Old 04-28-2013, 06:50 PM   #26
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
Originally Posted by Guzzi 1 View Post
Same procedure.
John
Thanx
ronjr8102 is offline   Reply With Quote
Old 04-28-2013, 08:05 PM   #27
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by PA452 View Post
Anyone know the sequence for disabling the seat belt chime?
Isn't it something like rapidly plugging and unplugging the seat belt for 15 secs or so? I did this a long time ago, no more annoying seat belt chime for me
Old 04-28-2013, 08:22 PM   #28
PA452
Member#: 346220
2013 Impreza Premium
MT Dark Gray Metallic
I found a couple videos. Apparently you turn the key to the run position, fasten and unfasten your seatbelt 20 times within 30 seconds, and then start the car. I'm going to try this tomorrow.
PA452 is offline   Reply With Quote
Old 04-30-2013, 10:07 AM   #29
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
I think I read on here somewhere that you can disable the chime by keeping the seat belt buckled while you're driving
soobie doo is offline   Reply With Quote
Old 04-30-2013, 12:13 PM   #30
PA452
Member#: 346220
I don't need an annoying chime to remind me to fasten my seatbelt while out on the road. And I certainly don't need it constantly going off when I'm slowly moving the car around in driveways or open spaces, particularly if I'm in a situation where I find myself in and out of the car repeatedly. It's a dummy reminder. Do you need it?
I disabled it yesterday. Turn the key to the run position, fasten and unfasten the belt 20 times within 30 seconds, then start the car. It will beep at you a few times when you first start the car, but no more after that. I was kind of surprised though, it even turned off the seatbelt indicator light on the dash.
Old 04-30-2013, 01:41 PM   #31
ronjr8102
Member#: 216040
dark metallic grey
Wow I'm surprised u could even disable the seatbelt chime. I figured that would be something u can't disable.
Old 04-30-2013, 01:54 PM   #32
wymi
Member#: 351884
Does that also disable the passenger seat belt alert?
wymi is offline   Reply With Quote
Old 04-30-2013, 03:00 PM   #33
Angelus911
Member#: 89967
2012 Impreza Sport
Yes, I believe so
Old 05-02-2013, 06:19 PM   #34
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
key to ON (dont start the car)
buckle/unbuckle like 20-30 times in 30 seconds
repeat for passenger seat
profit
did mine like 2 weeks ago, normally I buckle, but for things like driving from the alley to the front of my house it is super annoying.
Old 05-02-2013, 07:38 PM   #35
wymi
Member#: 351884
Originally Posted by Angelus911 View Post
Yes, I believe so
I just did this procedure to my Impreza and I can verify that it does work to disable the chime and the light. Both the driver and passenger seat belt alerts are completely disabled.
Old 05-05-2013, 11:22 AM   #36
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
They let you disable the chirping for locking and the seat belt alarm... but wont let you turn off the bright yellow light stating I turned off the hill assist. That is the one I wish we could change.
DKsiazek is offline   Reply With Quote
Old 05-05-2013, 07:00 PM   #37
PA452
Member#: 346220
I also wish we had a switch or something for disabling the HSA, instead of putting in a code. Seems like that should be a simple push button option, rather than something you have to check the manual to do.
Old 10-17-2013, 01:40 AM   #38
Socalsuby
Member#: 336947
2013 WRX
Dark grey metallic
Seatbelt chime sequence worked for me but I can't seem to get the damn alarm chirp sequence down
Socalsuby is offline   Reply With Quote
Turning off the Lock/Unlock Beep jcoble Newbies & FAQs 8 11-25-2008 05:16 PM
Lock/Unlock Beep stopped working WRBEJ257 Car Audio, Video & Security 22 11-18-2008 09:45 PM
is there a simple way to make the locks unlock with one push? Matth3w Car Audio, Video & Security 5 11-24-2005 06:11 PM
How to disable remote lock/unlock horn beep? Aken Legacy Forum 12 04-09-2005 12:45 PM
Any way to make the keyless lock/unlock beep/flash instead of honk? Butt Dyno Car Audio, Video & Security 6 03-25-2003 01:50 AM
