Old 04-29-2013, 10:23 PM   #401
05subysti
Member#: 268190
2005 STi
Originally Posted by TyConway View Post
It was the mishimoto that was in the car when i bought it, i just changed the location of the inlets and outlets.
yes, just have to go turn down the hub and get it redrilled for the correct lug pattern. just haven't had time to go to my friends machine shop.
Oh okay. Well can you document all the things that you do to the rear end? Also what diff you plan on using?
Old 04-30-2013, 12:00 AM   #402
TyConway
Member#: 193189
2002 wrx
I already have a custom rear cradle with a nissan 350Z rear lsd differential.
R200 but is much larger than the nissan 240 R200.
Im going to run jdm sti rear knuckles and turn down my 350z hub to fit the sti bearing and redrill it for 5x100 bolt pattern. Then use 2 of the short side 350z axles.
TyConway is offline   Reply With Quote
Old 04-30-2013, 12:06 AM   #403
05subysti
Member#: 268190
2005 STi
How much would you charge to make another rear cradle?
Old 04-30-2013, 02:07 AM   #404
TyConway
Member#: 193189
2002 wrx
Pm me.... What rear diff are you planning on using?
Old 04-30-2013, 08:19 AM   #405
05subysti
Member#: 268190
2005 STi
Pmed.
Old 05-01-2013, 04:23 AM   #406
TyConway
Member#: 193189
2002 wrx
rear cradle bolted in for the final time...
Old 05-01-2013, 07:28 AM   #407
Strangerdanger
Member#: 324329
Hey man,
I'm in the process of doing an ls1 swap right now (non turboed so your build ****s all over it). What radiator did you go with? Also how much did you drop rack all together?
Strangerdanger is offline   Reply With Quote
Old 05-01-2013, 08:11 AM   #408
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
This build is ridiculous. I check this thread nearly daily, flipping epic. This project got me into welding after seeing some of the work in your earlier posts. Fast forward a few months and hours of helmet time later and i just picked up my first TIG unit over the weekend. I think my 2009 is destined for a V8 swap now.
Really man, amazing work.
bridgestone24 is offline   Reply With Quote
Old 05-01-2013, 12:06 PM   #409
TyConway
Member#: 193189
2002 wrx
Originally Posted by Strangerdanger View Post
Hey man,
Its the radiator that was in the car when i purchased it, Mishimoto... Just welded on AN bungs both on the passenger side.
I don't remember off hand how far the rack had to go down, it was a good bit, thats why I ended up building custom A-arms and modified front spindles to correct the steering geometry.
Old 05-01-2013, 02:11 PM   #410
TyConway
Member#: 193189
2002 wrx
Rear diff after glass bead blasted.
Old 05-01-2013, 08:13 PM   #411
05subysti
Member#: 268190
2005 STi
Are you gonna paint the diff? And show some pics of the painted cradle
Old 05-01-2013, 08:26 PM   #412
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
Great work
Imprezzedwitsubies is offline   Reply With Quote
Old 05-01-2013, 08:29 PM   #413
TyConway
Member#: 193189
2002 wrx
Pics are posted a few posts up....
Old 05-01-2013, 09:02 PM   #414
05subysti
Member#: 268190
2005 STi
Whoops lol it looks amazing!
Old 05-01-2013, 10:00 PM   #415
2011WRX420
Member#: 294479
dayum dude i am in my calculus class right now and just spend 3/4 of my lecture being amazed by your skills and how sick that car will be when completed. Kudos my dude
2011WRX420 is offline   Reply With Quote
Old 05-02-2013, 12:41 AM   #416
TyConway
Member#: 193189
2002 wrx
LOL , Thanks
Old 05-02-2013, 06:47 PM   #417
Strangerdanger
Member#: 324329
Yup. I only dropped mine an 1 inch roughly. I mounted mine high. I was more worried about bump steer than hood clearance. I don't know if you've looked into my build at all. I modified a 240 sx rack to fit (more steering angle drift car ****) but with that I purchased beefy inner and outer tie-rods. Those came with the same piece your friend made to lower the ball joint location.
That's why I was curious about some of you modifications. Also, have you attempted to do your wiring yet?
Old 05-02-2013, 07:05 PM   #418
TyConway
Member#: 193189
2002 wrx
Wiring is the easy part...Pretty straight forward. stand alone for the engine... then just wire the gauges up...
the starter / ignition wire is already in the chassis harness on the wirefall, along with the charging lead out of the fuse box.
But maybe just me, but wiring is simple if you have some patience. But I have wired a ton of lsx swaps and various honda swaps.
I also deleted all the abs system... and took out anything I wasn't going to use...
Also just browsed through your thread... the piece I custom machined were to replace the lower ball joint, ( i have custom lower A-arms to correct the steering geometry so I will have no bump steer). They aren't the same as yours for steering... You just have the drop down spacer for the tie rods which in fact really doesn't correct the geometry for the steering rack being lowered. your car will still have bump steer like is setup now.
Old 05-02-2013, 07:19 PM   #419
Strangerdanger
Member#: 324329
Yeah I'm not that great with wiring. This is my first car I've ever done anything aftermarket too lol. So I'm really intimidated but the wiring. I have a local shop willing to do it for 350. Do you think that's a reasonable price?
Old 05-02-2013, 07:20 PM   #420
wrxoutback
Member#: 349061
2002 impreza wrx
06 subaru LGT
looking really really good!!!!! but please paint that idler.
wrxoutback is offline   Reply With Quote
Old 05-02-2013, 07:30 PM   #421
TyConway
Member#: 193189
2002 wrx
Its an old one, put it on to find the correct size belt. I have a new one ordered and a new power steering reservoir, and bracket.
Old 05-02-2013, 07:31 PM   #422
TyConway
Member#: 193189
2002 wrx
Just buy a stand alone from my friend Chase... ( chasebays.com ) buy the universal application ls1 harness. But they are simple hookup... Not sure what your price would be, I get a good hookup from him...
Old 05-02-2013, 07:36 PM   #423
TyConway
Member#: 193189
2002 wrx
This is to clear up the steering setup on my car... Theres alot more involved than just lowering the steering rack...
When you do this it screws all the geometry up... why I have custom length A-arms and custom built cradle to fix all of this...
There isn't a easy fix by adding spacers... Here are three illustrations to help
Old 05-02-2013, 07:39 PM   #424
TyConway
Member#: 193189
2002 wrx
To the first illustration.... you have to think , we are lowering the steering rack... just not lowering the ride height.... thats why the spacer isn't for our application. It would help if the car was just lowered... and the Steering rack in the factory location.
Old 05-02-2013, 07:51 PM   #425
Strangerdanger
Member#: 324329
Thank you very much for taking your time to explain too me. I really appreciate it. So do you think I will have horrendous bump steer with my current setup.
