Old 04-29-2013, 01:05 PM   #1
PinkSTI550CC
Member#: 331903
Default Ej22 with Ej25 Head.
Can i use EJ22 short block with ej25 sohc head? Just for a good running engine.
PinkSTI550CC is offline   Reply With Quote
Old 04-29-2013, 02:17 PM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
You can, but the compression ratio will be lowered some, so it will probably make less power than a stock ej22
cal_look_zero is online now   Reply With Quote
Old 04-29-2013, 03:42 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
What years are you working with? Phase II EJ22 and Phase II EJ25 heads share the same combustion chamber, valvetrain and timing components. Compression will not change in that scenario.
Phase I EJ22 heads had a smaller combustion chamber and would therefore lose a slight amount of compression. Not enough to notice.
Jay
Old 04-30-2013, 09:05 AM   #4
PinkSTI550CC
Member#: 331903
Phase 2 EJ22 because of the single port, EJ25 is from a Legacy 2000. I just want to know if i can keep it as a spare motor.
Old 05-02-2013, 12:20 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
There are still 2 types of single port EJ22 heads. Do yours look like EJ25 heads (can you see the headbolts with the valve covers on? If you can see them, it's still phase I. If they look like EJ251 heads (big flat valve covers), then it's a true phase II head.
Jay
Old 05-05-2013, 04:27 PM   #6
PinkSTI550CC
Member#: 331903
Looks like the ej251,
