Old 04-25-2013, 09:13 PM   #1
bipolarnrute
Member#: 340737
Exclamation Help NEEDED, Any Ideas ??
Help! in the process of doing a v7 swap, struggling a couple hours to get the passenger side mount to fall into place. Me and my pops pulled the ej205 out using the diy and it went smoothly,Putting the v7 in was a different story.
The whole time my pops kept saying he thought the transmission was offset to the right. at first i thought he was just seeing things but it explained why we couldnt get the stud to line up.
once we finally did.... this is what we were left with
the dog bone isnt straight
in the pic above the timing cover is pressing against the engine bay
bipolarnrute is offline   Reply With Quote
Old 04-25-2013, 09:16 PM   #2
bipolarnrute
Member#: 340737
ive looked at everything from the tranny back and nothing looks bent. Any help or ideas on how to set this straight?? I can take more pics
Old 04-25-2013, 10:32 PM   #3
Antiharper
Member#: 350489
09 Impreza 2.5i
There is a certain amount of "adjustment" you can get from loose motor mounts. Other than that something has to be off. I'd loosen mounts, align better and tighten mounts down. Good luck
Antiharper is offline   Reply With Quote
Old 04-25-2013, 11:10 PM   #4
bipolarnrute
Member#: 340737
i will definitely try that. We pretty much "adjusted" the passenger side to get it to fall in place, now that everything is in, loosening it all at the same time sounds like a good idea,
after messing with it for the whole morning, once it was in we decided that was a good time to take a break.
Thanks for the idea. I'll let you know how it goes.
Old 04-28-2013, 05:23 PM   #5
bipolarnrute
Member#: 340737
No luck. If anything the timing cover is a centimeter away from touching the engine bay now. Any other ideas ??? I wouldnt feel comfortable driving it like that.
Old 04-29-2013, 05:26 PM   #6
bipolarnrute
Member#: 340737
bump for more suggestions..?
Old 04-29-2013, 10:18 PM   #7
Antiharper
Member#: 350489
09 Impreza 2.5i
Pics ynderneath? If its that far out in the pics how is your drive line rear axle/diff area? Can't drive like that.
Old 05-02-2013, 06:01 PM   #8
bipolarnrute
Member#: 340737
I took some pics and tried to capture any areas of concern the best i could.
There is a certain spot where the driveshaft seems to start to look a little off, but im assuming thats just where it allows for "play"
hope the pics help
Something i questioned was why this one bolt was so shiny and new compared to the other
not the best pic
and lastly
Again i appreciate any thoughts or ideas. Thanks
Old 05-02-2013, 07:45 PM   #9
Antiharper
Member#: 350489
09 Impreza 2.5i
Looks like your hanger bearing was replaced due to shiny bolt, not your problem. as long as everything bolted together trans-engine easily I can't see why this is happening. Was the car a wreck? Frame crooked? It's a long shot. How much room do you have on the other side? If its equal spaced that's all you get. Also check lower crossmember mount. This one adjusts a lot, if I remember correctly.
Old 05-02-2013, 08:45 PM   #10
bipolarnrute
Member#: 340737
No the car was never wrecked to my knowledge, everything looks symmetrical under the car.
but on top is a different story
passenger side
drivers side
Old 05-03-2013, 03:22 PM   #11
SubaruKing
Member#: 262875
Default Mounts
Did you get all new mounts and try tightening them down intermittently?
SubaruKing is offline   Reply With Quote
Old 05-07-2013, 11:41 AM   #12
Antiharper
Member#: 350489
09 Impreza 2.5i
passenger side
drivers side
Dude that engine has got to move over. Try loosening all mounts again. It has to go over atleast an inch. Get a big bar and pull.
Old 05-07-2013, 10:23 PM   #13
niemkij
Member#: 141922
2006 Impreza Sti
I would check around and on top of the trans for anything wedged against the car body or frame.
niemkij is online now   Reply With Quote
Old 07-30-2013, 08:29 PM   #14
bipolarnrute
Member#: 340737
I forgot to Update, It was the passenger side axle causing everything to be pushed towards the driver's side of the car. It wasn't the right length. Not sure how he drove it that way. My uncle demonstrated, when I raised the vehicle up on jacks the axle shifted in some way and caused the problem. He said the same thing could of happened while driving, if the suspension had been allowed to travel the same amount.
