Welcome to the North American Subaru Impreza Owners Club Friday October 24, 2014
Old 04-28-2013, 05:37 PM   #10326
DownhillSubie
Member#: 342985
99% sure I saw a forum members ride (black hatch, rally bar, bike rack) from this thread at the OC Spring Opener today in NY. I couldn't believe the amount of nicely modded Subaru's at this show, insane!
I was in my Audi though, haha.
DownhillSubie is offline   Reply With Quote
Old 04-28-2013, 07:17 PM   #10327
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Has anyone rolled their rear fenders? Im curious to know what this is on the rear fender lip.
When I started rolling the rears this happened.
Now the inside of the fender looks like this when rolled and its not even flat against the fender. (looks perfectly fine from the outside)
Is it just me or are the rear fenders much harder to roll than normal? Maybe its just me. I cant roll it anymore because the lip just doesn't want to flatten out anymore.
Slow Scoobie is offline   Reply With Quote
Old 04-28-2013, 08:05 PM   #10328
DownhillSubie
Member#: 342985
So which of you have installed coil-overs yourselves? Any DIY's on NASIOC pertaining to our platform vehicle?
Old 04-28-2013, 08:05 PM   #10329
.HaVoK.
Member#: 229726
'09 2.Slow
Yup that was me
.HaVoK. is offline   Reply With Quote
Old 04-28-2013, 08:10 PM   #10330
DownhillSubie
Member#: 342985
Originally Posted by .HaVoK. View Post
Yup that was me
Knew it. Nice hatch and your friends had some sweet cars.
Stupid me, I forgot to look. what trailer hitch do you have? I need to buy one.
Old 04-28-2013, 08:20 PM   #10331
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Almost certain its a paint sealant to prevent oxidation from starting there early. Mine came off as well. I rolled the rears pretty much flat when I did mine. I also resealed the paint where that protective backing came off of.
BSP671 is offline   Reply With Quote
Old 04-28-2013, 08:33 PM   #10332
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Did you use a fender roller or some other method?
Old 04-28-2013, 09:09 PM   #10333
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Originally Posted by fancyfootwork15
Run it for 4k miles then do an oil analysis.
How would I go about doing that? recommend company? And what should I be looking for?
I've only had it in for a day. I was expecting a quieter engine only because some of the boosted guys noticed that when switching to T6.
Old 04-28-2013, 09:38 PM   #10334
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
I use Blackstone Labs. Go to www.blackstone-labs.com You need to request an oil sample kit (free). Once you get the kit in the mail you can choose your payment type. Detailed instructions are included. Send in the oil, turn around date is a couple days.
They have average numbers for every engine type in terms of wear. You would be hard pressed to notice any bit of change instantly. What really counts when it comes to oil is how your engine is breaking it down. A $30 oil analysis here and there can save you thousands in the long run.
fancyfootwork15 is online now   Reply With Quote
Old 04-28-2013, 10:46 PM   #10335
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
I ghetto styled it lol. Used a heat gun, baseball bat and my scissor jack. Had the stock steelies on while doing it. Paint didnt crack or chip. Only on the last front fender cuz I got lazy and didnt reapply the heat haha. Wasnt too bad though. I stopped as soon as I heard it. When I was done I just sealed all the rolled edges with plastidip for good measure.
Old 04-28-2013, 11:17 PM   #10336
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Ok because thats what im doing heat gun rubber mallet and baseball bat. But for the life of me I cant get the rears to roll flat. In the rear its like they doubled up on the fender while the front is single. If that makes any sense
Old 04-28-2013, 11:45 PM   #10337
reide181
Member#: 276915
2011 WRX Limited
Always need more pics! On the topic of fender rolling, I did mine by hand (round plastic object and heat gun). I like doing things myself and I just took my time and made sure to get the paint really hot. I plan to seal the fenders with undercoating this summer when I redo my underbody.
reide181 is online now   Reply With Quote
Old 04-29-2013, 01:19 AM   #10338
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
lolredcurb
JourdanWithaU is online now   Reply With Quote
Old 04-29-2013, 01:45 AM   #10339
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Yeah the rears were a bit harder to roll while the front was no problem at all. How far did you roll them? Maybe you need to roll it a bit further out to help the fenders bend more easily. Only thing I can think of is to use the handle of the bat to push it in more (don't know if that makes sense). I use a diy method on the forums here for reference. What wheel size and offset you plan on running? Tire size also. Maybe you dont need to roll it flat to fit your wheels.
Old 04-29-2013, 07:53 PM   #10340
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Dropped the struts and Konis off today.. Going in soon
Old 04-29-2013, 08:06 PM   #10341
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
so i used my A/C today and i noticed that there wasn't much of a rpm drop or much loss of power. I think it may of been because of changing the coolant out completely. anyone else can confirm?
Navysesal is online now   Reply With Quote
Old 04-29-2013, 08:51 PM   #10342
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
What were you doing when you turned it on?
At idle, the RPMs don't really drop. They kick up when the compressor comes on. If I'm driving and I turn on the AC, I notice an initial choke in power but that's it. Otherwise it's not noticeable.
This is what happens for me at least.
Old 04-29-2013, 08:59 PM   #10343
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
My AC always feels the same.. A small but noticeable loss in power. I counteract that loss of power by revving the engine out a little bit more, maybe 2 or 3 hundred RPM before shifting if I want to accelerate at the same speed. (5 speed) I have the 100,000 mile Subaru Super Blue coolant so I won't be changing it anytime soon- I have 30,000 miles on my car.
BWX is offline   Reply With Quote
Old 04-29-2013, 10:20 PM   #10344
DownhillSubie
Member#: 342985
Any companies make a skidplate for our cars to protect the undercarriage?
They make panzer plates for Euro's so i'm guessing someone HAS to make some sort of beefier belly pan for Subarus. I mean Subarus are the leaders in rough terrain cars.
Old 04-29-2013, 10:52 PM   #10345
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
http://www.get-primitive.com/ - check them out
Old 04-29-2013, 11:18 PM   #10346
Sellars21
Member#: 304055
Originally Posted by Steve2.5i
These look sweet but all I can hear is "rattle rattle rattle" all the live long day. Don't know if I could spend the money on something that would drive me nuts.
Old 04-30-2013, 12:05 AM   #10347
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
I agree but lol that's all I could find for skidplates. Check out dirtyimpreza.com maybe someone has something else :P .
Old 04-30-2013, 03:07 AM   #10348
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
yeah, before it would always choke then the rpm would drop pretty fast in every shift. but it definitely feels like there isn't a huge load on the engine anymore
Old 04-30-2013, 07:06 AM   #10349
campanozzi
Member#: 336415
2011 Impreza limited
lolredcurb
Wow so nice !!
campanozzi is offline   Reply With Quote
Old 04-30-2013, 12:30 PM   #10350
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Finally got a video posted that isn't cellphone quality lol.
I also posted it in the rallisport thread.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
