Old 05-01-2013, 10:44 PM   #1
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
Default Perrin Inlet to stock BOV - issue
I'm trying to finish my WRX swap and it came with a Perrin Inlet hose.
I decided to leave the perrin inlet on the motor. I then found I was missing the stock BOV recirculation hose so I ordered that because I'm running the stock BOV. So tonight I removed the plug that was in the perrin inlet and tried connecting the BOV recirculation hose to it and it won't fit.
Does anyone know if there is a adapter or something I can buy from my local autoparts store? If so, what size?
noTe is offline   Reply With Quote
Old 05-02-2013, 01:44 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
I have a Perrin turbo inlet with a stock BPV hose and it fits. Maybe it is snug since the hose is new. What is not fitting?
jebjkey is offline   Reply With Quote
Old 05-02-2013, 07:49 AM   #3
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
Mine looks like first picture below (I know it's a Evo inlet but anyways), there is no tube inside where the stock BPV hose goes. I'm not sure if I have a old version of the inlet or the previous owner of the motor just threw the piece away since they blocked it off. The stock BPV hose is smaller than the hole in the inlet
This picture below looks like it has a adapter piece already inside
Old 05-02-2013, 08:10 AM   #4
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
Here is a picture of the plug that was in the perrin inlet, against the BPV pipe
Old 05-02-2013, 08:15 AM   #5
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
You are missing the piece of aluminum tube that inserts into the inlet. You slide the tube half way into the inlet and leave the other half for the recirc valve hose.
Old 05-02-2013, 08:17 AM   #6
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
Do you know the size of that tube by chance? My only thought is going to home depot to see if they have anything.
Old 05-02-2013, 08:28 AM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Did you try calling Perrin or the vendor you bought the hose from? I'm sure they would send you one.
Old 05-02-2013, 08:33 AM   #8
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
I didn't buy inlet, it came already installed on the motor I purchased.
This picture below on Perrin's website looks like it's actually manufactured with the piece already in the silicone?
I guess I'm going to have to visit home depot to see if they have something. If I knew this was going to be such a PITA, I would have put a stock inlet on before I put this motor in.
Old 05-02-2013, 10:12 AM   #9
jebjkey
Member#: 73884
16 HyperBlue STi
I think you have a v1 of their turbo inlet. V2 has the molded-in BPV connection. Hope you can find a piece to make the connection. If not I guess a new turbo inlet is coming your way.
Old 05-02-2013, 10:33 AM   #10
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Hmm, you could still give Perrin a call. Tell them the situation, and I'm sure they can give you some sort of clue, or be able to sell you the correct piece.
Old 05-02-2013, 01:24 PM   #11
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
I spoke with Mladen @ Perrin and he was able to sell me the piece I needed. Thanks all for the help!
Old 05-02-2013, 02:28 PM   #12
PERRIN_Mladen
Member#: 339582
2014 Limited BRZ
CBS
I'm glad we were able to get you taken care!
Let me know if you need anything else. I've sent you the copy of the instructions in the email as well, so I hope that makes install pretty easy. If you have any further questions, just give us a call again!
PERRIN_Mladen is offline   Reply With Quote
Old 05-04-2013, 01:41 AM   #13
NSOM005
Member#: 308369
2006 Impreza WRX STi
Mladin, it turns out that I need that exact same piece. What is the proper name of the piece and where can i order it??
NSOM005 is offline   Reply With Quote
Old 05-04-2013, 07:54 AM   #14
jebjkey
Member#: 73884
16 HyperBlue STi
Call Perrin.
Old 05-04-2013, 09:37 AM   #15
NSOM005
Member#: 308369
Mmm, wink* Top Secret G14 Classified stuff huh? I read ya... Thanks!
Old 05-04-2013, 09:57 AM   #16
jebjkey
Member#: 73884
16 HyperBlue STi
Old 05-04-2013, 03:13 PM   #17
noTe
Member#: 87332
2001 WRXed L Coupe
2015 WRX Limited
On the invoice they sent me, this is the part #: X-PSP-INT-401 - Coupler 1.25 Od Polished
Call (503) 693-1702 and ask for Mladen, he'll take care of ya. He told me they are out of the part but it should be back in stock sometime next week.
