Old 01-23-2013, 10:02 PM   #1
BoostinX
Member#: 162458
02 WRX
Default 2.0L cooling issue PLEASE HELP!
I have done alot of searching reguarding the cooling system and bleeding air from the system, and have only found situations similar to mine. Looking for some advise/direction from anyone...
Problem: Can not get air out of cooling system and thermostat will not open, also cooling fans will run non stop..probably to keep motor cool because T stat isnt opening...
Just had the motor out of the car for last few months for little refresh, did not touch rotating assembly, but replaced headgaskets. Also replaced most all other gaskets/hoses/seals etc, new oil pump, water pump, cooling tubes, rubber hoses, new t stat, timing components. Have bleed sys multiple times, can get tstat to open and almost all air out, but next day or after a drive it closes back up and lower hose is cold? There are also no coolant leaks anywhere at this time...
My questions are...has anyone experienced anything similar? Do you know how air could continue to get into the cooling system? Why I may not be able to get all air out? Headgasket problem/combustion leaking by?
Any input is greatly appreciated
BoostinX is offline   Reply With Quote
Old 01-24-2013, 12:08 AM   #2
jvallepu
Member#: 325769
Do u have bubbles in ur coolant res? I always simply fill the radiator then fill the turbo coolant res and run it. it bleeds itself just keep an eye on the coolant level on the radiator res. keep it full. Also check if ur system is building pressure.
jvallepu is offline   Reply With Quote
Old 01-24-2013, 12:58 AM   #3
wrxkid157
Member#: 201046
2004 WRX
^^^^take the caps off the coolant for a while until all the air bubbles bubble out. (it my take some time) and the T-stat you put in might be a faulty one.
wrxkid157 is offline   Reply With Quote
Old 01-24-2013, 01:08 AM   #4
CanadianImprezaSTi
Member#: 312159
2004 WRX
It does sometimes happen that the T-stat is faulty. You can throw it in a pot of boiling water when you get it new to test it. Takes 5 minutes and you know it's good.
However, since it's in there. Do as the other guys have said. Start it up and look in the rad cap to see if bubbles are forming.
CanadianImprezaSTi is offline   Reply With Quote
Old 01-24-2013, 08:54 PM   #5
killacam661
Member#: 341930
o3 wrx
Psm
i ran my car for 15 min with no radiator caps after my head gasket change last week. takes a couple times but just add coolant to the res after a drive if its low... itll become filled and stable
killacam661 is offline   Reply With Quote
Old 01-24-2013, 09:09 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
which direction did you install the thermostat?
Old 01-24-2013, 11:56 PM   #7
BoostinX
Member#: 162458
02 WRX
The tstat is installed correctly, spring towards motor...pretty sure it only goes in one direction...it is also brand new form subaru and I did test it in boiling water and it did open. There are bubbles in my coolant res, I have been using a spill proof funnel on the upper res and have ran the car multiple times, each time burping the sys from upper hose and running the motor and each time there are bubbles in the res. I can get 95% of bubbles to go away, tstat is open whole cooling sys is operating correctly, heat in the cabin and not over heating.
Thing is after that, top off over flow res and install radiator cap...then go for a drive, not long after the fans will kick on full blast and stay on, lower hose and tstat housing will be cold, and vehicle has been at operating temp the whole time. Next morning the overflow res will have dropped from the full mark? and fans will still run and tstat won't open again.
Old 01-25-2013, 06:30 AM   #8
quazimoto
Member#: 70395
Maybe your water pump is borked.
Old 01-25-2013, 11:07 AM   #9
PSBeachBum
Member#: 279870
2005 WRX Wagon
maybe a backward head gasket? dunno how thats possible but never know.
or maybe small animal got into the coolant piping and in now stuck on the thermostat
PSBeachBum is offline   Reply With Quote
Old 04-23-2013, 08:16 PM   #10
rexrexwrx
Member#: 327497
2004 WRX
gray
What did u come up with I'm having the same problem any info would help
rexrexwrx is offline   Reply With Quote
Old 04-23-2013, 09:43 PM   #11
DabiDa
Member#: 307041
2002 impreza wrx
psm
Are the gasket seals on the cap ok?My buddy had a issue with his 03 bugeye boiling and could not find the problem so we got a new cap for the turbo res and bam was just a faulty gasket that would let air in and out..
DabiDa is offline   Reply With Quote
Old 04-23-2013, 11:57 PM   #12
wrx1392
Member#: 342331
2003 wrx
blue
drill a small 1/8" hole in the Tsat .
wrx1392 is offline   Reply With Quote
Old 05-02-2013, 10:30 AM   #13
cranky18
Member#: 250565
2002 Impreza WRX
Yellow
Having the same problem on my 02 after a headgasket replacement. What temperature do the fans come on at?
cranky18 is offline   Reply With Quote
Old 05-07-2013, 11:04 PM   #14
subaru_gc8
Member#: 29292
2004 WRX wagon
did you guys get the heads resurfaced? before you put the back? here is a test to know whats going on
http://www.autozone.com/autozone/acc...er=391378_0_0_
get one and know if the head gasket is sealing properly
Old 05-08-2013, 12:05 AM   #15
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
Leave radiator cap on and burp system through res tank, no overheating here in az
wikedcobra312 is offline   Reply With Quote
Old 05-08-2013, 01:09 AM   #16
lagwagn
Member#: 161287
2004 impeza wrx
black stageII
Have you turned the heat on full while bleeding the system?
lagwagn is offline   Reply With Quote
Old 05-08-2013, 04:44 PM   #17
CalvinT
Member#: 329025
2002 WRX Wagon
This makes no difference. Coolant always flows through the heater. There is no coolant valve for the heater.
CalvinT is offline   Reply With Quote
Old 05-08-2013, 05:45 PM   #18
Mishimoto
NASIOC Manufacturer
Member#: 207954
+1 on this question and suggestion. Depending upon the head gasket failure you may have warped the heads. The tester shown is a great way to identify failure.
Mishimoto is offline   Reply With Quote
