Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 04-27-2013, 08:16 PM   #476
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^ who measured it? and with what?
Old 04-27-2013, 08:41 PM   #477
GrundleJuice
Member#: 165749
Originally Posted by vicious_fishes View Post
drivetrain loss is 25% guys. this has been measured/verified in the past. obviously this will change if you have a light flyhweel, crank pulley, driveshaft or whatever. but stock...
So a wrx loses more hp to the drivetrain than a rs/2.5i just because it makes more power at the crank?
Old 04-28-2013, 06:22 PM   #478
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Originally Posted by RaceFaceXC View Post
Drivetrains loss is more a constant HP than percent of power. For example A 500 WHP car does not make 750 at the crank.
I wouldn't say it's a constant horsepower, that doesn't make sense. That would be saying that your car has negative power at idle. More accurately, it is a percentage of the power but it doesn't apply as a linear function.
Rudgers73 is offline   Reply With Quote
Old 04-28-2013, 06:27 PM   #479
airbornesoldier
Member#: 282013
2012 Subaru WRX
SPW
should of just bought an older wrx?
airbornesoldier is offline   Reply With Quote
Old 04-28-2013, 06:49 PM   #480
GrundleJuice
Member#: 165749
Logic. Get some
Old 04-28-2013, 09:26 PM   #481
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Logic. Get some
Don't understand. You were wrong and I was just offering a more rational answer. The percentage of loss in a mechanical system is a function of the sum off all of the parts that contribute to the inefficiency. When you add up a bunch of mechanical inefficiencies that have different modes of loss (torsional displacement, gearing inefficiency, contact resistance, all different types of inertial forces acting together and against each other) than the total percentage lost is going to vary infinitely. Each part of the system becomes less efficient at different rates for different reasons. You could generalize, but that wouldn't be very logical
Old 04-28-2013, 09:45 PM   #482
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Yes. If a wrx has 200 HP and loses 25% it transfers 150 to the wheels. If an RS makes 170 HP and has the same 25% loss it will transfer about 131 to the wheels.
Look at what we have: wrx - 50 HP loss, RS - 42 HP loss
Old 04-29-2013, 02:02 AM   #483
GrundleJuice
Member#: 165749
They have identical parts, why would they have different parasitic losses?
If one did a wrx engine swap into ones rs would the drivetrain become less efficient because the Engine bolted to it had changed?
Old 04-29-2013, 03:10 AM   #484
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
There's a big techy thread about this deep within the bowels of the drivetrain forum.
Old 04-29-2013, 06:07 AM   #485
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
The efficiency would be the same on the drivetrain. The loss is always a percent of the total power. More power, more loss. 25% of a big number is always going to be more than 25% of a small number. You'll always have more power with an engine that makes more power, but the actual number of horses lost will go up as the total power increases.
Sucks, right?
Old 04-30-2013, 08:59 AM   #486
Special J
Member#: 148045
2006 OBS
Sucks, right?
Your math sucks.
It takes X ft/lbs of torque to twist the input shaft of the tranny (and thereby the rest of the drivetrain). Multiply that times RPMs and divide by 5252 to get the horsepower required. The number you come up with is the drivetrain loss. If it's 50 hp, that'll be 25% of a 200 hp motor, but only 12.5% of a 400 hp motor. The drivetrain torque requirement is static with regards to the motor spinning it; changing that motor only changes the percentage.
If it was always a fixed percentage, regardless of what was spinning it, you'd be able to make your car go by twisting the input shaft by hand, using only 25% of your available hand torque. Try that and get back to us to let us know how it goes. Hint: it won't.
J
Special J is offline   Reply With Quote
Old 04-30-2013, 10:02 AM   #487
GrundleJuice
Member#: 165749
Originally Posted by Special J View Post
Your math sucks.
J
Holy ****, someone with common sense.
I will say that as engine tq increases, shaft deflection increases, presumably increasing parasitic drag through the drivetrain. I would guess that this amount of increased loss to friction is small relative to the overall drivetrain loss.
