Old 05-02-2013, 02:27 AM   #26
zandander
Member#: 281895
2005 Impreza WRX
Got the tracking on the rad and it SHOULD be here Friday
My only issue right now is my closest subaru dealer is 80 miles away, so i can t easily get the coolant conditioner :/
Thoughts?
zandander is offline   Reply With Quote
Old 05-02-2013, 07:22 AM   #27
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
My Aluminum radiator lasted 4 years.
You would think that because it has aluminum endtanks it will last a long time, but it springs a leak in the fins section.
It does have increased capacity, which helps with the cooling but adds couple pounds at the tip of the nose of the car and makes it impossible to do a timing belt without removing it first.
Old 05-02-2013, 03:42 PM   #28
greenplates
Member#: 239162
coolant conditioner?
dude go to your local auto parts store and fill with 50/50 coolant. done.
NOTE: you may have to trim your radiator hoses SHORTER to compensate for the larger radiator
greenplates is offline   Reply With Quote
Old 05-03-2013, 06:24 PM   #29
zandander
Member#: 281895
2005 Impreza WRX
Got the radiator put in!
Had to trim the hoses to get it in there good but other than that not a problem. Still in the process of getting all the air out but I think it went pretty well.
Old 05-03-2013, 11:37 PM   #30
Mental
Member#: 321773
2005 WRX
I just had the same thing happen... I'm thinking GMS as well. Does the stock radiator cap work with it?
Mental is offline   Reply With Quote
Old 05-03-2013, 11:59 PM   #31
zandander
Member#: 281895
2005 Impreza WRX
It came with a cap. I didn't even try the old cap to be honest.
Old 05-04-2013, 12:24 PM   #32
wrxlaunch
Member#: 181298
Keep oem cap on reservoir next to turbo and new one on the radiator if it allows.
Old 06-17-2013, 03:10 PM   #33
mikesh_21
Member#: 337809
Sadly the insurance totaled my baby due to hail so all that work is gone to the wayside.
So, the RAD and upper and lower hose are for sale now. Check the FS Classifieds or PM me.
mikesh_21 is offline   Reply With Quote
