Old 05-02-2013, 01:24 AM   #1
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Default good time to build motor?
I have a stage 2 protuned with some extras and the car has almost 130 k and its running great right now bit the more the miles rack up the more I worry bout possible engine issues that may pop up. So what is like to know is at around what mileage would be a good time to take the engine out and have it looked at and build it up a bit. I don't really want to make much more power than what I have but is like the car to last as long as possible. Also what are some good parts motor wise to make it reliable when I do the build. I know forged pistons will be on the list and want the short block cleaned and machined of needed and maybe have the heads worked on a bit but the engine internals is something im not to educated in so im just looking for some input on when and what to do to the motor to keep her going for few 100 more k. I drive the car the way it was built to drive but nothing to crazy im still on stock clutch if that says anything on my driving style so I really don't beat on it to hard. Its my dd so I just want to plan ahead so I don't have to fix things as they come.
Thanks, Corey
Coreycarlile911 is offline   Reply With Quote
Old 05-02-2013, 04:17 AM   #2
Bru1212
Member#: 178770
06 STi
04 FXT
You could get a compression test done and that'll tell you if sooner is better or completely put your mind at ease.
Bru1212 is offline   Reply With Quote
Old 05-02-2013, 06:35 AM   #3
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
If it ain't broke don't fix it.
Do a compression test and a leak down test, if it all checks out ok leave the car as is. Worry about building the engine when it fails.
If you must rebuild,Forged pistons and all new bearings. A thorough cleaning and measuring and that should be all you need for your goals
SpongeBobSquarePants is offline   Reply With Quote
Old 05-02-2013, 12:10 PM   #4
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Yea I kinda thought the same for while but i feel like if i wait till something breaks it could cost me extra than doing it early and id have less of a chance of being stranded somewhere when there is failure. I will do the compression test tho I haven't yet cuz the car runs great. I just don't really know how long a moded sti is gonna last. I was really surprised it has lasted this long. Knock on wood lol
