04-29-2013, 10:23 PM | #401 |
Member#: 268190
TXIC
Vehicle:2005 STi |
Oh okay. Well can you document all the things that you do to the rear end? Also what diff you plan on using?
04-30-2013, 12:00 AM | #402 | |
Member#: 193189
Vehicle:2006 Impreza Black |
I already have a custom rear cradle with a nissan 350Z rear lsd differential. R200 but is much larger than the nissan 240 R200. Im going to run jdm sti rear knuckles and turn down my 350z hub to fit the sti bearing and redrill it for 5x100 bolt pattern. Then use 2 of the short side 350z axles. |
04-30-2013, 12:06 AM | #403 |
Member#: 268190
TXIC
Vehicle:2005 STi |
How much would you charge to make another rear cradle?
04-30-2013, 02:07 AM | #404 |
Member#: 193189
04-30-2013, 08:19 AM | #405 |
Member#: 268190
TXIC
Vehicle:2005 STi |
Pmed.
05-01-2013, 04:23 AM | #406 |
Member#: 193189
05-01-2013, 07:28 AM | #407 |
Member#: 324329
Vehicle:2002 WRX WRB |
Hey man,
I'm in the process of doing an ls1 swap right now (non turboed so your build ****s all over it). What radiator did you go with? Also how much did you drop rack all together? |
05-01-2013, 08:11 AM | #408 |
Member#: 268817
Tri-State
Vehicle:2009 Stg 2+ HB WRX Black |
This build is ridiculous. I check this thread nearly daily, flipping epic. This project got me into welding after seeing some of the work in your earlier posts. Fast forward a few months and hours of helmet time later and i just picked up my first TIG unit over the weekend. I think my 2009 is destined for a V8 swap now.
Really man, amazing work. Last edited by bridgestone24; 05-01-2013 at 08:18 AM. |
05-01-2013, 12:06 PM | #409 | |
Member#: 193189
Its the radiator that was in the car when i purchased it, Mishimoto... Just welded on AN bungs both on the passenger side. I don't remember off hand how far the rack had to go down, it was a good bit, thats why I ended up building custom A-arms and modified front spindles to correct the steering geometry. |
05-01-2013, 02:11 PM | #410 |
Member#: 193189
05-01-2013, 08:13 PM | #411 |
Member#: 268190
TXIC
Vehicle:2005 STi |
Are you gonna paint the diff? And show some pics of the painted cradle
05-01-2013, 08:26 PM | #412 |
Member#: 216116
South East
Vehicle:2014 Impreza Limited Crimson Red Pearl |
Great work
05-01-2013, 08:29 PM | #413 |
Member#: 193189
05-01-2013, 09:02 PM | #414 |
Member#: 268190
TXIC
Vehicle:2005 STi |
Whoops lol it looks amazing!
05-01-2013, 10:00 PM | #415 |
Member#: 294479
dayum dude i am in my calculus class right now and just spend 3/4 of my lecture being amazed by your skills and how sick that car will be when completed. Kudos my dude
05-02-2013, 12:41 AM | #416 |
Member#: 193189
05-02-2013, 06:47 PM | #417 | |
Member#: 324329
That's why I was curious about some of you modifications. Also, have you attempted to do your wiring yet? |
05-02-2013, 07:05 PM | #418 | |
Member#: 193189
the starter / ignition wire is already in the chassis harness on the wirefall, along with the charging lead out of the fuse box. But maybe just me, but wiring is simple if you have some patience. But I have wired a ton of lsx swaps and various honda swaps. I also deleted all the abs system... and took out anything I wasn't going to use... Also just browsed through your thread... the piece I custom machined were to replace the lower ball joint, ( i have custom lower A-arms to correct the steering geometry so I will have no bump steer). They aren't the same as yours for steering... You just have the drop down spacer for the tie rods which in fact really doesn't correct the geometry for the steering rack being lowered. your car will still have bump steer like is setup now. Last edited by TyConway; 05-02-2013 at 07:15 PM. |
05-02-2013, 07:19 PM | #419 |
Member#: 324329
Yeah I'm not that great with wiring. This is my first car I've ever done anything aftermarket too lol. So I'm really intimidated but the wiring. I have a local shop willing to do it for 350. Do you think that's a reasonable price?
05-02-2013, 07:20 PM | #420 |
Member#: 349061
Vehicle:2002 impreza wrx 06 subaru LGT |
looking really really good!!!!! but please paint that idler.
05-02-2013, 07:30 PM | #421 |
Member#: 193189
05-02-2013, 07:31 PM | #422 | |
Member#: 193189
Just buy a stand alone from my friend Chase... ( chasebays.com ) buy the universal application ls1 harness. But they are simple hookup... Not sure what your price would be, I get a good hookup from him... |
05-02-2013, 07:36 PM | #423 |
Member#: 193189
This is to clear up the steering setup on my car... Theres alot more involved than just lowering the steering rack...
When you do this it screws all the geometry up... why I have custom length A-arms and custom built cradle to fix all of this... There isn't a easy fix by adding spacers... Here are three illustrations to help |
05-02-2013, 07:39 PM | #424 |
Member#: 193189
To the first illustration.... you have to think , we are lowering the steering rack... just not lowering the ride height.... thats why the spacer isn't for our application. It would help if the car was just lowered... and the Steering rack in the factory location.
05-02-2013, 07:51 PM | #425 | |
Member#: 324329