Old 04-30-2013, 12:07 PM   #488
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Your math sucks.
J
I stand corrected. That makes sense. I knew something was going to be almost a constant. Turns out it was power required to compensate for the loss, not the percent lost
Old 04-30-2013, 11:23 PM   #489
Special J
Member#: 148045
2006 OBS
S'not so common these days.
If only everybody else out there were willing to listen to reason. Good on ya, Rudge.
Old 05-01-2013, 01:56 AM   #490
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
Greyish- Boosted
Did an argument just end peacefully on nasioc?
XSV Klutch is offline   Reply With Quote
Old 05-01-2013, 02:34 AM   #491
Counterfit
Member#: 124254
"The Scoobinator"
No! That's not true! THAT'S IMPOSSIBLE!
Old 05-01-2013, 09:32 AM   #492
Special J
Member#: 148045
2006 OBS
And, lo, there was a great earthquake; and the sun became black as sackcloth of hair, and the moon became as blood; and the stars of heaven fell unto the earth...
Old 05-01-2013, 11:22 AM   #493
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
I guess we could get into an argument about who is gay or who is a total noob, but as long as the right answer comes out of it I am happy haha
Old 05-01-2013, 02:33 PM   #494
Counterfit
Member#: 124254
"The Scoobinator"
Yup, you're the noob.
Old 06-01-2013, 11:22 AM   #495
scoobymatt93
Member#: 254115
2009 Impreza 2.5i
Dark Grey Metallic
Figured I'd bump up this thread to give some feedback. Finally got around to getting Mike to tune my car this year! kept talking about it, but never had the time. I've got the Rallisport v2 UEL headers, Tsudo N1 catback, and a Cosmo SRI. Mike was awesome with the tune and super quick, got everything wrapped up in about two weeks. Final tune feels GREAT. Pulls hard (for what it is) from 1.5k-redline now, used to bog down a lot under 2k and didn't really get power until about 3k-4k. Highly recommend you guys with mods to go get a tune. Makes the car feel MUCH better.
scoobymatt93 is offline   Reply With Quote
Old 06-14-2013, 10:31 AM   #496
kred
Member#: 351724
2006 Legacy GT LTD
Is anyone familiar with the guy on here who got his 2007 impreza 2.5i tuned and made like 189whp/187wtq? I know I saw it somewhere, but I can't find it and there's guys on the legacy forum who are calling BS on this.
kred is offline   Reply With Quote
Old 06-14-2013, 10:39 AM   #497
Counterfit
Member#: 124254
"The Scoobinator"
Those numbers would require a lot of work.
Old 06-14-2013, 12:23 PM   #498
kred
Member#: 351724
2006 Legacy GT LTD
^^^The guy had like a header back exhaust, intake, and LWCP. I've seen it somewhere, but where?
Old 09-20-2014, 11:11 PM   #499
Garret 2010i
Member#: 355661
2010 Impreza 2.5i
WR Blue
this was a great read, looks like i need to contact mikey and get my 2010 tuned up right!
this is an older thread, maybe we can get some new guys and see it we can get him to do another group buy.
see if i can break the na hp record, lol
Garret 2010i is offline   Reply With Quote
Old 09-24-2014, 08:34 PM   #500
Garret 2010i
Member#: 355661
2010 Impreza 2.5i
WR Blue
well i went for it, getting her tuned by mikey!
Forgetting Sarah Marshall: The Grandma's Boy of 2008. eurojax Off-Topic 91 09-14-2011 10:35 PM
God Grew Tired of Us: The Lost Boys of Sudan chkltcow Off-Topic 9 01-08-2007 12:40 PM
The Blind Boys of Alabama... CandyO Off-Topic 7 03-14-2005 07:11 PM
why do women like the bad boy image? linux>windows Off-Topic 33 06-11-2004 06:03 PM
So why do good girls like the bad boys? jashon Off-Topic 56 12-23-2002 10:05 PM
