/the OP know what gauge pod this is? in the pic/video it looks like it's integrated with the cluster bevel, but i've only seen these for 2008+ wrxs...not for any of the earlier years.
Originally Posted by txl146 View Post
gijosiahh is offline   Reply With Quote
Old 10-16-2013, 12:00 AM   #85
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Mine is autometer gauge pod. Look it up on eBay.
Old 11-03-2013, 04:26 PM   #86
Deek
Member#: 145458
2008 rdkls STi
So to confirm, the stock oil pressure sending unit serves no purpose? It's just there, collecting dust under the alternator? Much like the white PCV "sensor" that connects to the inlet back by the turbo?
I'm going to be giving this a shot in a totally different (more volatile) climate, extreme heat on a daily driven built engine. I will try to update with my findings/results.
Deek is offline   Reply With Quote
Old 11-25-2013, 10:47 PM   #87
Aron_WRC
Member#: 337384
I'm totally doing this!! Thanks for the info man!
Aron_WRC is offline   Reply With Quote
Old 11-27-2013, 04:34 PM   #88
turkeylord
Member#: 89016
2005 Legacy GT Wagon
ABP
I think I'll be doing this as well. Any need to fill the tube with oil or is it ok full of air?
turkeylord is offline   Reply With Quote
Old 11-30-2013, 12:55 AM   #89
Amerino
Member#: 298182
If you guys have an 11/32 drill bit and a 1/8''-27 NPT tap you can source an M18 x 1.5mm oil drain plug from an auto parts store in stead of ordering a galley plug online. I got mine from O'Reilly's for about $3 and it took me about 20 minutes to step drill it and tap it.
http://imageshack.com/a/img51/9082/jv7t.jpg
http://imageshack.com/a/img812/6959/a0dn.jpg
Amerino is offline   Reply With Quote
Old 11-30-2013, 12:42 PM   #90
turkeylord
Member#: 89016
ABP
^ Nice!
Here's your Home Depot shopping list...
Old 12-06-2013, 10:47 PM   #91
DeFMaN3o3
Member#: 359901
2002 STI
black
Wow, nice idea. I have prosport oil pressure gauge at home and it hasn't installed yet. I like your idea. I'm gonna buy it all at home depot. Cheaper is better than nothing. Thumb up!!
DeFMaN3o3 is offline   Reply With Quote
Old 12-07-2013, 02:42 AM   #92
Grippen
Member#: 329712
2005 Sti
Very cool
Grippen is offline   Reply With Quote
Old 12-08-2013, 12:50 AM   #93
DeFMaN3o3
Member#: 359901
2002 STI
black
I bought 18' gun grease hose and 1/8 brass coupling at home depot. I'm not sure what you use dielectric grease to put on it. Where to put dielectric grease on it?
Old 12-08-2013, 05:29 AM   #94
pebelz
Member#: 268632
2004 WRX wagon
Suby Blue
It goes on the sender contacts. Silicone tape on threads. Mine still looks brand new after a year of use.
pebelz is offline   Reply With Quote
Old 12-08-2013, 06:56 PM   #95
DeFMaN3o3
Member#: 359901
2002 STI
black
Got it. I'm gonna put dielectric grease on all Teflon tape on every thread, right?
Old 12-09-2013, 05:48 AM   #96
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
grease AND tape?
Old 12-09-2013, 05:58 AM   #97
pebelz
Member#: 268632
2004 WRX wagon
Suby Blue
Dielectric grease on electrical contacts of sender, tape on threads connecting hose, block, adapter.
Old 12-09-2013, 07:27 AM   #98
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sure, that makes sense.
this:
does not.
Old 04-30-2014, 07:57 AM   #99
Keaton522
Member#: 279103
2002 WRX Hybrid
Default thanks!
Just picked up all these parts from home depot... thanks for the great idea! Almost spent $50 on the same thing.
Keaton522 is offline   Reply With Quote
Old 04-30-2014, 03:27 PM   #100
rocketperson7
Member#: 283968
MBP
guys use this instead of teflon tape, works eleventy times better and won't ruin an engine if it somehow makes it into a galley:
http://www.permatex.com/products-2/p...sealant-detail
WTB : Remote Oil Pressure Sender Installation Kit EROCS04SBRUSTI Private 'Wanted' Classifieds 0 12-23-2011 05:10 PM
WTB : Remote Oil Pressure Sending Kit Dborne Private 'Wanted' Classifieds 0 07-21-2011 02:49 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
FS: Oil pressure sender relocation kit. bisonjr MAIC Private Classifieds 0 03-07-2009 06:04 PM
WRXtra Oil Pressure Sender Installation Kit drees Car Part Reviews 1 06-21-2004 08:09 PM
