Old 05-02-2013, 08:35 PM   #426
TyConway
Member#: 193189
2002 wrx
Originally Posted by Strangerdanger View Post
Thank you very much for taking your time to explain too me. I really appreciate it. So do you think I will have horrendous bump steer with my current setup.
Since yours is a track car... Id be most worried about the ackerman, b/c your front wheels are what is gonna be crucial for drifting and staying in control.
But I don't know how much different the 240 rack is... and how much you have dropped your rack.. theres a lot to think about on your setup... Thats the reason I tossed the first cradle I built, I got the geometry off when i was mocking up. But I'll post on your thread, don't want to jack my build thread up too much.
TyConway is offline   Reply With Quote
Old 05-04-2013, 01:37 PM   #427
TyConway
Member#: 193189
2002 wrx
Got a few things out of the way on the car.
All the brake lines are 100% complete
Wilwood Clutch master cylinder mounted.
Steering extension fully finished and installed.
Front knuckles are off, one is fully braced, and 100% welded up. 1 to go.
Old 05-04-2013, 02:58 PM   #428
Strangerdanger
Member#: 324329
Hey I'm also doing an abs delete. I was wondering if you had a break diagram to go by?
Strangerdanger is offline   Reply With Quote
Old 05-04-2013, 03:22 PM   #429
TyConway
Member#: 193189
2002 wrx
Id appreciate you pm me.... I Dont want to keep jacking my build thread up.
Thanks.
Old 05-06-2013, 03:41 AM   #430
TyConway
Member#: 193189
2002 wrx
Brake lines all tied together ( ABS Deleted )
Front stainless line connecting into the stainless lines going to the brake caliper
Old 05-06-2013, 03:47 AM   #431
TyConway
Member#: 193189
2002 wrx
Steering Linkage Completed ( DOM tubing used)
Old 05-06-2013, 03:54 AM   #432
TyConway
Member#: 193189
2002 wrx
Front Knuckles braced and finished.
3/16" steel plate
The welds to the Cast were done in two passes, First was fusion weld ( no filler added) mainly to get heat into the cast metal and to burn the impurities out) second pass was with filler rod. The it was wrapped in a welding blanket to allow a slow cool down to keep the strength to the max on cast metal. Also got a nice piece of cast metal that popped and hit me in my eye... lucky enough it burnt my contact and not my eye.
Old 05-06-2013, 03:54 AM   #433
TyConway
Member#: 193189
2002 wrx
Painted with epoxy
Old 05-06-2013, 12:33 PM   #434
jparker7
Member#: 264045
Looks like a great build but will probably be priced a little higher then im interested in spending.
jparker7 is offline   Reply With Quote
Old 05-06-2013, 08:43 PM   #435
TyConway
Member#: 193189
2002 wrx
Fuel pumps came in today
Bosch 044's
Bosch 44 compared to a walbro 400
Old 05-06-2013, 10:42 PM   #436
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
coming along nicely. very nice work sir!
Rene2.5RS is offline   Reply With Quote
Old 05-06-2013, 11:20 PM   #437
Hebidoshi
Member#: 355680
97 GF8/92 cressida
this is one awesome build sir :tup:
Hebidoshi is offline   Reply With Quote
Old 05-06-2013, 11:35 PM   #438
grandotitat
Member#: 355259
2003 Forester XT
I've seen sick projects but this is by far the best one i've seen. Can't wait to see videos of that bugeye rolling.
grandotitat is offline   Reply With Quote
Old 05-07-2013, 03:44 PM   #439
TyConway
Member#: 193189
2002 wrx
Saw a few things I wanted to change in my engine bay, so the engine is back out... while its out I'm going to go ahead and paint the engine bay as well.
Old 05-07-2013, 03:55 PM   #440
05subysti
Member#: 268190
2005 STi
You keeping the bay gray, or actually paint matching it? What things you wanted to change?
Old 05-07-2013, 08:40 PM   #441
TyConway
Member#: 193189
2002 wrx
Base/clear like the exterior. notch on the frame rail to allow a little more clearance for the 4" downpipe. Had to cut a section out and replate it. Want to do an fittings on my heater hose outlets on the firewall. Need to clearance the firewall cowl some for my clutch master cylinder reservoir. On my ls-1 harness its going to have a mil-spec connector on it so it will disconnect at the firewall. Have to weld up the big hole where the oem harness came through. Also have to install 2 more bulkheads for the fuel setup. Mainly just cleaning the bay up.
Old 05-09-2013, 07:55 AM   #442
bapaul
Member#: 147708
Carbon Panda
Subscribed!
bapaul is offline   Reply With Quote
Old 05-12-2013, 06:42 PM   #443
servanter
Member#: 200958
servanter is offline   Reply With Quote
Old 05-13-2013, 02:16 PM   #444
Dubs04wrx
Member#: 310717
04 WRX Wagon
Originally Posted by servanter View Post
So nasty. I'm not going to be able to sleep now.
Dubs04wrx is offline   Reply With Quote
Old 05-13-2013, 04:54 PM   #445
oldgovernor
Member#: 286224
2004 WRX
Man, those front knuckles look completely factory after you painted them. Shame it hides the beautiful welds.
oldgovernor is offline   Reply With Quote
Old 05-15-2013, 12:53 AM   #446
TyConway
Member#: 193189
2002 wrx
the 350z hubs and sti knuckles are a no go... just really no way of making it work. hate that i spent the money that i did on the rear sti knuckes and now cant use them.
Old 05-15-2013, 09:57 AM   #447
05subysti
Member#: 268190
2005 STi
Damn... So what is your plan now?
I read s14 Nissan hubs work and passenger s13/s14 axles.
Old 05-15-2013, 12:15 PM   #448
TyConway
Member#: 193189
2002 wrx
on subarus that have bolt in hub & bearings.. like a legacy or newer model sti... not a wrx like mine.
Just buy the driveshaft shop axles and hubs.
Old 05-15-2013, 01:03 PM   #449
05subysti
Member#: 268190
2005 STi
Such a shame it can't work. I'm surprised you couldn't make it work..
Old 05-15-2013, 06:45 PM   #450
TyConway
Member#: 193189
2002 wrx
its the design of the knuckle... theres a dust seal that the axle slides up into. The 350z axle is just too big (diameter wise) Either have to machine the axle or the knuckle... either or, not worth trying or making work.
Also my stock calipers will not bolt back onto the jdm sti knuckle.. unlike i was told by the seller.. told me they would swap with no issues. not the case... so it would have to be a ton of work and machine time, hub redrilled for correct lug pattern, caliper bracket modified or changed, then the ebrakes, depending on which caliper bracket i went with. then still have to machine the hubs so they would fit. Yea i'll just save the headache and do it the right way the first time.
