Old 04-27-2013, 09:06 PM   #26
Caged240
Member#: 345254
02 Wrx wagon
Btw I couldn't do the compression test but I figured it out..... The maf is bad
Caged240 is offline   Reply With Quote
Old 04-27-2013, 09:26 PM   #27
flores412
Member#: 337037
03 wrx
black
Or you could call iag and tell them what's happening, 5 bucks says because you said it was never tuned with all that done to it your timing is off intake is going nuts trying to keep the car running because your afrs are f'd and driving it just makes the problem 10xs worse. Don't be Afraid to call shops all they can say is idk, call iag bring it to them and post back up when you find the problem.
flores412 is offline   Reply With Quote
Old 04-28-2013, 09:34 AM   #28
Caged240
Member#: 345254
02 Wrx wagon
Well I'm probably going to take it to TPG it's pretty close to my house and I already talked to them about getting it tuned and looked over but I wana try and figure it out for myself so I can become more knowledgeable on these subaru motors
Old 04-29-2013, 10:53 AM   #29
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
You bought a fully modded car without any decent knowledge of its condition/tune?
Old 04-29-2013, 10:44 PM   #30
flores412
Member#: 337037
03 wrx
black
Yeaaaaaaa. Not to bright of a move.
Old 04-29-2013, 11:03 PM   #31
C3hutson
Member#: 347969
04 STi
JBP
Hohhot the irony.
C3hutson is offline   Reply With Quote
Old 04-30-2013, 10:57 AM   #32
Caged240
Member#: 345254
02 Wrx wagon
Well to the both of u No I knew it wasn't tuned... And it ran fine when I test drove it And drove it home 3 hours and also ran fine the couple of days i drove it around my town.... So I knew what I was getting. And your definition of fully modified ??? The car is far from fully modified
Old 05-05-2013, 10:24 PM   #33
flores412
Member#: 337037
03 wrx
black
Ok but what were trying to get you to understand is that, how do I say this. It's not a civic. You can't just slap parts on and go smash it. No, you buy a part you put it in, you tune it. No if ands or buts unless its a Cobb intake or spt. You will blow your motor. Just trying to help you.
Old 05-05-2013, 10:50 PM   #34
Badler
Member#: 133597
Originally Posted by alecb View Post
This is not good, at all. Stop driving the car before you break it even more. Do a compression/leakdown test.
On the 02-03, yeah, yeah you can. Would it be optimal with a tune? Absolutely. It's 04+ you really have to tune for.
OP, take it to a reputable shop if its over your head. What does AWD have to do with this anyway?
Old 05-10-2013, 10:03 AM   #35
Caged240
Member#: 345254
02 Wrx wagon
Well my subie is awd... So I'm new to awd but in a sense it doesn't have anything to do with it. And I'm just going to swap the motor and then ill take it to the shop that's kinda close to me and have them tune it. But by that time I should be on a rotated setup anyway
Old 05-10-2013, 10:36 AM   #36
4LoveOfBoxer
Member#: 338162
1997 Legacy L Wagon
Green, Black, Burgundy
I guess you can't tell if a vacuum leak is causing the misfire, but make sure all the vacuum lines are on and secured tight. It only takes a small amount of air taken in after the Maf to throw off the A/F ratio. Also don't forget about electrical connections
4LoveOfBoxer is offline   Reply With Quote
Old 05-10-2013, 10:50 AM   #37
subieguy87
Member#: 153412
1998 Impreza wrxRS
Why???
subieguy87 is offline   Reply With Quote
Old 06-03-2013, 12:39 AM   #38
Caged240
Member#: 345254
02 Wrx wagon
Never got around to checking for misfire but I'm not sure what's going on pulled both 2&4 coilpacks and the car ran the same as its been running so I think 2&4 r not working properly and the motor has 300,000 miles on it. I think it's just time for a new motor
Old 06-03-2013, 12:46 AM   #39
fivestringslinger
Member#: 200455
2004 WRX Wagon, WRB
06 Triumph Speed Triple
Replacing a motor to diagnose a misfire? I wish I had figured that out while I was still working in the auto repair biz. I would've hit bonus every month!
fivestringslinger is offline   Reply With Quote
