Old 04-28-2013, 02:35 PM   #1
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
Default Boost loss
Hey guys,
i noticed today that my boost was significantly lower than normal, i was tuned at 22lbs and boost gauges is showing 15 with a spike at 20lbs on initial take off. I started thinking boost leak and check all the hoses but then i noticed a little tear on my inlet.
i was wondering if there are any temporary patches i can apply to see if the car will return to my tuned 22lbs when covered. I dont want to have to replace the inlet if thats not the cause of the problem.
All help is appreciated! thanks guys!
edit*
i also have an aftermarket venair turbo inlet pipe, which i believe is silicone
pointblink19 is offline   Reply With Quote
Old 04-28-2013, 06:18 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
if there is a tear in your inlet...then thats your problem
Shortpersonbk is offline   Reply With Quote
Old 04-28-2013, 06:47 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Duct tape MIGHT cover it, but just buy a new inlet and be safe.
Old 04-28-2013, 07:58 PM   #4
Member#: 301037
2004 Forester XT
Replacing it is the safe bet. Depending on the size of the rear it could lean the car out.
art@grimmspeed is offline   Reply With Quote
Old 04-28-2013, 08:44 PM   #5
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
thanks for the imput, will purchase a new inlet, my AFR gauges reads normal so thats good, hopefully that will be the only thing i need to replace
Old 04-28-2013, 08:45 PM   #6
Shortpersonbk
Member#: 319017
15 Prius
if its torn i don't see how its reading normal ....
Old 04-28-2013, 09:46 PM   #7
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
its not technically torn, it looks like there's a tear but it may only be superficial, might not have made its way all the way through the inlet. Hmm this makes me think this might not be my problem. I've checked all the possible vac lines and they all feel smooth so i dont think there's a leak there.
a buddy of mine told me to check the bpv gasket so i may just repalce that to see what happens.
Old 04-29-2013, 07:19 PM   #8
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
I did some data logging with my AP just to check if it was the gauge that was reading wrong but nope gauges read correctly and i'm only hitting about 14-15psi;
i'm going to replace the bpv gasket to see if that has any effect
Old 04-29-2013, 08:50 PM   #9
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
$90 bucks ebay silicone inlet and done.........squeeze it under the manifold.........installed and reinstalled one 2 or 3 times, takes a bit of cussing. Reinstall was done a couple times to check the compressor wheel because i thought i lost the turbo (on old setup).
Secure the shaft of the inlet with 2 or 3 worm clamps along the straight of the inlet to ensure it wont collapse under boost. My did not collapse until 27psi, and when it collapses you will know.
You go from turbo to......this car does have a turbo right? The car will feel like it is NA in boost when it should be the other way around.
Dr. octagon is offline   Reply With Quote
Old 04-29-2013, 09:25 PM   #10
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
I was told in earlier posts that the car would be leaning out if it were the inlet, which it is not so im not convinced i need a new inlet yet, the car is running smooth and i am able to boost at a constant 15lbs, but im tuned at 22psi so im not sure why its not holding up to 22psi, if the bpv doesn't solve my problem, my next step was to soap and water the hoses and see if there are any bubbles.
you guys got any pressure points i should be checking the most?
i'm going to do the inlet, the boost controller hoses to the wg and turbo, and the bpv hose
Old 04-30-2013, 10:25 PM   #11
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
just picked up a oem bpv gasket and replaced the old one, the old on on the car was spliced into two pieces so this may be the problem. Will do some logging when i get a chance to see if it is this simple fix
Old 05-01-2013, 12:53 PM   #12
RichImpreza02
Member#: 106440
2004 WRX
ive been hunting a phantom boost problem for longer than id like to admit. Did the soap and water trick last fall on practically the entire engine bay, BPV gasket replaced, turbo replaced, IC hose clamps all replaced.
Just a few weeks ago got under the car to regrease bushings and figured i'd soap and water spray the exhaust one more time....found the leak between manifold and up pipe on the top side where it's hard to see but is clearly spitting when sprayed.
2 gasket attempts later, still some spitting so i'm wondering if the flange weld is cracked so i'll have to either pull the UP or get in there with some dental mirrors or something...
Check the exhaust.
RichImpreza02 is offline   Reply With Quote
Old 05-01-2013, 01:00 PM   #13
xBlaze89x
Member#: 355156
BPV on my car was leaking. RTV often needs to be added between the elbow and the BPV. A new gasket should take care of between the intercooler and BPV, but if it is still having problems you could RTV that as well.
xBlaze89x is offline   Reply With Quote
Old 05-02-2013, 12:03 AM   #14
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
thanks for the imput fellas, gonna do some logging when im not working all day and night LOL, hopefully i'll get an answer this weekend.
Old 05-02-2013, 03:40 PM   #15
greenplates
Member#: 239162
replace that sonbich
greenplates is offline   Reply With Quote
Old 05-05-2013, 03:00 PM   #16
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
so i did some logging this weekend and still stuck at 15lbs, afr is good, so im gonna soap and water all the lines see if theres a small leak somewhere
Old 05-08-2013, 04:55 PM   #17
danger1138
Member#: 279525
04 rex luger!
I did a diy boost leak tester on mine using soapy water as well, found out mine was leaking the bpv gasket. Tried a new gasket applied the test and was still leaking. My problem was solved by scraping off the residue of the old bpv gasket on the sti tmic flange. There were spots on the glange that still had portions of the old gasket still there. I scraped it off with a blade and now im good to go. Also found small leaks on the maf o ring, and the fuel pressure regulator..
danger1138 is offline   Reply With Quote
Old 05-10-2013, 04:01 AM   #18
subaru505
Member#: 321645
03 03 rsti
black
its the process of elimination just fix it (cause it does need replacing ) and if thats not it then move on to the next possible thing case closed
subaru505 is offline   Reply With Quote
Old 05-16-2013, 07:49 PM   #19
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
i was talking to a buddy of mine who is a great mechanic and has been working on subarus for a long time, told me it may be the ebcs that's gone bad. I contacted grimmspeed who told me it was very rare that they go bad but sometimes they do.
told me to hook up a 9-12volt to the ebcs to see if it opens and closes. will do that when i get a chance and get back to you guys.
Old 05-17-2013, 11:21 AM   #20
tec_41
Member#: 346278
04 WRX
Why don't you post up some logs, too? It wouldn't hurt.
tec_41 is offline   Reply With Quote
Old 05-18-2013, 01:57 PM   #21
Sypher
Member#: 106366
2006 WRX
One thing I noticed you guys did NOT warn the opp of is whether or not he had this tare when he was tuned it just wasnt that bad. Meaning if you put on a APS or a free flowing one compared to stock TRUST ME you will need a tune and a maf rescale more then likely. Take it back to your tuner once your done but keep an eye on your AFR's and boost. Also ask your tuner if he took out the open loop closed loop delay, if they did then feel free to enjoy the extra spool up compared to stock, if they did NOT, do not full throttle the car your AFR's will be slightly different.
Sypher is offline   Reply With Quote
Old 05-18-2013, 02:31 PM   #22
Nolanb121
Member#: 343531
Try replacing gaskets
Nolanb121 is offline   Reply With Quote
