Old 04-22-2013, 11:33 AM   #1
spiffyriceburner
Member#: 354234
2005 STi
Default 05 STi Headlight Replacement
So my 05 STi has the seemingly common fogged out headlight problem and I would like to replace it. Is there any difference between the regular WRX headlight non-HID and the HID STi housing? Could I transfer my ballast on to a non-HID light so I don't have to spend $500 for a new assembly?
spiffyriceburner is offline   Reply With Quote
Old 04-22-2013, 12:00 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes....suck it up and buy a new one. Or open yours, dry it out, and seal it back up. There are many threads in the lighting forum on how to remove and open the headlights.
Old 04-22-2013, 03:28 PM   #3
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
Yes, the housings are different and new headlight housings aren't cheap. I would follow Unabombers advice and open them up to dry them out and then get some sealant to reseal when you put them back together to avoid them fogging again.
I know the process of baking and splitting the housings is really intimidating, at least I know it was for me, but it's actually very simple and easy to do. Just take your time and it will come out great.
jm02466 is offline   Reply With Quote
Old 04-22-2013, 03:48 PM   #4
spiffyriceburner
Member#: 354234
2005 STi
Oh well that's a bummer. I don't think I have to split it, I think it is the outside of the lens oxidizing. I'm new to this forum so I will do so more searching on the best sealant and way to clear this lens up.
Thanks for your responses though!
Old 04-22-2013, 09:04 PM   #5
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
If its just the outside clouding get a 3M headlight clearing kit. Works well if you take your time. They're like $20 at Harbor Freight. You usually have to redo it every couple years, but its worth it.
We thought you had moisture inside the housing. Hence the baking and splitting.
Old 04-23-2013, 10:57 AM   #6
spiffyriceburner
Member#: 354234
2005 STi
Awesome, I'll go pick one up today! Thanks again for the recommendation.
Old 04-28-2013, 11:18 AM   #7
spiffyriceburner
Member#: 354234
2005 STi
Thanks so much jm02466! I used the kit with the protector for $13 on Amazon and it worked great! Looks good as new!
Old 04-29-2013, 10:23 PM   #8
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
Glad to hear it. That kit works pretty well.
