Old 04-29-2013, 02:08 PM   #1
Tomnompom
scammer
Member#: 343232
2012 WRX 5DR
Default Back cramp on longer drives
Anyone else's lower back cramp/spaz pretty bad on long drives (30+ minutes) or stop and go traffic? It only effects the right side, slightly to the right of the spine.
I've tried the diy seat mod and variations of it but haven't found a solid solution. Anyone got any methods that may help?
This is in the newer wrx seats.
I'm 195 lbs 5'7", gym junky. I have large shoulders and a 32-33" waist just to give some idea.
Tomnompom is offline   Reply With Quote
Old 04-29-2013, 02:20 PM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Get fatter.
Remove your wallet from your pocket.
Make stops along the way.
get yourself one of those bead seat backs.
Old 04-29-2013, 02:23 PM   #3
alecb
Member#: 335146
2004 STi
Jesus christ man I'm 6'3" and 190lbs lol.
alecb is offline   Reply With Quote
Old 04-29-2013, 02:25 PM   #4
Tomnompom
scammer
Member#: 343232
2012 WRX 5DR
Originally Posted by Loyale93 View Post
Get fatter.
Is this a serious solution?
Doubt my fiance would appreciate me gaining more
Old 04-29-2013, 02:31 PM   #5
XERO287
Member#: 253541
2011 WRX 5DR Premium
Put in Legacy seats.
XERO287 is offline   Reply With Quote
Old 04-29-2013, 02:47 PM   #6
tec_41
Member#: 346278
04 WRX
You could try sitting on a small cushion/pad to elevate your butt. My dad does this on long drives and it helps him a lot...it changes the lumbar support position on your back, which might be your problem if you're a little shorter.
tec_41 is offline   Reply With Quote
Old 04-29-2013, 02:58 PM   #7
greenplates
Member#: 239162
Lean your seat way back. It straightens your back putting more weight on your upper back. And extends your arms out stretching, it feels great
greenplates is offline   Reply With Quote
Old 04-29-2013, 03:35 PM   #8
1wrxtra
Member#: 316364
We're the same height, but you're about 10 lbs heavier than I am, with the same body type. I don't have any issues with cramping, and I often make 1.5 - 2 hr drives. Hell, my drive to work is approx 40 minutes each way, every day.
Post #2 is correct in suggesting to remove your wallet if you keep it in your back pocket.
Otherwise, look into changing your posture. My seat is 1 or 2 clicks back from straight up and down, and my arms are slightly bent to reach 9/3 on the wheel. Have you ever had any other issues with your back? Injuries, strained while lifting, etc?
Old 04-29-2013, 03:44 PM   #9
Ruhh-Roh
Member#: 349889
2007 STi
I say ask a doctor, that doesn't sound like something seat related, mostly because you are feeling pain in a specific area.
Ruhh-Roh is offline   Reply With Quote
Old 04-29-2013, 04:08 PM   #10
az ru
Member#: 342436
http://www.webmd.com/back-pain/guide/sciatica-symptoms
sounds like you have this i have the same problem i hurt my back i go a massage in it goes away for awhile
az ru is offline   Reply With Quote
Old 04-29-2013, 04:18 PM   #11
Tomnompom
scammer
Member#: 343232
2012 WRX 5DR
Thanks for the suggestions, I'll definitely have to see someone then. I do notice if my knees are practically under the steering wheel column it reduces the strain but that's just uncomfortable hitting my knee over every little bump.
It's almost as if the cause of the pain is cause by my right foot letting on and off the gas too much.
I'm surprised WebMD didn't say I had cancer due to the symptoms.
Old 04-29-2013, 04:26 PM   #12
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
practice more yoga.
do you know the steering wheel is telescopically adjustable, aside from the height?
Old 04-29-2013, 05:35 PM   #13
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
I'd say you had a slightly herniated disk in your lower back if it's triggered by extension of your foot etc.. Go get it checked out, I PM'd you a great back doc in Houston that got me 100%.
Napalm3nema is offline   Reply With Quote
Old 04-30-2013, 02:38 AM   #14
775WRX
Member#: 348189
2003 Impreza WRX
Midnight Blue
Most doctors now recommend stomach exercises for people with back problems. I got hit in the trunk twice about a week apart 5 years ago. Saw a physical therapist and a chiropractor for over 2 years and still to this day suffer from lower back and side pain.
Started going to the gym about 2 months back at work and it has helped a lot.
775WRX is offline   Reply With Quote
Old 04-30-2013, 02:40 AM   #15
del_tron
Member#: 277736
2006 Saab 9-2x Aero
Take your wallet out of your back pocket. Seriously.
del_tron is offline   Reply With Quote
Old 04-30-2013, 03:27 AM   #16
eckman
Member#: 96100
'06 Impreza WRX/STi
I'd say you have poor sitting posture. This isn't something you can fix with a different seat or by removing your wallet. This is done by properly excercising the correct sitting posture.
eckman is offline   Reply With Quote
Old 04-30-2013, 03:31 AM   #17
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
You mirin? do you lift weights?
pkluong is offline   Reply With Quote
Old 04-30-2013, 03:34 AM   #18
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
Same except I only get it in the way home from work. 50min commute each way. Nothing in pockets I just readjust my ass and sit up as straight as I can for as long as I can.
Old 04-30-2013, 10:52 AM   #19
DZXN
Member#: 306186
2002 Subaru WRX
As stated in half the posts, wallet. You can also try a very small pillow in the lumbar region of your back. It forces your hips slightly forward and relieves some pain. Stretching before is a good idea too. I have a ruptured L5/S1 and the accompanying sciatic nerve pain, and stretching when I get up, half way through the day, and so forth is the best way to keep the pain away. Or a drip of narcotics.
Lookup sciatica stretches and try those for a while, even if you don't have sciatica the stretches work for lower back pain.
DZXN is offline   Reply With Quote
Old 04-30-2013, 03:44 PM   #20
svxrated
Member#: 352540
WR Blue
im about the same height and weight but don't go to the gym too often cause of work schedule but i take my wallet out and it makes a big difference. i still notice a little soreness in my back when compared to driving my truck.
svxrated is offline   Reply With Quote
Old 04-30-2013, 03:52 PM   #21
C4RBON_F1BER
Member#: 208507
'15 BRZ
This is why I never look at WebMD
+1 on taking wallet out on drives. Helps me a ton.
C4RBON_F1BER is offline   Reply With Quote
Old 04-30-2013, 07:18 PM   #22
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
http://forums.nasioc.com/forums/show....php?t=2499938
Maybe you and rkjunior can come up with something for each other. At least compare posts in your threads.
Gallo2011 is offline   Reply With Quote
